Choose another country or region to see content specific to your location and shop online.
Canada
China
Germany
Japan
Korea
Italy
Spanish
EcoFlow RIVER Pro + 110W Portable Solar Panel
100% secure shopping
Reliable warranty
Free shipping
Regular price
$749.00
Sale
$749.00
Regular price
$1,049.00
Sold out
per
Number of Solar Panel
  • 1
View cart
TO DOUBLE THE CAPACITY OF RIVER Pro,CLICK HERE RIVER Pro EXTRA BATTERY
The EcoFlow RIVER Pro is a compact, portable power station that is built for taking your adventure into the great outdoors. Whether you are camping, over-landing, tailgating, or boating, the RIVER Pro provides reliable power that lets you take your adventure anywhere.
  • 3 x 600W AC OUTLETS AND 720Wh CAPACITY
  • RECHARGE FROM 0-80% WITHIN 1 HOUR
  • DOUBLE CAPACITY FROM 720Wh to 1440Wh
  • POWER A WIDE RANGE OF APPLIANCES
Stay off the grid with EcoFlow 110W Solar Panel Charger. Made up of efficient monocrystalline silicon cells,  it can recharge DELTA and your electric devices, and keep your equipment running without interruption when connected to our portable power station.
  • COMPATIBLE WITH MOST GENERATORS
  • UPGRADE HIGH EFFICIENCY
  • PORTABLE & FOLDABLE KICKSTAND PANEL
*Please NOTE: This item is only applicable to orders in the US mainland states(except Hawaii, Alaska, Virgin Islands and Puerto Rico).
Customer reviews
4.0 563 Reviews
  • 5 star
    75%
  • 4 star
    60%
  • 3 star
    10%
  • 2 star
    8%
  • 1 star
    1%
Reliable warranty
Free shipping
Step into the wild with a massive 720Wh of battery capacity. RIVER Pro is the powerhouse for your off-grid adventure. Keep multiple devices powered on at once and recharge in record times via car, solar, or standard AC outlets.
X-Stream Fast Charge
Expandable Capacity
X-Boost Output
Power Multiple Devices
The Centerpiece of Your Adventure
Power up to 10 devices at once with all the ports you’ll need.
So Much More Sun
32 premium monocrystalline silicon cells provide a high conversion efficiency of 22%. Recharge even faster by chaining multiple panels in series or in parallel.
Better Together
Recharge freely and naturally when you link EcoFlow’s 110W Solar Panel to a RIVER Pro portable power station.
Compare The Models
RIVER Max
Capacity:576Wh
Life Cycles: 500+ Cycle
Output: 600W (Surge 1200W)
AC Input: 500W Max
Solar Input: 200W
$599
RIVER Pro
Capacity:720Wh
Life Cycles: 800+ Cycle
AC Input: 660W Max
Solar Input: 200W
$649
DELTA
Capacity:1260Wh
Output: 1800W (Surge 3300W)
AC Input: 1200W Max
Solar Input: 400W
$1399
Yes. You can control RIVER Pro using your phone. Just link to it in the EcoFlow app to control it from afar.
Yes. RIVER Pro can power devices up to 1800W with our proprietary technology, X-Boost. *X-Boost can run devices that require up to 1800W, however, it’s best to test before use. Some 600W–1800W appliances with strict voltage requirements may not function (e.g. air compressors).
Yes. You can connect up to 2 sets of 110W solar panels to sustainably charge your RIVER Pro in under 3 hours.
It can be an emergency power source (EPS), which will have the same result as UPS for most electronics. Here's the difference. When your RIVER Pro is plugged into the wall, anything plugged into it gets power from the grid, not its battery. If power from the grid stops, RIVER Pro automatically switches to its battery supply mode within 30 milliseconds. That means anything connected will not have power for 30 milliseconds, which may mean sensitive electronics like desktop computers and data servers turn off. Test your devices individually to see if they need UPS to stay powered.
Increase the efficiency of your solar panel by facing it directly at the sun without any obstructions. Remember to be careful when handling your solar panel because damaged cells provide less power.
Yes, if the only thing between it and the sun is transparent, but it won’t charge as well compared to being outside. You can compare the difference by looking at the input section of your power station’s LCD screen.
Specs of RIVER Pro
16.8 lbs (7.6kg)
11.4 x 7.1 x 9.3in (28.9 x 18.0 x 23.5cm)
Charge Temperature
32 to 113°F +/- 5°F (0 to 45°C +/- 3°C)
Discharge Temperature
-4 to 113°F +/- 5°F (-20 to 45°C +/- 3°C)
Color
Black
24 months
Charging Method
AC Wall Outlet, 12V Car Adapter, Solar Panel(s)
Full Recharge Time
1.6 Hours (AC) 8 Hours (12V Car Adapter) 4-8 Hours (Using 2x 110W Solar Panels in parallel with direct sunlight) 6-12 Hours (Using 1x 160W Solar Panel with direct sunlight)
720Wh (28.8V)
Cell Chemistry
Lithium-ion
Shelf Life
1 year (once fully charged)
800 cycles to 80%+ capacity
Management Systems
BMS, Over Voltage Protection, Overload Protection, Over Temperature Protection, Short Circuit Protection Low Temperature Protection, Low Voltage Protection, Overcurrent Protection
Testing and Certifications
UL Standard, CE, FCC, RoHS, RCM
AC Charge Input Power
X-Stream Charge 660W Max
AC Charge Input Voltage
100-120Vac (50Hz/60Hz)
Solar Charge Input
200W 10-25Vdc 12A Max
Car Charger
12Vdc 8A Max
AC Output (x3)
600W (Surge 1200W) total, 120Vac ( 50Hz/60Hz)
USB-A Output (x2)
5Vdc, 2.4A, 12W Max per port
USB-A Fast Charge (x1)
5V/2.4A,9V/2A,12V/1.5A 18W Max
USB-C Output (x1)
5Vdc, 9Vdc, 12Vdc, 15Vdc, 20Vdc, 5A, 100W Max
Car Power Output (x1)
136W, 13.6Vdc, 10A Max
DC5521 Output (x2)
13.6Vdc, 3A Max per port
Specs of 110W Solar Panel
Weight
13.2 lb (Solar Panel 8.8 lb)
Unfolded Dimensions
62.5 × 20.2 × 1.0 in (158 × 51.4 × 2.4 cm)
Folded Dimensions
16.5 × 20.2 × 1.0 in (42 × 51.4 × 2.4 cm)
12 months
Rated Power
110W (±5W)
Efficiency
21%–22%
Connector Type
Solar Connector
Open Circuit Voltage
21.7V (Vmp 18.5V)
Short Circuit Current
6.3A (Imp 6.0A)
Cell Type
Monocrystalline Silicon
Operating & Storage Temperature
−4°F to 185°F
The RIVER Pro Extra Battery is sold separately.
The EcoFlow RIVER Max features the RIVER power station plus an Extra Battery, which doubles up the battery capacity and offers you reliable, portable, and easy-to-access power wherever you are.
X-Boost Technology
The EcoFlow X-Boost technology gives you the ability to use the 600W inverter to power essential devices like kitchen appliances and tools up to 1800W. This unique technology is perfect for outdoor adventures when you need to power your favorite devices on the go. Please conduct full test on a case-by-case basis to confirm the X-Boost feature works with your appliances. Use X-Boost with devices below 1200W for the best product experience.
X-Stream Charging Technology
EcoFlow’s X-Stream technology offers one of the fastest recharging rates for a power station on the market. With the built-in smart inverter, EcoFlow RIVER Max can recharge from 0-80% within 1 hour, achieving a full charge in just 1.6 hours.
Modular Design + Extra Battery
The EcoFlow RIVER Max features a compact, modular design that allows you to attach an extra battery to double the capacity of the device from 288Wh to 576Wh. Alternatively, you can detach the Extra Battery to make the device more portable. Whether you’re with family or going on a solo road trip, the modular design gives you all the freedom to customize your power options however you like.
Power 10 Devices Simultaneously
EcoFlow RIVER Max fits many types of the ports you’ll need to charge all your devices. The 100W USB-C is perfect for charging laptops while the full sine wave AC outlets give you more flexibility in charging heavy duty devices. With the informative EcoFlow APP, you can control and monitor the unit on your hands.
Efficient Solar Power
The EcoFlow RIVER Max is also compatible with the EF Solar Panels, which provide you with a way to generate clean, reliable solar power on the go. Two 110W Solar Panels can be connected in parallel to charge the EcoFlow RIVER Max from 3-6 hours.
Easy-to-Carry Handle
Introducing the future of portable power stations. EcoFlow RIVER Max weighs 17lbs, is exceptionally durable, and features an easy-to-carry handle. This incredibly portable power station can be taken around wherever you go, whether that be on your car trunk, coffee table, or the great outdoors. It’s that easy.
Power a Wide Range of Devices
The RIVER Max comes with three AC outlets. (Note that the total rated wattage of the three AC outlets is 600W (surge 1200W)). With a built-in 600W inverter, the RIVER Max can power devices up to 1800W with the X-Boost mode on. This provides support for a wide range of essential devices such as a fridge, TV, laptop, hairdryer, and more.
Note: It is not recommended to use the RIVER series power station to power heavy-duty devices e.g., air conditioners, ovens or washing machines.
Warning: DO NOT use RIVER series portable power station AC charging cables on DELTA series power stations. EcoFlow takes no responsibilities for any damages caused by customers' failure to follow instructions. Doing so will void the warranty.
What EcoFlow RIVER Max Can Power?
*The duration and times of the appliances indicated in this table are for reference only.
Specifications
General Info
Net Weight*17 lbs (7.7kg)
Dimension*11.4 x 7.3 x 9.3 in (28.9 x 18.4 x 23.5 cm)
Charge Temperature32-113°F +/- 5°F (0-45°C +/- 3°C)
Discharge Temperature-4-113°F +/- 5°F (-20-45°C +/- 3°C)
Color Cyber Black
Warranty24 months
Charging
Charge MethodAC Wall Outlet, 12V Car Adaptor, Solar Panel
Full Recharge Time1.6 Hours (AC)
6.5 Hours (12/24V Car Adaptor)
3-6 Hours (Using 2x110W Solar Panels in parallel with full sun)
4.8-9.6 Hours (Using 1x160W Solar Panel with full sun)
Battery Info
Capacity576Wh (28.8V)
Cell ChemistryLithium-ion
Shelf Life1 year (after fully charging the device)
Cycle Life500 Cycles to 80%+ capacity
Management SystemsBMS, Over Voltage Protection, Overload Protection,
Testing and certificationUL Standard CE FCC RoHS RCM
Input Ports
AC Charge Input PowerX-STREAM Charge 500W max
AC Charge Input Voltage100-120Vac(50Hz/60Hz) International Version 220-240Vac(50Hz/60Hz)
Solar Charge Input200W 10-25V DC 12A Max
Car Charger12V DC 8A Max
Output Ports
AC Output (x3)600W (Surge 1200W) total,120Vac( 50Hz/60Hz)
USB-A Output (x2)5V DC,2.4A,12W Max, per port
USB-A Fast Charge (x1)5V DC,9V DC,12V DC,2.4A,28W Max
USB-C Output (x1)5V DC,9V DC,12V DC,15V DC,20V DC,5A,100W Max
Car Power Output (x1) 136W, 13.6V DC, 10A Max
DC5521 Output (x2)13.6V DC, 3A Max, per port
EcoFlow RIVER Max Portable Power Station
ProductQuantity
EcoFlow RIVER MaxX 1
DC5521-DC5525 CableX 1
1.5m MC4 to XT60 Solar Charging Cable
X 1
1.5m AC Charging Cable
X 1
1.5m Car Charging Cable
X 1
User ManualX 1
User Manual
  • Click to Download EcoFlow RIVER Max User Manual
