EcoFlow DELTA 3 Series + Smart Extra Battery | EcoFlow US | DELTA 3 Plus+ Smart Extra Battery + 800W Alternator Charger
EcoFlow DELTA 3 Plus + Smart Extra Battery + 800W Alternator Charger - Web Exclusive
USD $1,399.00
Regular price USD $1,399.00
Sale price USD $1,399.00 Regular price $1,997.00
-$598
Up to EcoCredits for cash deduction. Log in
 * Increase the capacity of DELTA 3 Plus/DELTA 3 with an extra 1024Wh.
*Get 10 years of daily use until it hits 80% of its original capacity. Embrace 3000+ charging cycles enabled by the LFP battery chemistry.
*Plug-and-play system. Use the EcoFlow app to monitor and control the DELTA 3 Smart Extra Battery.
*With one of the most comprehensive 5-year warranties available, we go the extra mile to give you peace of mind.
USD $1,399 $1,997 -$598
How long is the EcoFlow Smart Home Panel 2 warranty?
EcoFlow Smart Home Panel 2 has a 10-year of quality assurance warranty.
What is the Smart Home Panel 2 weather-protection level?
Distribution panel: NEMA 3R standards can be installed indoors and out (equivalent to IP14). Battery connection box: NEMA Type 1 electrical enclosure; safe for indoor installation (equivalent to IP10).
Can I install the EcoFlow Smart Home Panel 2 by myself?
EcoFlow Smart Home Panel 2 must be installed by certified installers and electricians who have completed EcoFlow Smart Home Panel 2 product training. We also offer an installation consultation for EcoFlow Smart Home Panel 2. See here for details.
How long does it take to install EcoFlow Smart Home Panel 2?
EcoFlow Smart Home Panel 2's installation time may vary depending on the scope of work required and the current configuration of the circuits in your home. For most homes, EcoFlow Smart Home Panel 2 installs in 3-8 hours, which is similar to replacing a standard distribution box.
Will installing EcoFlow Smart Home Panel 2 and EcoFlow DELTA Pro Ultra affect NEM 2.0?
No. Since EcoFlow DELTA Pro Ultra it won't affect NEM 2.0. It cannot be connected to NEM 2.0 rooftop photovoltaic systems, so a new system would need to be installed.
Is Smart Home Panel 2 repairable? How can it be repaired?
Any Smart Home Panel 2 needs to be repaired by a professional electrician. Although the panel does not need to be removed from the wall, Smart Home Panel 2 certified technicians must repair the internal assembly and reconfigure the internet connection. If you need this service, please contact the Smart Home Panel 2 technical support team for troubleshooting and determine whether to return to the factory for repair.
How many circuits can Smart Home Panel 2 manage?
Smart Home Panel 2 can manage up to 12 × 120V circuits or 6 × 240V circuits and can be selected according to different needs.
How to connect EcoFlow DELTA Pro Ultra with Smart Home Panel 2?
EcoFlow DELTA Pro Ultra connects with Smart Home Panel 2 using an EcoFlow Power Input/Output Cable (5 + 8). If additional cables are needed, they can be purchased on the official online store.
Why doesn't Smart Home Panel 2 have the same automation features as Smart Home Panel? Why can't we take one circuit on grid while taking another off the grid?
The Smart Home Panel automated timing feature is still available. Smart Home Panel 2 can only achieve a full mains or energy storage power supply for a circuit, and this is based on North American distribution panels.
How many EcoFlow DELTA Pro/EcoFlow DELTA Pro Ultra units are supported by EcoFlow Smart Home Panel 2?
EcoFlow Smart Home Panel 2 can connect to EcoFlow DELTA Pro and EcoFlow DELTA Pro Ultra. Up to 3 EcoFlow DELTA Pro Ultra Inverters can connect to EcoFlow Smart Home Panel 2, each inverter allowing for 5 batteries. A total of 2 EcoFlow DELTA Pro, with 2 Smart Extra Batteries per unit, can connect to the EcoFlow Smart Home Panel 2 using the EcoFlow Double Voltage Hub.
Does the Smart Home Panel 2 offer three-phase electrical power like the German electrical grid?
Smart Home Panel 2 can support two-phase electrical output but cannot achieve three-phase.
