EcoFlow DELTA Pro Ultra | Whole-Home Backup Power | DELTA Pro Ultra + DELTA Pro Ultra Extra Battery (1 × Inverter + 3 × Batteries)
Starting at 0% APR with Pay
Hot
Hot
EcoFlow DELTA Pro Ultra Whole-Home Backup Power (UL 9540 Certificated) EcoFlow DELTA Pro Ultra Whole-Home Backup Power (UL 9540 Certificated) EcoFlow DELTA Pro Ultra Whole-Home Backup Power (UL 9540 Certificated) EcoFlow DELTA Pro Ultra Whole-Home Backup Power (UL 9540 Certificated) EcoFlow DELTA Pro Ultra Whole-Home Backup Power (UL 9540 Certificated) EcoFlow DELTA Pro Ultra Whole-Home Backup Power (UL 9540 Certificated) EcoFlow DELTA Pro Ultra Whole-Home Backup Power (UL 9540 Certificated) EcoFlow DELTA Pro Ultra Whole-Home Backup Power (UL 9540 Certificated) EcoFlow DELTA Pro Ultra Whole-Home Backup Power (UL 9540 Certificated) EcoFlow DELTA Pro Ultra Whole-Home Backup Power (UL 9540 Certificated) EcoFlow DELTA Pro Ultra Whole-Home Backup Power (UL 9540 Certificated) EcoFlow DELTA Pro Ultra Whole-Home Backup Power (UL 9540 Certificated) EcoFlow DELTA Pro Ultra Whole-Home Backup Power (UL 9540 Certificated) EcoFlow DELTA Pro Ultra Whole-Home Backup Power (UL 9540 Certificated) EcoFlow DELTA Pro Ultra Whole-Home Backup Power (UL 9540 Certificated) EcoFlow DELTA Pro Ultra Whole-Home Backup Power (UL 9540 Certificated)
Ends in
Days
  • The only portable power station certified to both UL1973 and UL9540, offering extreme reliability for home use.
  • 7.2-21.6kW output, powerful enough to run your whole home even with a central AC
  • 6kWh-90kWh capacity, whole house backup for weeks with comfort
  • Auto-switchover, prolonged backup, and energy bill savings with EcoFlow Smart Home Panel 2
  • 5 Charging Options, even plan B has a plan B
  • Battery automatically starts self-heating if the temperature is lower than 32℉, allowing the battery to run as normal
*Note: 1) The DELTA Pro Ultra Inverter package does not include a connection cable . To connect a second inverter to SHP2, please purchase the connection cable separately.
Smart Home Panel 2 requires installation before use, and the specific fee will depend on the assessment, and only 'EcoFlow DELTA Pro Ultra + Smart Home Panel 2 + Installation' includes installation services. 2) Rooftop solar charging for DPUX via SHP3/Gateway requires current transformers.
Learn more
Service & Benefits
Installation Service
Step 1: Order Placement
When placing an installation order, please provide your full delivery address and contact details.
T&C:
One-Day Delivery
1. Free Shipping Policy
2. One-Day Delivery
3. One-Day Delivery Regions
Members' Benefits
1. Earn More, Save More: Get 1 EcoCredit per $1 spent – redeem 20 Credits for $1 off anytime, or exchange for exclusive gifts and discounts.
2. Join EcoCredits Monthly Madness: Unlock more EcoCredits fun! Available every 4th Thursday of the month.
3. Bonus Rewards: Earn extra EcoCredits when you refer friends – unlock cash bonuses and special perks.
4. Priority Support: Enjoy 24/7 assistance, extended warranty coverage, and seamless trade-in options.
5. VIP Access: Be the first to shop new products, attend members-only events, and get insider update. Sign up>>
5-Year Warranty
Recommend
EcoFlow Installation Service Installation Service for Smart Home Panel 2 Turnkey Installation Service
Live Installation Support for SHP2/SHP3/Gateway
USD $0
By selecting this service, you agree to EcoFlow Live Installation Support Terms & Conditions (United States)
You acknowledge and consent that the Live Installation Support Service may record the site survey and installation process. Such recordings may capture identifiable images of you or other individuals present at the installation site. These recordings will be used solely for installation documentation and the resolution of any related disputes, and will be retained for no longer than 180 days, after which they will be securely deleted.
USD $0
Check area
Please confirm that installation service is available in your area before making a purchase.
We regret to inform you that our installation services are temporarily unavailable in your area. Please share your information with us for free online technical support or, depending on your location, help accessing on-site installation services.
The installation service is available in your area. Please share your information with us for free online technical support or depending on your location, help accessing on-site installation services
Ecoflow Turnkey Installation Service. Learn More
USD $0
Check area
USD $0
Compare
Expand Your Capacity
Power With Solar
Optimize Your Energy
Selection Summary
EcoFlow DPU-BUNDLE DELTA Pro Ultra + DELTA Pro Ultra Extra Battery (1 × Inverter + 3 × Batteries) EcoFlow DELTA Pro Ultra Whole-Home Backup Power (UL 9540 Certificated)
USD $7,999
USD $7,999
USD $7,999.00
Comparison
DELTA Pro Ultra
DELTA Pro 3
DELTA Pro
Discharging: Pure sine, 7,200W total, 120V/240V~ 60Hz
102.4V⎓60A, 6,144Wh
4kWh
3600Wh
102.4V⎓60A, 6,144Wh
4kWh
3600Wh
240V/30A
240v/20A
120v/15A
240V/30A
240v/20A
120v/15A
AC Input Charging: 100-120V~15A; 200-240V~12.5A, 50/60HzBypass: 100-120V~15A, 50/60Hz (duration < 3hrs when the current exceeds 12A)Solar Charging InputTotal 5600W, 2 portsHigh-PV Input: 80-450V/15A, 4000W MaxLow-PV Input: 30-150V/15A, 1600W Max
AC Charging Input1800W Max, 120V~15A, 3000W Max, 240V~12.5ASolar Charging Input1600W Max, 11-150V, 15A Max
120V AC Output Socket (Backup UPS): 2 x 20A Max per port
120V AC Output Socket (Online UPS): 2 x 20A Max per port
120V AC Output Socket (Online UPS): 1 x 30A Max
120V/240V AC Output Socket (Backup UPS): 1 x 30A Max
Total: 7
4 x NEMA 5-20R, 120V/20A
1 x TT-30, 120V/30A
1 x L14-30, 120V/240V/16.7A
1 x NEMA 6-20R, 240V/16.7A
Total: 7
1 x TT-30, 120V/30A
10ms
10ms
10ms
10ms
Up to 90kWh, 21.6kW
Up to 36kWh, 12kW
Up to 25kWh, 7.2kW
Up to 90kWh, 21.6kW
Up to 36kWh, 12kW
Up to 25kWh, 7.2kW
YES
Auto switchover <20ms when paired with EcoFlow Smart Home Panel 2
YES
NO
YES
YES
NO
Customized Widget Dashboard Third-party Devices Integration Future Electricity Price Analysis Generator Auto Start/Stop Self-Powered TOU Mode Scheduled Tasks API
DashboardThird-party Devices Integration Generator Auto Start/Stop Scheduled TasksAPI
Dashboard
Third-party Devices IntegrationGenerator Auto Start/Stop Scheduled Tasks API
Dashboard
Inverter: 31.7 kg (70 lb)
Battery: 50.7 kg (111.8 lb)
Approx. 51.5 kg
Approx. 45 kg
Approx. 51.5 kg
Approx. 45 kg
Over 12,000 Units installed in U.S. households
EcoFlow DELTA Pro Ultra is a whole-home energy system designed to grow with your family. Integrated with the Smart Home Panel 2, it scales to meet your evolving energy needs - keeping your home powered, intelligent, and secure through every stage of life.
Get the Highlights
Month-long power security.
6-90kWh Capacity
5.6kW-16.8kW Solar Input
Flexible Solar Systems
Rigid Solar System
EcoFlow DELTA Pro Ultra works seamlessly with existing rooftop solar panels, replacing sensitive solar inverters prone to failure. Working in tandem with EcoFlow Smart Home Panel 2, maximize the value of your solar power and cut a chunk of change off your energy bill.
*This information is intended for users who have not installed a solar inverter.
Rigid Solar System
Rigid Solar System
Always in charge
With a Generator or EV pile
Peace Of Mind With An Advanced Design.
EcoFlow X-Cooling
Boost Performance with BMS
EcoFlow X-Cooling
EcoFlow X-Cooling
290V high voltage tolerance
6144Wh, 102.4V⎓60A
30kWh (5 x DPU Battery)
AC Continuous Output
7200W
Expanable Capacity(System*)
90kWh (15 x DPU Battery)
AC Surge Output
10.8kW
Scalability(System*)
21.6kW
IP Rating
IP54
Battery Cycle Life
UPS
DC Output
12.6V⎓30A, 378W Max
2 x 120V, 20A Max per port
1 x 120V/240V, 30A Max
USB-A
1 x 120V, 30A Max
USB-C
AC Input
Inverter Dimension
Inverter Net Weight
31.7 kg (70 lb)
Battery Dimension
Battery Net Weight
50.7 kg (111.8 lb)
5-year warranty
Connection
Bluetooth & Wi-Fi & 4G
Discharging temp
-20°C to 45°C | -4°F to 113°F
Charging temp
Storage temp
Terms & Conditions
Promotion Period
The EcoFlow Prime Day Sale promotion (hereinafter referred to as the 'Promotion Period') begins at 12:00 AM PDT on June 8, 2026, and ends at 11:59 PM PDT on July 3, 2026.
Installation Discount
A. Valid from 12:00 AM PDT on June 8, 2026, to 11:59 PM PDT on July 3, 2026.
B. Customers purchasing Smart Home Panel 3 are eligible for an automatic $900 discount on installation services related to Smart Home Panel 3 on https://us.ecoflow.com/. The discount will be applied automatically at checkout.
C. This Installation Discount is non-stackable with other discounts.
D. Installation Service Scope
VIP Customer Service: VIP support for installation and usage inquiries.
Professional Installation Service: 4-step professional installation process
Installation Service Fee Coverage: The standard Installation Service Fee ONLY covers the installation labor costs. For more installation information, refer to our Installation T&C
Free Sub Panel Removal: We'll remove your existing sub panel at no extra charge.
E. Installation fees are calculated based on the installation ZIP code. Pricing may vary by region and will be reflected at checkout.
⚠ Notice: Rooftop solar charging for DPUX via SHP3/Gateway requires current transformers.
