EcoFlow Smart Home Panel 3 | Whole-Home Energy Control | Smart Home Panel 3 (32 Circuits)
EcoFlow Smart Home Panel 3 (32 Circuits) EcoFlow Smart Home Panel 3 (32 Circuits)
USD $3,299.00
Regular price USD $3,299.00
Sale price USD $3,299.00 Regular price
-$-3,299
  • Command home power center with 32 smart circuits
  • Seamless Backup in <20 ms
  • Smarter Savings up to $6,000/year
  • Extend Backup time by up to 42%
*Note: Smart Home Panel 3 requires installation before use, and the specific fee will depend on the assessment
Recommended
EcoFlow Installation Service Installation Service for Smart Home Panel 2 Turnkey Installation Service
Live Installation Support for SHP2/SHP3/Gateway
USD $0
By selecting this service, you agree to EcoFlow Live Installation Support Terms & Conditions (United States)
You acknowledge and consent that the Live Installation Support Service may record the site survey and installation process. Such recordings may capture identifiable images of you or other individuals present at the installation site. These recordings will be used solely for installation documentation and the resolution of any related disputes, and will be retained for no longer than 180 days, after which they will be securely deleted.
USD $0
USD $3,299
32 Independently Controlled Circuits • 200A Max Current • Supports Split-Phase 120/240V and 120/208V Grids
The Ultimate Whole-Home¹ Power Command Center
EcoFlow Smart Home Panel 3 is a smart electric panel with 32 independently controlled circuits. Fully compatible² with DELTA Pro Ultra X, generators, solar panels, and EV chargers, it delivers a seamless whole-home³ energy experience—with instant, automatic backup during outages.
When Blackout Hits: Lights Stay On
Smart Control, Always Reliable Regardless of Weather
Backup for Your Backup
20 ms Auto Switchover Time
Smart Home Panel 3 switches from grid to battery in under 20 ms—faster than a blink—so your whole home keeps running without interruption.
42% More Backup Time
In the app, categorize your appliances as must-have or nice-to-have. Critical loads stay on, while non-essentials automatically scale back—extending runtime by up to 42%.
Seamlessly Compatible with High-Power Generators⁴
Build a multi-source backup system with DELTA Pro Ultra X and your generator. Just connect your split-phase generator to Smart Home Panel 3 via its 5+8 port—no rewiring or extra hardware—and power your home while charging your battery.
Turn Sunlight Into Savings, No
Watt Wasted
For DIY solar, Self-Powered For Your Home
Track and Use Every Solar Watt
Pair Smart Home Panel 3 with DELTA Pro Ultra X for true self-power. Once the battery reaches your set reserve, surplus solar flows directly to home appliances—free solar first, cheaper power all day, backup ready at night.
Paired with a Current Transformer, Smart Home Panel 3 tracks your rooftop generation in real time and directs surplus solar to your DELTA Pro Ultra X. No more waste, no more pennies to the grid.
Smart Saving with AI Mode
Slash Bills with Your PowerPulse
Based on TOU peak/off-peak rates, solar forecasts your energy habits, AI TOU manages battery charging and discharging for the lowest-cost power. Before a rainy day, it fills the battery with free solar or cheap off-peak power, letting you bypass peak rates automatically.
AI charging shifts to solar by day and off-peak rates by night, keeping your EV always ready. If your EV consumes 10 kWh per day, this system can save you up to $1,095 annually—equivalent to a full year of free commuting.
The Fastest Installation⁶
7 Days, 3 Steps
DAY 1 – Installer Match
DAY 2–6 – Site Visit⁷
DAY 7 – One-Day Installation⁸
After your order, we’ll match you with an EcoFlow Authorized Installer. Nationwide coverage—from sunny California to snowy Maine.
*7‑Day Installation counts from permit issuance (after purchase & delivery) until on‑site installation is complete.
Your installer will assess your home and plan installation.
Smart Home Panel 3 is wired, the EcoFlow app is set. We provide end-to-end support, ensuring everything is safe, running, and ready to use.
Resilient in Extremes, Reliable for a Decade
–30℃ to 50℃ Operation⁵
Whether in extreme heat or freezing winters, Smart Home Panel 3 safeguards your power security.
10 Years
Enjoy complete confidence with a 10-year warranty.
Split design, Hassle-Free Install
What's in the box?
88.8±0.4lb(40.3±0.2kg)
Dimensions (HWD)
365*188*1150mm(14.37*7.40*45.28in.)
Number of load branches
32
Overvoltage Category
IV
Rated Input Voltage (V)
120/240V, 120/208V, 60Hz
Maximum Continuous Input Current (A)
160A
Enclosure Protection
NEMA 3R
Operating Temperature Range
-30~50℃ (-22~122℉)
Storage Temperature Range
-30~50℃ (-22~122℉)
Maximum Operating Altitude
≤3000m (9842.52ft)
Branch Circuit Rated Current
90A*8 circuits output 60A*24 circuits output
Noise Emission
≤40dB
Certificates
UL67, UL869A, UL916, UL1741
10 years
Communication Method
Bluetooth/Wi-Fi/Ethernet/CAN/RS485
EMC
FCC Part 15B
FCC Part 15C
Main circuit power detection accuracy
0.5%
Sub circuit power detection accuracy
1%
Ecologically compatible products
EcoFlow DELTA Pro Ultra Inverter/EcoFlow DELTA Pro Ultra X Inverter/PowerPulse EV Charger
Which EcoFlow Portable Power Stations does the Smart Home Panel 3/Smart Gateway support connecting to? Does it support the DELTA Pro 3?
Currently, it only supports connecting the DELTA Pro Ultra X via the EcoFlow Smart Inlet Box Connection Cable (5P8 Port to 5P8 Port) or connecting the DELTA Pro Ultra to the Smart Inlet Box (Smart Home Panel 2 Upgrade) via the EcoFlow Power Input/Output Cable. You can also connect the DELTA Pro Ultra X and the DELTA Pro Ultra simultaneously using the cables that meet the corresponding requirements.Currently, it does not support connecting the DELTA Pro 3. For future updates, please refer to the official information.
Will the Smart Home Panel 3/Smart Gateway send the power from the Backup Battery back to the power grid? Will it affect the use of the existing photovoltaic system?
No, the Smart Home Panel 3/Smart Gateway is not a grid-connected system. The power of the Backup Battery will only be supplied to the branch circuits inside the system and the Sub-Panel connected to the Smart Gateway, and will not be output to the power grid.The Smart Home Panel 3/Smart Gateway only indirectly utilizes the existing photovoltaic system and will not affect its original functions.
What types of Generators does the Smart Home Panel 3/Smart Gateway support for use as Backup Power, and do I need to purchase any accessories?
It supports 3 - 12kW split - phase 240V generators. Connect it to the AC1 - 5p8/GEN IN port of the Smart Inlet Box (Smart Home Panel 2 Upgrade) via the EcoFlow AC Generator Charging Adapter (NEMA L14 - 30P to 5P8 Port) (allowing the generator to generate 3 - 7.2kW) or the EcoFlow Generator Charging Adapter (NEMA 14 - 50P to 5P8 Port) (allowing the generator to generate 3 - 12kW). In addition, we need to remind you that you must connect at least one DELTA Pro Ultra X/DELTA Pro Ultra to the AC2/3 port of the Smart Inlet Box for the generator to generate electricity.
What are the maximum rated current and peak current of the mains input allowed by the Smart Home Panel 3/Smart Gateway respectively?
Rated current: 160A; Peak current: 200A
What is the waterproof rating of the Smart Home Panel 3/Smart Gateway? Can it be installed outdoors?
The protection level of the Smart Home Panel 3/Smart Gateway is NEMA 3R, which is waterproof and can be installed indoors or outdoors.However, the Smart Inlet Box (Smart Home Panel 2 Upgrade) used in conjunction with it has a protection level of NEMA 1, is not waterproof, and can only be installed indoors.
What is the EPS mode of the Smart Home Panel 3/Smart Gateway? Can it be enabled simultaneously with the Operating modes: AI Mode, Self-powered, and Scheduled tasks?
Enabling the EPS mode allows the system to switch to the powered-on Backup Battery within 20ms during a power outage, reducing the impact of power outages on the important loads in your home.
*Note that for the EPS to take effect within 20ms, only the powered-on DELTA Pro Ultra X should be included in the connected Backup Battery.
*When the DELTA Pro Ultra is connected, the EPS mode and Operating modes cannot be enabled simultaneously; and if the DELTA Pro Ultra is in the charging state under EPS mode, it cannot switch to the DELTA Pro Ultra for power supply within 20ms at the moment of a power outage.
Does the Smart Home Panel 3/Smart Gateway support 5G WiFi connection?
It is not supported. Only 2.4G WiFi is supported when connected via WiFi.
Does the Smart Home Panel 3/Smart Gateway only support household electricity of 120/240V~ (split phase)? My apartment uses commercial electricity of 208Y/120V~, 3W (from 3Ø 4W). Can it be used?
The Smart Home Panel 3/Smart Gateway supports household electricity of 120/240V~ (split phase) and commercial electricity of 208Y/120V~, 3W (from 3Ø 4W). You just need to ask your electrician to find the corresponding live wire, connect the wires according to the Installation Guide, and select the corresponding voltage in the Grid Setting of the APP.
Who can install the Smart Home Panel 3/Smart Gateway?
The Smart Home Panel 3/Smart Gateway must be installed by EcoFlow authorized installers and licensed electricians, and the installers must have successfully completed the EcoFlow product training. If you are interested in contacting an authorized installer, please select the Installation Service when making a purchase. If you already have installers but they haven't obtained the relevant materials for installing EcoFlow products, please go to Support->User Manual on the EcoFlow official website and download the latest Installation Guide for the corresponding product so that they can start learning and performing the installation.
How long does it take to install the Smart Home Panel 3/Smart Gateway?
The installation time of the Smart Home Panel 3/Smart Gateway may vary depending on the scope of work required and the current wiring configuration of your home. For most households, the Smart Home Panel 3 can be installed within 10 hours, and the Smart Gateway can be installed within 6 hours.
How many years is the warranty for the Smart Home Panel 3/Smart Gateway?
The warranty period for the Smart Home Panel 3/Smart Gateway is 10 years. For specific warranty terms, please refer to the "Warranty Service" Card inside the packaging box.
How does the EcoFlow Smart Home Panel 3/EcoFlow Smart Gateway help save money?
When your system is equipped with solar panels or your household electricity price has peak and off-peak periods, you can choose AI Mode or Self-powered Mode according to your household situation. Charge the battery during low electricity price periods or when *solar energy is predicted to be available, and use the battery to power your home during high electricity price periods or when there is redundant solar energy. In addition, you can also use the Smart Circuit Settings to turn on/off some circuits with high standby power consumption at a scheduled time, and only run them when necessary.*Solar forecast requires subscribing to the professional feature package - Energy Master. For specific subscription rules and feature details, please refer to the latest information in the APP.
Which circuit breakers are compatible with Smart Home Panel 3/Smart Gateway?
The Smart Home Panel 3/Smart Gateway is compatible with industry-standard single-pole and double-pole circuit breakers. For specific Main Circuit Breakers and Branch Circuit Breakers, please refer to the Circuit Breaker Compatibility section in the Installation Guide.
Is it necessary to drill holes on the Smart Home Panel 3/Smart Gateway to reserve an entry for the cables during installation?
There are already 5 knockouts reserved on the body of the Smart Home Panel 3/Smart Gateway. If you still need more cable holes, it is recommended that you use a hydraulic hole puncher and keep the plastic protective cover inside the machine in place during the punching process to prevent iron filings and other debris from damaging the machine during the process.
Can the Smart Home Panel 3/Smart Gateway be used as a Sub-Panel in the home?
Yes, but please note that when used as a Sub-Panel, you need to remove the Main bonding jumper between the Main neutral terminal and the Main ground terminal.
If my local electrical regulations require me to install an external emergency stop switch [EPO] when installing the Smart Home Panel 3/Smart Gateway, how should I meet this requirement?
Both the Smart Home Panel 3 and the Smart Gateway have an EPO port reserved inside the product. When you have a need, you can optionally purchase an Emergency Power Off Button when buying the main product and install it according to the Installation Guide in the Support -> User Manual on the official website.
If my local electrical regulations require me to have an overcurrent protection device [OCPD] between the Smart Home Panel 3 or Smart Gateway and the Backup battery storage, where should I install it?
You can install an overcurrent protection device [OCPD] in the middle of the Smart Inlet Box Connection Cable (5P8 Port to 5P8 Port). The actual OCPD specifications shall comply with your local electrical regulations. We recommend that you use a 70A 2P circuit breaker.
Does the use of Smart Home Panel 3 or Smart Gateway have any requirements for the APP version?
You need APP version ≥ 6.8.5 to add Smart Home Panel 3 or Smart Gateway to the APP for use.
