EcoFlow WAVE 2 + EcoFlow DELTA 2 Max - / - EcoFlow
EcoFlow WAVE 2 + EcoFlow DELTA 2 Max EcoFlow WAVE 2 + EcoFlow DELTA 2 Max
USD $3,099.00
Regular price USD $3,099.00
Sale price USD $3,099.00 Regular price $3,267.00
-$168
WHY THIS BUNDLE
Runs up to 14 hours
 Runs even longer with 100% clean energy (with 400W Portable Solar Panel)
DELTA 2 Max
• Expandable capacity - 2-6kWh expandable capacity to fit your energy storage needs. Add up to two DELTA 2 Max Smart Extra Batteries to hit a capacity of 6144Wh. Ideal for home backup, RVing, outdoors or even everyday use.
• Built to last 6× longer - Get 10 years of daily use until hitting 80% of its original capacity. That’s down to its LFP battery chemistry giving you 3000+ cycles.
• Huge AC output - With X-Boost mode get up to 3400W output power to run 99% of home appliances. Power 15 devices at once including 6 AC outlets.
•Fastest recharging - World's fastest AC recharging and X-Stream dual AC+Solar charging speeds. Up to 1000W solar input to charge in as fast as 2.3 hours.
WAVE 2
• Fastest cooling and heating
• Installation-free! Fits anywhere
• 8 hours of comfort
• 44dB: Perfect for quiet sleep
• Using R290: A greener way to beat the heat
• 4 ways to charge
Solar Panel
USD $3,099 $3,267 -$168
Citi Pay® Credit – Special financing available. Learn More
Citi Pay® Credit Badge Citi Pay® Credit. Special financing available
Experience up to 14 hours of cooling or heating with power from DELTA 2 Max
Fastest Cooling & Heating
The world's first wireless portable AC with heater.EcoFlow's tailor-made compressor enables WAVE 2 to provide 5100 BTUs of cooling and 6100 BTUs of heating. Get ready for the ultimate comfort with WAVE 2!
Installation-free, Fits anywhere
Ideal for any compact space. Simple to use, with no installation or drainage* hassle. Includes air ducts to fit your tent, van or other small space. Experience the convenience of cooling and heating without any fuss.
Durable, Safe, Lightweight
LFP Battery Chemistry
Advanced BMS Protection
Robust Design
Upgraded Tech, Lighter Weight
Power pretty much anything with up to 3400W Output
DELTA Max powers almost all the devices you need with a large 2400W AC output. With X-Boost proprietary technology, run appliances with an output of up to 3400W. Compared with similar portable power stations, DELTA 2 Max can power more devices while also preventing overloading and overheating.
120V Home Backup: Power through outages
Power your essential appliances with a hefty 2400W AC output by connecting DELTA 2 Max (2kWh) and up to two Smart Extra Batteries (6kWh) with your home's transfer switch for partial home backup. With a plug-and-play design, it's easier than ever to prepare for blackouts.
Power for the entire family
2048Wh Capacity
Home Backup
RVing & Outdoors
DIY Projects
Filmmaking & Photography
Expandable up to 6kWh
Triple the power
Fuel Up 80% in Only 43 Mins*
With DELTA 2 Max's upgraded tech, combine up to 1000W solar input with AC for world-leading charging speeds. In only 43 min get an 80% charge. Or stick with AC for an 80% charge in a speedy 1.1 hour.
Take control of your power
Smart Automatic Control
AC Always-on
Energy Management
Low Battery Reminder
Save more on electricity billsCustomize the working time of DELTA 2 Max to avoid peak rates.
Experience peace of mind during power outages With our all-new AC Always On Mode, the AC power button stays on, even during a power outage or after the grid power is back, keeping your appliances powered no matter what.
Easily adjust power Easily adjust AC or Solar input to fit your needs: backup power reserve or energy savings.Prioritize solar energy input via the EcoFlow app when using X-Stream AC + solar dual charging.
Always power readyGet a notification via the app when the battery hits a low.
Extensive 5-Year Warranty
As Quiet as 30 dB
Peaceful charging
DELTA 2 Series
Learn More About DELTA 2
