EcoFlow DELTA Max Solar Generator (Flexible PV100W) | DELTA Max (1600) / 2*100W Flexible Panels
EcoFlow DELTA Max Solar Generator (Flexible PV100W) EcoFlow DELTA Max Solar Generator (Flexible PV100W) EcoFlow DELTA Max Solar Generator (Flexible PV100W) EcoFlow DELTA Max Solar Generator (Flexible PV100W) EcoFlow DELTA Max Solar Generator (Flexible PV100W) EcoFlow DELTA Max Solar Generator (Flexible PV100W)
USD $2,079.00
Regular price USD $2,079.00
Sale price USD $2,079.00 Regular price $2,242.00
-$163
Secure your power supply with an EcoFlow DELTA Max solar generator bundle at home. Plug in 100W Rigid Solar Panels and get up to 800W input to charge from anywhere in as fast as 3 hours.
 The Portable & Expandable Home Battery
DELTA Max expands up to 6kWh with Smart Extra Batteries, keeping your home powered on in any emergency.
 Rapid Dual Charging
X-Stream tech means that DELTA Max charges 7times faster than the competition. That’s 0–80% in just 65 minutes with AC input. Plug in EcoFlow solar panels and charge in as fast as 3 hours with 8 x 100W rigid solar panels.
  • Extremely Light
    At only 5.1lbs (2.3kg), this flexible solar panel is easy to move and install, barely adding any weight to your vehicle. Flexible solar panels are perfect for roofs that can only support a light load, such as tents and awnings.
  • Flexible
    Its adaptable design can fit a multitude of curved surfaces, making it ideal for mounting on RVs, van roofs, and boats.
  • Weatherproof
    With a waterproof level of IP68, the flexible solar panel can be used in all weather and can withstand dirt, dust, debris, and low-pressure water jets.
  • Universally compatible
    The 100W flexible panel includes a 3.3ft charging cable that gives you plenty of space to position each panel, maximizing solar input. With an all-inclusive solar connector, the 100W rigid panel works with other 3rd party solar systems and power stations.
Capacity of DELTA Max
Number of 100W Flexible Panels
USD $2,079 $2,242 -$163
