![EcoFlow DELTA 2 Max Solar Generator (PV220W)](http://us.ecoflow.com/cdn/shop/files/ecoflow-us-ecoflow-delta-2-max-solar-generator-pv220w-32617212837961.png?v=1722462374&width=1000)
DELTA 2 Max + 220W Bifacial Solar Panel
$1,399.00 $2,548.00
“Enjoy Free Solar Energy with 50% lower price”
Fast Charge with 23% conversion rateFull charge with solar in 2.3hr
![EcoFlow DELTA 2 Max + DELTA 2 Max Smart Extra Battery](http://us.ecoflow.com/cdn/shop/files/ecoflow-us-ecoflow-delta-2-max-delta-2-max-smart-extra-battery-30323023380553.png?v=1684216894&width=1000)
DELTA 2 Max + Smart Extra Battery
$2,099.00 $3,298.00
“Enjoy 3X power capacity with 50% lower ”
Expand your DELTA 2 Max to 6144WhTriple power at up to 50% lower cost
Ditch Gas, Go Solar
Winner of Red Dot Design Award 2023. EcoFlow DELTA 2 Max Solar Generator
![](http://us.ecoflow.com/cdn/shop/files/1-kv_2X_087ff187-2645-4b9b-9adc-854b729b5104.png?v=1684400796&width=1000)
![](http://us.ecoflow.com/cdn/shop/files/3-_NA_2X_b611e147-419d-4f80-bda6-5226d91d8478.png?v=1684402407&width=1000)
![](http://us.ecoflow.com/cdn/shop/files/PC__img.jpg?v=1739096930&width=1000)
Durable, Safe, Lightweight
![](http://us.ecoflow.com/cdn/shop/files/10-year_Long-lasting_LFP_Battery_0b3504ee-70ef-4195-b9ac-49bbb49f0e0e.png?v=1710403278&width=1000)
LFP Battery Chemistry
![](http://us.ecoflow.com/cdn/shop/files/LFP_Battery_Chemistry_113341ce-8920-4dd7-a135-ca3cec55fae3.png?v=1685697367&width=2000)
Advanced BMS Protection
![](http://us.ecoflow.com/cdn/shop/files/Advanced_BMS_Protection.png?v=1685427183&width=2000)
![](http://us.ecoflow.com/cdn/shop/files/With_LFP_cells.png?v=1685427431&width=1000)
![](http://us.ecoflow.com/cdn/shop/files/A_rubber_anti-slip_base.png?v=1685427480&width=1000)
![](http://us.ecoflow.com/cdn/shop/files/Robust_Design.png?v=1685427536&width=1000)
Robust Design
![](http://us.ecoflow.com/cdn/shop/files/Upgraded_Tech_Lighter_Weight.png?v=1685427632&width=1000)
Upgraded Tech, Lighter Weight
Power pretty much anything with up to 3400W Output
DELTA Max powers almost all the devices you need with a large 2400W AC output. With X-Boost proprietary technology, run appliances with an output of up to 3400W. Compared with similar portable power stations, DELTA 2 Max can power more devices while also preventing overloading and overheating.
![](http://us.ecoflow.com/cdn/shop/files/Run_99_of_Appliances_with_X-Boost..png?v=1685427726&width=2000)
![](http://us.ecoflow.com/cdn/shop/files/10-1-icon_2x_599c9ebd-7070-4c08-969d-3377a54b764f.png?v=1684490864&width=1000)
120V Home Backup: Power through outages
Power your essential appliances with a hefty 2400W AC output by connecting DELTA 2 Max (2kWh) and up to two Smart Extra Batteries (6kWh) with your home's transfer switch for partial home backup. With a plug-and-play design, it's easier than ever to prepare for blackouts.
![](http://us.ecoflow.com/cdn/shop/files/11-120V_Home_Backup._2X_70cac1a1-f516-4bc3-b964-b4e8dc83d714.png?v=1684736204&width=1000)
Expandable up to 6kWh
Triple the power
![](http://us.ecoflow.com/cdn/shop/files/Expandable_up_to_6kWh.png?v=1685428010&width=2000)
Fuel Up 80% in Only 43 Mins*
With DELTA 2 Max's upgraded tech, combine up to 1000W solar input with AC for world-leading charging speeds. In only 43 min get an 80% charge. Or stick with AC for an 80% charge in a speedy 1.1 hour.
![](http://us.ecoflow.com/cdn/shop/files/Mask_group_07188543-2401-42d1-a643-df61471cf6a9.png?v=1685428074&width=2000)
![](http://us.ecoflow.com/cdn/shop/files/15-99_MPPT_Efficiency_2X_6fb44631-1718-48a6-a096-f0d66d153980.png?v=1684741632&width=2000)
![](http://us.ecoflow.com/cdn/shop/files/17-5-Year_Warranty_2X_a5397bef-be46-4912-b7b2-081c05e7aae4.png?v=1684744738&width=1000)
Extensive 5-Year Warranty
As Quiet as 30 dB
Peaceful charging
![](http://us.ecoflow.com/cdn/shop/files/As_Quiet_as_30_dB.png?v=1685428159&width=2000)
DELTA 2 Series
![](http://us.ecoflow.com/cdn/shop/files/18-Delta_2_series_pc.png?v=1684996082&width=1000)
DELTA 2 Max
![DELTA 2 Max](http://us.ecoflow.com/cdn/shop/files/20-1-DELTA_2_Max_2X_f2bc3279-430f-455c-a13d-15efaf69e18d_535x.png?v=1684745873)
AC Charging Cable
![AC Charging Cable](http://us.ecoflow.com/cdn/shop/files/20-2-AC_charging_cable_2X_26dc7f3f-99ca-4778-bc4b-a6ae6281d34a_535x.png?v=1684747166)
Car Charging Cable
![Car Charging Cable](http://us.ecoflow.com/cdn/shop/files/20-3-Car_charging_cable_2X_dba79ac7-d091-4563-a4ea-9fc1a572206f_535x.png?v=1684747262)
DC5521 to DC5525 Cable
![DC5521 to DC5525 Cable](http://us.ecoflow.com/cdn/shop/files/20-4-Car_charging_cable_2X_7141d48e-04ff-4fa7-b7e9-44888d764d4d_535x.png?v=1684747594)
User manual & warranty card
![User manual & warranty card](http://us.ecoflow.com/cdn/shop/files/20-5-User_manual_warranty_card_2X_a97f9198-d095-4a2d-a702-5b584d4f5a14_535x.png?v=1684747624)
2048Wh
Extra Battery
6 outlets, 2400W total (Surge 4800W)
X-Boost 3400 W
USB-A Fast Charge
Car Power Output
1 port, 12.6V, 10A, 126W Max
DC5521 Output
AC Charging
X-stream Fast Charge 1800W, 15A
AC Input Voltage
100-120V~ max. 15A 50Hz/60Hz
Car Charging
Support 12V/24V battery, 8A
EcoFlow WAVE & WAVE 2 & GLACIER & Smart Generator
Supported
LFP (LiFePO4 battery)
3000 cycles to 80+% capacity
Connectivity
Wi-Fi & Bluetooth
Net weight (lbs)
50 lbs
Net weight (kg)
23kg
