DELTA Pro 3 + Smart Home Panel 2 | EcoFlow | EcoFlow DELTA Pro 3 + Smart Home Panel 2 + Folding Wagon Cart | EcoFlow
USD $4,299.00
Regular price USD $4,299.00
Sale price USD $4,299.00 Regular price $5,727.00
-$1,428
Up to EcoCredits for cash deduction. Log in
Get up to $1,289.70 in rebates through the Residential Clean Energy Credit. Learn More >
Up to $1,289.70 in rebates
Amount 30% off
Claim By: December 31, 2032
Program: Residential
  • Rentals do not qualify.
  • Must be grid-tied.
Whole-home power solution
EcoFlow DELTA Pro 3 + EcoFlow Smart Home Panel 2
-Intelligent subpanel for home battery systems.
-20 ms auto switchover
-EcoFlow app control
-Modular design
-12-circuit sub-panel
Recommend
You Could Apply for 30% Tax Credit*, When You Install EcoFlow DELTA Pro 3 as a Home Power SolutionLearn more
USD $4,299 $5,727 -$1,428
An Intelligent Subpanel For Outage Protection And Savings In One
The EcoFlow Smart Home Panel 2 is the center of your whole-home backup solution,
working alongside EcoFlow DELTA Pro 3, generators, and sollar panels to protect your
home. With a fast, automatic switchover, you'll have reliable backup whenever needed. It
allows you to customize your energy usage based on time-of-use rates and your home's
solar energy production.
The Commanding ForceBehind Your Power System
The Whole-Home Backup System Hub
EcoFlow Smart Home Panel 2 is the hub of the powerful EcoFlow DELTA Pro 3, allowing
you to maximize your energy system's potential. Connect your home circuits to 3 x
EcoFlow DELTA Pro 3 units with 6 x Extra Batteries for energystorage of up to 36kWh.
It's not just for longer backup but also lets you control and runevery single household
appliance. EcoFlow Smart Home Panel 2 is future-proofed to vwork with our next-gen
power solutions and the EcoFlow DELTA Pro.
Even Plan B Has A Plan B
Compatible With Solar And Gas Generators
EcoFlow Smart Home Panel 2 can manage energy from variouss sources, including solar
and gas. With the sun's rays, brighten your home with cost-effcective green energy and
dramatically reduce your electricity expenses. When the weather turns gray and you're all
out of the sunshine, a seamless connection to any 3-12kW portable gas generator
ensures your home stays energized without a hitch.
The Nights Of Fumbling ForA Torch Are Over
20-Ms Auto-Switchover
When an outage hits, there's no need to brave the darkk, cold night to switch to your
backup manually. EcoFlow Smart Home Panel 2's automattic switchover feature ensures
your home remains powered even when you're away. Forget spoilead food and damaged
appliances. Embrace uninterrupted power so that life never stops.
Leave The Power Prep To The Pro
EcoFlow App
EcoFlow Smart Home Panel 2 ensures your home is blackeout-proof with ample energy at
all times. Even when an outage lingers on, it's business as usual.
Backup Extension
Categorize your home circuits into three levels of power supply priority with Circuit Control mode. Ensure protection for the most mission-critical tasks and massively extend backup time.
Emergency Weather Prep
With automatic storm warnings mode, batteries fully recharge12 hours before an extreme weather event. Lockina eneray until an outage occurs. EcoFlow Smart Home Panel 2 rmonitors the
weather hourly, updating the system based on the forecast offering a more precise backup strategy
Savings Just Roll On In
With The EcoFlow App
With Backup Reserve mode, EcoFlow Smart Home Panel 2 securres an assigned battery
percentage. Fear an impending outage? Set a higher reserve for hoome backup. For everyday use, set a lower portion and customize your EcoFlow Smart Home Panel 2's performance using Self-Power, Scheduled Tasks, or TOU Modes tto lower your energy bills.
TOU Mode
Based on Time Of Use peak and off-peak rates and your energy habits, EcoFlow Smart Home Panel 2 intelligently manages battery charge and discharge, significantly offsetting electricity
costs.
Self-Power Mode
Once battery capacity exceeds the pre-set reserve, solar begins to top up energy supplies while powering the home to lower utility bills.
See Your Entire Energy Strategy At Work
EcoFlow App, Powerlnsight & Web Dashboard
View real-time energy insights for your home anywhere you go. CDn your phone, wall
mounted dash, or even online. Get a complete home energy consumption ofverview as
well as solar and gas input, battery capacity, and much more. With EcoFlow Smart Home
Panel 2 comes Powerlnsight, a wall-mounted screen, and a webdashboard, accessible
anywhere online.
See Your Entire EnergyStrategy At Work.
View real-time energy insights for your home anywhere you go. COn your phone, wall
mounted dash, or even online. Get a complete home energy coonsumption overview as
well as solar and gas input, battery capacity, and much more. With EEcoFlow Smart Home
Panel 2 comes Powerlnsight, a wall-mounted screen, and aweb dashboard, accessible
anywhere online.
View real-time energy insights for your home anywhere you go. On yourphone, wall
mounted dash, or even online. Get a complete home energy cornsumption overview as
Panel 2 comes Powerinsight, a wall-mounted screen, and a wetdashboard, accessible
anywhere online.
EcoFlow app
EcoFlow Powerlnsight
Web dashboard
Monitor, control,and customize your power usage at your fingertips
Monitor, control,and customize your power usage at your fingertips.
Home Energy Manager, An All-In-One Dedicated Monitor.
Installation Consulting Service For EcoFlow Smart Home Panel 2
$99 FREE NOW!
With our service, you'll experience a seamless EcoFlow Smart HHome Panel 2 installation
We connect you with a fully-trained local electrician and providetracking from order to
fitting. Our team is on hand to answer any technical queries, enssuring a smooth, hassle
free setup that prioritizes your convenience and satisfaction.
EcoFlow Smart Home Panel 2 (or Smart Home Panel 2 bundle) + Installation fee Installation Terms & Conditions
Installation Conditions
2. If customer's home is such that the required wiring length may cause voltage drop and not satisfy NEC requirements, the installation may not be possible.
3. In the event of unforeseen circumstances that may prevent inistallation, EcoFlow reserves the right to determine the final feasibility of installation.
1.To support sales of Smart Home Panel 2 or Smart Home Panel 2 bundle in North America through the EcoFlow US official website, EcoFlow offers an installation service package, which includes the basic installation cost for Smart Home Panel 2.
2.Customers who purchase EcoFlow Smart Home Panel 2 or EcoFlovw Smart Home Panel 2 bundle through Shopify may opt to purchase the "Installation service Package". EcoFlow customer service is responsible for matching the customers with electricians who can take the orderand for following up on the progress of the installation.
3.Installation Service Package includes wiring the EcoFlow Smart Home Panel 2 to the existing load center. It does not include pulling permits from AHD (If required by customers, addiitional fees may apply), wiring the EcoFlow Smart Home Panel 2 to a generator, or wiring thee EcoFlow Power Station to solar panels or PV systems. If the customer requires the installation to include wiringthe EcoFlow Smart Home Panel 2 to generator, or wiring to solar panels or PV systems, the electrician reserves the right to refuse to take the order.
4.The installation service fee on the official website covers labor costs and the materials needed for installing Smart Home Panel 2 within 2 feet of the load center. This excludes:
a.Additional material and labor costs due to excessive distance or incompatibility between the existing circuit breaker and Smart Home Panel 2.
c. The electrician's on-site assessment fee, which can be waivedif the circumstance has been assessed by the electrician to be suitable for installation and the customer does not request for refund of the installation service fee.
The above extra costs and fees shall be subject to the actual quote from the electrician. Customers are responsible for directly paying the electrician for any extra costs ircurred. EcoFlow reserves the right to final interpretation of the installation service fee.
5.By agreeing to EcoFlow's installation services, you consent to the collection and processing of personal information necessary for completing the service. This may include, but is not limited to, your name,address, contact information, and any relevant details related to the installation. We will handle your personal information in compliance with applicable data protection laws and regulations and will only use it for the purpose of fulfilling the installation service. Please refrain from directly providing your personal information to the electrician during the installation process, otherwise you will be responsible for any loss or damage caused by the disclosure of such information.
3. Should a customer opt for our installation service and then decide to return the Smart Home Panel 2 due to dissatisfaction after installation, the paid installation fee cannot be funded. Additionally, the customer will be responsible for any costs associated with the removal of Smart Home Panel 2.
4. The installation service does not include any cleaning or removalof debris generated during the installation process. Residents are responsible for managing and disposing of all trash and debris resulting from the installation.
5. Any holes or modifications made to the premises during theinstallation are considered normal and necessary for the proper completion of the service. The installer shall nnot be held liable for any unavoidable damages or alterations made to the premises during the installation process.
7. Any product issues or defects resulting from installation by an unauthorized installer shall be the sole responsibility of the resident. The resident shall bear full responsibility or any after-sales service or repairs needed due to such unauthorized installations.
Disclaimer
Effective date: Jan 1, 2023"
