![Load image into Gallery viewer, EcoFlow US 2kw EcoFlow Power Kits(Independence Kit) + Smart Generator (Dual Fuel)](http://us.ecoflow.com/cdn/shop/products/ecoflow-us-ecoflow-power-kits-independence-kit-smart-generator-dual-fuel-2kw-30069028585545_400x@2x.png?v=1668501807)
![Load image into Gallery viewer, EcoFlow US 4kw EcoFlow Power Kits(Independence Kit) + Smart Generator (Dual Fuel)](http://us.ecoflow.com/cdn/shop/products/ecoflow-us-ecoflow-power-kits-independence-kit-smart-generator-dual-fuel-4kw-30069028618313_400x@2x.png?v=1668501811)
![Load image into Gallery viewer, EcoFlow US 5kw EcoFlow Power Kits(Independence Kit) + Smart Generator (Dual Fuel)](http://us.ecoflow.com/cdn/shop/products/ecoflow-us-ecoflow-power-kits-independence-kit-smart-generator-dual-fuel-5kw-30069028520009_400x@2x.png?v=1668501814)
![Load image into Gallery viewer, EcoFlow US 10kw EcoFlow Power Kits(Independence Kit) + Smart Generator (Dual Fuel)](http://us.ecoflow.com/cdn/shop/products/ecoflow-us-ecoflow-power-kits-independence-kit-smart-generator-dual-fuel-10kw-30069028651081_400x@2x.png?v=1668501817)
![Load image into Gallery viewer, EcoFlow US 15kw EcoFlow Power Kits(Independence Kit) + Smart Generator (Dual Fuel)](http://us.ecoflow.com/cdn/shop/products/ecoflow-us-ecoflow-power-kits-independence-kit-smart-generator-dual-fuel-15kw-30069028552777_400x@2x.png?v=1668501821)
![Load image into Gallery viewer, EcoFlow US Bundle EcoFlow Power Kits(Independence Kit) + Smart Generator (Dual Fuel)](http://us.ecoflow.com/cdn/shop/products/ecoflow-us-ecoflow-power-kits-independence-kit-smart-generator-dual-fuel-bundle-30084942594121_400x@2x.jpg?v=1669189405)
![](https://cdn.shopify.com/s/files/1/1996/9707/t/27/assets/815smart-generator-2part-1-1660559223245_1200x.png?v=1660559241)
Introducing the ultimate backup power solution to accompany your portable power station (DELTA Pro/Max/Power Kits). The EcoFlow Smart Generator, now with dual fuel support. It's smarter, and with propane it's more efficient, and more intuitive than the rest, all while integrating seamlessly with your EcoFlow DELTA Max, Pro & Power Kits.
LPG does it better.
With LPG as an additional fuel source, you get way more flexibility. When the grid is down, it's ideal as an emergency option for your home or RV as gas is hard to come by. Not only that, you can store it longer, produce 10% the carbon monoxide, and create less fumes and scents.
![](https://cdn.shopify.com/s/files/1/1996/9707/t/27/assets/815smart-generator-2part2-1660621626396_1200x.png?v=1660621656)
Huge capacity for extended blackouts.
With a 1600W-1800W*1 output and a 4L gasoline tank, you can generate 5.4kWh in gasoline or even 20kWh with LPG*2. That gives you hours up to 12.5 hours of runtime with LPG alone. Connect that to your DELTA Pro/Max to charge up when you’re all out of other options. All while using less fuel, producing less noise, and producing fewer emissions.
*1 Gasoline = 1800W (1900W Peak), LPG = 1600W (1700W Peak)
*2 Measured with a 20lb LPG tank. The power is not limited to this amount. It depends on the size of the LPG tank.
![](https://cdn.shopify.com/s/files/1/1996/9707/t/27/assets/815smart-generator-2part3-1660621626440_1200x.png?v=1660621666)
Save fuel. Maximize efficiency.
When paired with DELTA Pro/Max, you'll get a 40% efficiency gain, saving you fuel, producing fewer emissions, and charging your batteries.That's down to direct DC-DC charging (10%) and X-Stream Charging tech (30%). With that, you can charge DELTA Max to full in 1.8 hours, or DELTA Pro is 2.7 hours.
The efficiencies don't stop with charging either. Pre-determine a set battery percent and automate the Smart Generator to turn on. It'll recharge your DELTA Pro/Max, then shut down when full.
![](https://cdn.shopify.com/s/files/1/1996/9707/t/27/assets/815smart-generator-2part4-1660621626446_1200x.png?v=1660621670)
Stay powered even while charging.
While recharging your batteries, you can still use the AC sockets to power other essential AC appliances simultaneously. If both your AC and DC ports are in use, it’ll intelligently prioritize your AC supply to keep powered no matter what.
![](https://cdn.shopify.com/s/files/1/1996/9707/t/27/assets/815smart-generator-2part5-1660621626522_1200x.png?v=1660621682)
Real-time monitoring and control.
Once connected via Bluetooth or WiFi, the app opens up a whole world of possibilities. Set your battery level for auto-start, control DC output levels, remote start or stop your unit, and switch on Eco mode, all while getting a full suite of monitoring and alerts. Up close? Use the onboard LCD screen for all your vitals.
![](https://cdn.shopify.com/s/files/1/1996/9707/t/27/assets/815smart-generator-2part6-1660621626567_1200x.png?v=1660621691)
Safety first.
The Smart Generator (Dual Fuel) keeps you in the know with a carbon monoxide detector, fuel alert, engine oil alert, temperature protection, overload avoidance, and a whole lot more. All are clearly visible with indicators on the unit, and all (excluding fuel alert) can trigger an auto-shutdown to keep you and your batteries safe.
![](https://cdn.shopify.com/s/files/1/1996/9707/t/27/assets/815smart-generator-2part7-1660621626587_1200x.png?v=1660621697)
Four ways to start means power comes easy.
When you’re caught short in an outage, ease of use is essential. Start up the Smart Generator(Dual Fuel) via an electric button in 2 seconds flat, Far easier than other options on the market, Alternatively, set it to auto-start* in the app, use the app to start it directly, or rely on the manual starter grip in case of failure.
*Auto-start requires use of DELTA Max/Pro or Power Kits
![](https://cdn.shopify.com/s/files/1/1996/9707/t/27/assets/815smart-generator-2part8-1660621626598_1200x.png?v=1660621703)
Dual fuel has never been this easy.
Choose gasoline or propane (LPG) to power and charge your essentials. With LPG, we’ve made it easier than ever. Plug into the LPG inlet without any screwing required. Once set up, you can use the generator seamlessly without switching modes, then power up in seconds with the electric start button. We’ve gone the extra mile too, with a built-in pressure regulator, it's easier to carry your unit.
![](https://cdn.shopify.com/s/files/1/1996/9707/t/27/assets/815smart-generator-2part9-1660621626608_1200x.png?v=1660621708)
Easy maintenance and noise reduction.
With a spacious side access maintenance door, you can keep your unit up to the job. And with the built-in noise muffler, it only outputs 56-67db from a 7-meter distance.
![](https://cdn.shopify.com/s/files/1/1996/9707/t/27/assets/815smart-generator-2part10-1660621626680_1200x.png?v=1660621719)
![](https://cdn.shopify.com/s/files/1/1996/9707/t/27/assets/20221124112055-1669260133418_500x.jpg?v=1669260136)
1. Smart Generator (Dual Fuel) 2. User Manual and Warranty Card 3. Extra Battery Connection Cable 4. Oil Funnel
5. Screwdriver 6. Spark Plug Socket 7. Breaker Bar 8. Double-Ended Spanner 9.LPG Hose
![](https://cdn.shopify.com/s/files/1/1996/9707/t/27/assets/819smart-generator-2phonepart1-1660874842300_1200x.png?v=1660874863)
LPG does it better.
![](https://cdn.shopify.com/s/files/1/1996/9707/t/27/assets/819smart-generator-2phonepart2-1660874842326_1200x.png?v=1660874871)
![](https://cdn.shopify.com/s/files/1/1996/9707/t/27/assets/819smart-generator-2phonepart3-1660874842352_1200x.png?v=1660874878)
![](https://cdn.shopify.com/s/files/1/1996/9707/t/27/assets/819smart-generator-2phonepart4-1660874842356_1200x.png?v=1660874883)
![](https://cdn.shopify.com/s/files/1/1996/9707/t/27/assets/819smart-generator-2phonepart5-1660874842398_1200x.png?v=1660874895)
![](https://cdn.shopify.com/s/files/1/1996/9707/t/27/assets/819smart-generator-2phonepart6-1660874842424_1200x.png?v=1660874902)
Safety first.
![](https://cdn.shopify.com/s/files/1/1996/9707/t/27/assets/819smart-generator-2phonepart7-1660874842434_1200x.png?v=1660874907)
![](https://cdn.shopify.com/s/files/1/1996/9707/t/27/assets/819smart-generator-2phonepart8-1660874842444_1200x.png?v=1660874912)
![](https://cdn.shopify.com/s/files/1/1996/9707/t/27/assets/819smart-generator-2phonepart9-1660874842449_1200x.png?v=1660874917)
![](https://cdn.shopify.com/s/files/1/1996/9707/t/27/assets/819smart-generator-2phonepart10-1660874842465_1200x.png?v=1660874923)
![](https://cdn.shopify.com/s/files/1/1996/9707/t/27/assets/20221124112055-1669260133418_400x.jpg?v=1669260136)
1. Smart Generator (Dual Fuel) 2. User Manual and Warranty Card 3. Extra Battery Connection Cable 4. Oil Funnel 5. Screwdriver 6. Spark Plug Socket 7. Breaker Bar 8. Double-Ended Spanner 9.LPG Hose
Generator Specs
Net weight
67.2 lbs/30.5kg
23.5x11.8x18.7 in/597x300x475mm
Type
Inverter Generator
Frequency
60Hz
Rated Voltage
120V
Rated Power (Gas)
1800W (Peak Value 1900W)
Rated Power (LPG)
1600W (Peak Value 1700W)
DC Output Voltage
42-58.8 V
DC Current
32A
Engine Specs
Model
R80-i
Type
Single cylinder, four-stroke, forced-air cooling, overhead valve
Displacement
80 CC
Fuel Type
Unleaded Gasoline/LPG
Fuel Tank Capacity
4.0 L/1.05 gal.
Engine Oil Capacity
0.38 L/0.1 gal.
Noise Level (at 7m distance)
56-67 dB (full load)
Continuous Working Time (Gas)
3.5 Hours
