Buy EcoFlow DELTA Max Portable Power Station - DELTA Max (2000) - EcoFlow US
EcoFlow US
USD $1,599.00
Hot
Hot
Regular price USD $1,599.00
Sale price USD $1,599.00 Regular price $2,099.00
-$500
Limited Offer! Buy DELTA Max & Get Home Backup Kit for only $1,699 by using this coupon code "DMHOMEBACKUP" . (Offer valid while stocks last)
The generator cord will be shipped separately and is estimated to start shipping in July.
• 2-6kWh expandable capacity for home backup
• Power heavy-duty devices with 2400W output
• Charge 0-80% in just 65 minutes
• Solar charge in as fast as 2.5 hours
• Up to 3400W fast dual charging
• Smart app control
Accessories
EcoFlow 220W Bifacial Portable Solar Panel
USD $549 USD $649
23% Conversion Rate | IP68
EcoFlow 160W Portable Solar Panel
USD $299 USD $449
21-22% Conversion Rate | IP68
USD $549 USD $649
USD $299 USD $449
USD $1,599 $2,099 -$500
Unleash Your Capacity
Home power security Home power security
Home power security
DELTA Max’s large 2kWh capacity keeps your home appliances running during a blackout. Expand up to 6kWh with Extra Batteries for several days of reliable backup power.
Fast charging speeds Fast charging speeds
EcoFlow’s patented X-Stream AC fast charging lets you recharge DELTA Max in only 1.8 hours. Or even quicker if you combine any two charging methods, that’s from an AC wall outlet, solar panels, or a Smart Generator.
Power 99% of essential appliances
DELTA Max powers almost all the devices you need with a large 2400W AC output.Using 3400W X-Boost mode, power even high-wattage appliances without overloading.
Emergency backup Emergency backup
Emergency backup
In the most extreme cases, use the EcoFlow Smart Generator to efficiently recharge using DC. Once DELTA Max hits a low battery level, the Smart Generator kicks in automatically, fully recharging your battery.
Harness the power of the sun Harness the power of the sun
Collect up to 800W of sustainable solar energy to keep DELTA Max running even when there’s an outage. With an advanced MPPT (maximum power point tracking) algorithm, DELTA Max auto-regulates, maintaining optimal solar generation throughout the day.
Monitor & control from the EcoFlow app Monitor & control from the EcoFlow app
Take control of your DELTA Max and quick-view stats right from your phone. Customize settings such as charging speeds and Smart Generator auto-start levels to fit your power needs.
Reliable BMS Reliable BMS
Reliable BMS
EcoFlow’s battery management system analyzes DELTA Max’s vitals in real-time, regulating voltage, current, and temperature. BMS keeps DELTA Max safe and efficient, maintaining its life for years to come.
Power your essential appliances with 2000W huge ACoutput by directly connecting the DELTA Max with Transfer Switch and a Power Cord for partial home backup. With a plug-and-play design, it's easier than ever to prepare for blackouts.
Expandable home backup power.
DELTA Max charges up safely and rapidly from 0-80% in just 65 minutes. And it gets even better. If you’re looking for an even faster way to charge up DELTA Max, you can combine AC with the smart generator to get up to 3400W, AC with solar to get up to 2600W, or the Smart Generator with solar to get up to 2600W.*
With EcoFlow’s X-Boost technology, DELTA Max can power heavy-duty devices up to 3400W. That means during a power outage or blackout, you can continue to power your fridge, dryer, and more. That’s the industry gold standard for a portable power station of this size and capacity.
Harness the power of the sun.
DELTA Max connects with up to 2x 400W EcoFlow solar panels to deliver 800W Max solar charging speeds. With a voltage range from 11-100V and the Solar connector, you can also connect other solar panels to your DELTA Max. Even during cold or cloudy days, our smart maximum power point tracking (MPPT) algorithm automatically detects voltage and current in real time to give you optimum solar generation throughout the day.
Emergency backup power.
Multiple ways to charge.
There are multiple ways to charge DELTA Max wherever you are. If you’re at home, plug into an AC wall outlet or solar panels. If you’re out and about, charge DELTA Max in your car or use solar panels if you’ve set up camp. In extreme emergencies during power outages, connect the DELTA Max to the Smart Generator for a last-standing power source.
AC Charging
Solar Generator
Car Charging
How many solar panels can I use at the same time with DELTA Max?
It depends on the total voltage and watts of solar panels you choose. As long as the solar panels use MC4 connector and its voltage and current are under 11-100V, 13A max range.
What's the max input for DELTA Max?
When charging DELTA Max and its extra battery together, you can reach 3600W max charging speeds by combining any two methods of AC, solar and Smart Generator. For DELTA Max single unit, you can recharge it at standard wall outlets (1800W max), or combine AC and solar charging to reach max 2000W charging speeds.
How does the Emergency Power Supply (EPS) work? And how fast is it?
When your portable power station is plugged into the wall, any electronics plugged into it are powered from the grid and not its battery. When power from the grid stops, as in a blackout, the power station automatically switches to battery power within 30ms.
What's the water-resistance rating for this product?
DELTA Max is not water-resistance, so it should be kept away from liquids. Or if you're looking for water-resistance solution, you can purchase the DELTA Max case to water-resistance protection.
Specs of DELTA Max (2000)
2016Wh
Extra Battery
Support up to two DELTA Max Smart Extra Battery/Smart Generator
6 outlets, 2400W total (Surge 5000W)
3400W
USB-A Fast Charge
Car Power Output
12.6V, 10A, 126W Max
DC5521 Output
AC Charging Input
1800W Max, 15A
Solar Charging Input
800W Max, 11-100V, 13A
Car Charging Input
Support 12V/24V battery, 8A
NCM
800 cycles to 80% capacity
Connection
Wi-Fi
Approx. 48lbs
Dimension
19.6*9.5*12 in
Specs of DELTA Max (1600)
1612Wh
Extra Battery
6*20A outlets, 2000W total (Surge 5000W)
2800W
USB-A Fast Charge
Car Power Output
DC5521 Output
AC Charging Input
1600W Max, 15A
Car Charging Input
NCM
500 cycles to 80% capacity
Connection
Wi-Fi
Approx. 48lbs
Dimension
19.6*9.5*12 in
*DELTA Max needs to be connected to the DELTA Max Smart Extra Battery for dual charging.
