EcoFlow DELTA Max + 160W Portable Solar Panel - DELTA Max (2000) / 4*160W - EcoFlow US
EcoFlow US
USD $2,799.00
Regular price USD $2,799.00
Sale price USD $2,799.00 Regular price $3,895.00
-$1,096
  • Generates up to 3.5kWh to 4kWh daily.
  • 2800W to 3400W AC output with X-Boost.
  • A high conversion rate guarantees a fast solar charging speed: 0-100% in 3-4 hours (4 sets), 4-5 hours (3 sets) and 6-8 hours (2 sets).
  • IP68 dust and water resistance.
  • Smart remote control with EcoFlow app.
  • 3-year warranty for DELTA Max and 12-month warranty for 160W Portable Solar Panel.
**DELTA Max and 160W Portable Solar Panel will be shipped separately.
Shipment services to Alaska, Puerto Rico, and Hawaii are temporarily suspended.
Model
Number of Solar Panel
USD $2,799 $3,895 -$1,096
Expandable Capacity
Dual Charging
Power Multiple Devices
800W max Solar Input
Expandable home backup power.
DELTA Max charges up safely and rapidly from 0-80% in just 65 minutes. And it gets even better. If you’re looking for an even faster way to charge up DELTA Max, you can combine AC with the smart generator to get up to 3400W, AC with solar to get up to 2600W, or the Smart Generator with solar to get up to 2600W.*
With EcoFlow’s X-Boost technology, DELTA Max can power heavy-duty devices up to 3400W. That means during a power outage or blackout, you can continue to power your fridge, dryer, and more. That’s the industry gold standard for a portable power station of this size and capacity.
Harness the power of the sun.
DELTA Max connects with up to 2x 400W EcoFlow solar panels to deliver 800W Max solar charging speeds. With a voltage range from 11-100V and the Solar connector, you can also connect other solar panels to your DELTA Max. Even during cold or cloudy days, our smart maximum power point tracking (MPPT) algorithm automatically detects voltage and current in real time to give you optimum solar generation throughout the day.
Emergency backup power.
Learn More >
Multiple ways to charge.
What's in the bundle - DELTA Max
1.DELTA Max 2.AC Charging Cable 3.Car Charging Cable 4.DC5521 to DC5525 cable 5.User Manual
It depends on the total voltage and watts of solar panels you choose. As long as the solar panels use MC4 connector and its voltage and current are under 11-100V, 10A max range.
When charging DELTA Max and its extra battery together, you can reach 3600W max charging speeds by combining any two methods of AC, solar and Smart Generator. For DELTA Max single unit, you can recharge it at standard wall outlets (1800W max), or combine AC and solar charging to reach max 2000W charging speeds.
When your portable power station is plugged into the wall, any electronics plugged into it are powered from the grid and not its battery. When power from the grid stops, as in a blackout, the power station automatically switches to battery power within 30ms.
DELTA Max is not water-resistance, so it should be kept away from liquids. Or if you're looking for water-resistance solution, you can purchase the DELTA Max case to water-resistance protection.
Specs of DELTA Max
2016Wh
6 outlets, 2400W total (Surge 5000W)
DC5521 Output
Solar Charging Input
800W Max, 11-100V, 13A
NCM
Approx. 48lbs
Extra Battery
Support up to two DELTA Max Smart Extra Battery/Smart Generator
3400W
USB-A Fast Charge
Car Power Output
12.6V, 10A, 126W Max
AC Charging Input
1800W Max, 15A
Car Charging Input
Support 12V/24V battery, 8A
800 cycles to 80% capacity
Connection
Wi-Fi
Dimension
19.6*9.5*12 in
Specs of 160W Solar Panel
Unfolded Dimensions
61.8 × 26.8 × 1.0 in (158 × 51.4 × 2.4 cm)
Folded Dimensions
16.5 × 26.8 × 1.0 in (42 × 51.4 × 2.4 cm)
Weight
15.4 lb (Solar Panel 11 lb)
12 months
Rated Power
160W(±5W)
Efficiency
21%–22%
Connector Type
Solar Connector
Open Circuit Voltage
21.4V (Vmp 18.2V)
Short Circuit Current
9.6A (Imp 8.8A)
Cell Type
Monocrystalline Silicon
Operating & Storage Temperature
−4°F to 185°F
