EcoFlow DELTA Max Portable Power Station + 2*400W Rigid Solar Panel + | 2*400W Rigid Solar Panel + DELTA Max (2000) + DELTA Max Smart Extra Battery | EcoFlow
EcoFlow DELTA Max Portable Power Station + 2*400W Rigid Solar Panel + EcoFlow DELTA Max Smart Extra Battery
USD $3,759.00
Regular price USD $3,759.00
Sale price USD $3,759.00 Regular price $5,098.00
-$1,339
Up to EcoCredits for cash deduction
DELTA Max Solar Generator
Secure your power supply with an EcoFlow DELTA Max solar generator bundle at home. Plug in 400W Rigid Solar Panels and get up to 800W input to charge from anywhere in as fast as 3 hours.
The Portable & Expandable Home Battery DELTA Max expands up to 6kWh with Smart Extra Batteries, keeping your home powered on in any emergency.
Rapid Dual Charging X-Stream tech means that DELTA Max charges 7 times faster than the competition. That’s 0–80% in just 65 minutes with AC input. Plug in EcoFlow solar panels and charge in as fast as 3 hours with 2 x 400W rigid solar panels.
Fast Charging With a high conversion efficiency rate of up to 23%, the 400W panel charges your LFP batteries faster than similar-sized solar panels.
Weatherproof & Durable The rigid panel balances design with robust materials allowing the panel to weather any storm while offering the same excellent performance and aesthetics for years.
Off & On-grid Solution This high-wattage panel works for both on-grid and off-grid solar-powered setups, storing energy for outages, reducing power bills, or powering an off-grid home.
Universally Compatible The 400W solar panel includes a 300mm charging cable that gives you plenty of space, maximizing solar input. With an all-inclusive solar connector, the 400W rigid panel works with other 3rd party solar systems and power stations.
USD $3,759 $5,098 -$1,339
*DELTA Max needs to be connected to the DELTA Max Smart Extra Battery for dual charging.
Expandable Capacity
Dual Charging
Power Multiple Devices
800W max Solar Input
Expandable home backup power.
DELTA Max charges up safely and rapidly from 0-80% in just 65 minutes. And it gets even better. If you’re looking for an even faster way to charge up DELTA Max, you can combine AC with the smart generator to get up to 3400W, AC with solar to get up to 2600W, or the Smart Generator with solar to get up to 2600W.*
With EcoFlow’s X-Boost technology, DELTA Max can power heavy-duty devices up to 3400W. That means during a power outage or blackout, you can continue to power your fridge, dryer, and more. That’s the industry gold standard for a portable power station of this size and capacity.
Harness the power of the sun.
DELTA Max connects with up to 2x 400W EcoFlow solar panels to deliver 800W Max solar charging speeds. With a voltage range from 11-100V and the Solar connector, you can also connect other solar panels to your DELTA Max. Even during cold or cloudy days, our smart maximum power point tracking (MPPT) algorithm automatically detects voltage and current in real time to give you optimum solar generation throughout the day.
Emergency backup power.
Multiple ways to charge.
1. DELTA Max 2.AC Charging Cable 3. Car charging cable 4. DC5521 to DC5525 cable 5.User Manual and Warranty card 6. 2×400W Rigid Solar Panel 8. Solar to XT60 Charging Cable 9. Support Brackets 10. DELTA Max Smart Extra Battery
It depends on the total voltage and watts of solar panels you choose. As long as the solar panels use MC4 connector and its voltage and current are under 11-100V, 13A max range.
When charging DELTA Max and its extra battery together, you can reach 3600W max charging speeds by combining any two methods of AC, solar and Smart Generator. For DELTA Max single unit, you can recharge it at standard wall outlets (1800W max), or combine AC and solar charging to reach max 2000W charging speeds.
When your portable power station is plugged into the wall, any electronics plugged into it are powered from the grid and not its battery. When power from the grid stops, as in a blackout, the power station automatically switches to battery power within 30ms.
DELTA Max is not water-resistance, so it should be kept away from liquids. Or if you're looking for water-resistance solution, you can purchase the DELTA Max case to water-resistance protection.
Specs of DELTA Max (2000)
2016Wh
Extra Battery
Support up to two DELTA Max Smart Extra Battery/Smart Generator
6 outlets, 2400W total (Surge 5000W)
3400W
USB-A Fast Charge
Car Power Output
12.6V, 10A, 126W Max
DC5521 Output
AC Charging Input
1800W Max, 15A
Solar Charging Input
800W Max, 11-100V, 13A
Car Charging Input
Support 12V/24V battery, 8A
NCM
800 cycles to 80% capacity
Connection
Wi-Fi
Approx. 48lbs
Dimension
19.6*9.5*12 in
Specs of DELTA Max (1600)
1612Wh
Extra Battery
6*20A outlets, 2000W total (Surge 5000W)
2800W
USB-A Fast Charge
Car Power Output
DC5521 Output
AC Charging Input
1600W Max, 15A
Car Charging Input
NCM
500 cycles to 80% capacity
Connection
Wi-Fi
Approx. 48lbs
Dimension
19.6*9.5*12 in
