Power. Never Been This Easy
Charge 0-100% in 1 Hour
Fastest charging speeds ever.
RIVER 2 Max beats the industry charging speed standard, fully charging in only 60 minutes. That's 5x faster than other portable power stations on the market and 38% quicker than previous generations. Fully charge RIVER 2 Max while you pack your bags, so you'll always be ready for a last-minute trip.
LiFePO4 Battery Chemistry
5-year Warranty
Our state-of-the-art Battery Management System (BMS) constantly monitors the voltage, current, and temperature of RIVER 2 Series with multiple aspects of protection, extending its life to the max.2
4 Ways to Charge
Charge anywhere.
AC Charging
Car Charging
USB-C Charging
AC Charging Car Charging
Solar Charging USB-C Charging
Why not harness renewable energy while you camp or head off on a trip? Plug in a couple of portable solar panels to fully recharge off-grid in as fast as 3 hours.
RIVER 2 Pro Solar Generator produces up to 1.8kWh daily, which means sufficient power to run your essential home appliances smoothly for almost half a day. Sudden power outages? You'll always be ready. Using RIVER 2 Pro Solar Generator every day decreases your whole-year carbon emissions by about 143kg. That's like planting 8 trees in a year!*
Up to 23% Solar Conversion
Faster Solar Charging 0-100% in 4.5-9 hr
IP68 Waterproof Solar Panel
Easily Plug & Unplug
10 Years of Use
Long-term Saving
*Based on an average carbon emission of 0.371kg/kWh and an average sunshine duration of 6 hours/day.
X-Boost Up to 1000W
Small size. Big power.
RIVER 2 Max has an AC output of up to 500W. Need to power a vacuum cleaner or sandwich maker? Crank it up to 1000W with X-Boost mode to run up to 80% of essential appliances.
Lightweight at only 13.2 lbs
With a compact portable design, taking travel-friendly power off-grid has never been this easy. With a light-weight that's 22% lighter than the previous generation, RIVER 2 Max is ready to power all your outdoorsy escapades, from boondocking to BBQs at the beach.
<30ms EPS Auto-switch
Ultra-fast home backup switchover.
With a switchover speed of less than 30ms, you won't even know the power was down. Use RIVER 2 Series as an emergency power supply for overnight outages to keep essentials running from a light to your fish tank.
EcoFlow App
Control at your fingertips.
Use the EcoFlow app to control and monitor RIVER 2 Series, even from afar. View charging levels, customize settings, and adjust charging speeds, all from the convenience of your phone.
LEARN MORE >
Power. Anywhere. Anytime.
1. RIVER 2 Pro 2. AC Charging Cable 3. Car Charging Cable 4. DC5521 Connection Cable 5. Quick Start Guide
RIVER 2 Max Specs
512Wh
Approximately 13.4lbs
10.6 x 10.2 x 7.7inches
AC Input
100-120V 50Hz/60Hz, 660W Max
Solar Input
11-50V, 13A, 220W Max
USB-C Input/Output
5/9/12/15/20V, 5A, 100W Max
DC Output
12.6V, 10A/3A/3A, 126W Max
5V, 2.4A, 12W Max
120V 50Hz/60Hz, 500W (Surge 1000W)
Cell Chemistry
Discharge Temperature
14°F to 113°F/-10°C to 45°C
Charge Temperature
32°F to 113°F/0°C to 45°C
Optimal Operating Temperature
68°F to 86°F/20°C to 30°C
Storage Temperature
14°F to 113°F (68°F to 86°F is best)/-10°C to 45°C (20°C to 30°C is best)
Car Input
12V/24V, 8A, 100W Max
DC5521 Output
12.6V, 3A, 36W Max
App Control
Wi-Fi, Bluetooth
1. Using RIVER 2 Max six times a week, 3000 full 100% cycles will last 9.6 years until it drops to 80%.
3. When charging and discharging at high wattage, RIVER 2 Max may make a noise up to 62db.
