EcoFlow DELTA Max Solar Generator (Rigid PV400W*2) | 2*400W Rigid Solar Panel + DELTA Max (2000)
USD $2,559.00
Regular price USD $2,559.00
Sale price USD $2,559.00 Regular price $3,499.00
-$940
Secure your power supply with an EcoFlow DELTA Max solar generator bundle at home. Plug in 400W Rigid Solar Panels and get up to 800W input to charge from anywhere in as fast as 3 hours.
The Portable & Expandable Home Battery DELTA Max expands up to 6kWh with Smart Extra Batteries, keeping your home powered on in any emergency.
Rapid Dual Charging X-Stream tech means that DELTA Max charges 7 times faster than the competition. That’s 0–80% in just 65 minutes with AC input. Plug in EcoFlow solar panels and charge in as fast as 3 hours with 2 x 400W rigid solar panels.
Fast Charging With a high conversion efficiency rate of up to 23%, the 400W panel charges your LFP batteries faster than similar-sized solar panels.
Weatherproof & Durable The rigid panel balances design with robust materials allowing the panel to weather any storm while offering the same excellent performance and aesthetics for years.
Off & On-grid Solution This high-wattage panel works for both on-grid and off-grid solar-powered setups, storing energy for outages, reducing power bills, or powering an off-grid home.
Universally Compatible The 400W solar panel includes a 300mm charging cable that gives you plenty of space, maximizing solar input. With an all-inclusive solar connector, the 400W rigid panel works with other 3rd party solar systems and power stations.
USD $2,559 $3,499 -$940
EcoFlow DELTA 3 Smart Extra Battery
Expandable Capacity
Increase The Capacity Of DELTA 3 Plus/DELTA 3 With An Extra 1024Wh. Double The
Capacity To Fit Your Energy Storage Needs, Ideal For Home Backup, RVingOutdoor
Adventures, And Everyday Use.
Same Power, More Compact.
With The Compact Design, The DELTA 3 Smart Extra Battery Is1/3 Smaller Than Its
DELTA 2 Counterpart. It Can Also Be Securely Stacked On Top Of The Power Station To
Save Space And Minimize Clutter.
10-year Lifespan with an
LFP Battery
With The LFP Battery Chemistry, The DELTA 3 Smart Extra Battery Has A Lifespan Of
4000 Complete Cycles Until 80% Capacity. You'll Get Pretty Much 10 Years Of Power,
Even If You Use It Every Day. That's 6x Longer Than Other Power Stations With A Similar
Capacity And Output.
Easy to Use
There's No Setup. Just Plug Into Your Power Station For More Energy Storage. Using
The EcoFlow App, You Can Charge And Monitor The DELTA 3 Smart ExtralBattery With
Ease.
Control From Anywhere
Get All The Same Info About Battery Percent, Remaining Recharge Time, Hours Left,
And More On The Built-In Screen. You Can Check The Battery's Status Right From The
EcoFlow App.
Convenient Recharging
Connect The Extra Battery To The Power Station's Extra Battery Port/And Recharge
From AC Outlets, Portable Solar Panels, Or Our Smart Generator.
What's In The Box?
How long is the EcoFlow Smart Home Panel 2 warranty?
EcoFlow Smart Home Panel 2 has a 10-year of quality assurance warranty.
What is the Smart Home Panel 2 weather-protection level?
Distribution panel: NEMA 3R standards can be installed indoors and out (equivalent to IP14). Battery connection box: NEMA Type 1 electrical enclosure; safe for indoor installation (equivalent to IP10).
Can I install the EcoFlow Smart Home Panel 2 by myself?
EcoFlow Smart Home Panel 2 must be installed by certified installers and electricians who have completed EcoFlow Smart Home Panel 2 product training. We also offer an installation consultation for EcoFlow Smart Home Panel 2. See here for details.
How long does it take to install EcoFlow Smart Home Panel 2?
EcoFlow Smart Home Panel 2's installation time may vary depending on the scope of work required and the current configuration of the circuits in your home. For most homes, EcoFlow Smart Home Panel 2 installs in 3-8 hours, which is similar to replacing a standard distribution box.
Will installing EcoFlow Smart Home Panel 2 and EcoFlow DELTA Pro Ultra affect NEM 2.0?
No. Since EcoFlow DELTA Pro Ultra it won't affect NEM 2.0. It cannot be connected to NEM 2.0 rooftop photovoltaic systems, so a new system would need to be installed.
Is Smart Home Panel 2 repairable? How can it be repaired?
Any Smart Home Panel 2 needs to be repaired by a professional electrician. Although the panel does not need to be removed from the wall, Smart Home Panel 2 certified technicians must repair the internal assembly and reconfigure the internet connection. If you need this service, please contact the Smart Home Panel 2 technical support team for troubleshooting and determine whether to return to the factory for repair.
How many circuits can Smart Home Panel 2 manage?
Smart Home Panel 2 can manage up to 12 × 120V circuits or 6 × 240V circuits and can be selected according to different needs.
How to connect EcoFlow DELTA Pro Ultra with Smart Home Panel 2?
EcoFlow DELTA Pro Ultra connects with Smart Home Panel 2 using an EcoFlow Power Input/Output Cable (5 + 8). If additional cables are needed, they can be purchased on the official online store.
Why doesn't Smart Home Panel 2 have the same automation features as Smart Home Panel? Why can't we take one circuit on grid while taking another off the grid?
The Smart Home Panel automated timing feature is still available. Smart Home Panel 2 can only achieve a full mains or energy storage power supply for a circuit, and this is based on North American distribution panels.
How many EcoFlow DELTA Pro/EcoFlow DELTA Pro Ultra units are supported by EcoFlow Smart Home Panel 2?
EcoFlow Smart Home Panel 2 can connect to EcoFlow DELTA Pro and EcoFlow DELTA Pro Ultra. Up to 3 EcoFlow DELTA Pro Ultra Inverters can connect to EcoFlow Smart Home Panel 2, each inverter allowing for 5 batteries. A total of 2 EcoFlow DELTA Pro, with 2 Smart Extra Batteries per unit, can connect to the EcoFlow Smart Home Panel 2 using the EcoFlow Double Voltage Hub.
Does the Smart Home Panel 2 offer three-phase electrical power like the German electrical grid?
Smart Home Panel 2 can support two-phase electrical output but cannot achieve three-phase.
