Buy EcoFlow DELTA Max Smart Extra Battery | DELTA Max Smart Extra Battery | EcoFlow
USD $1,199.00
Regular price USD $1,199.00
Sale price USD $1,199.00 Regular price $1,599.00
-$400
Up to EcoCredits for cash deduction. Log in
· Expandable capacity - Increase the capacity of DELTA 2, DELTA Max, and DELTA 2 Max with an extra 2016Wh.
· Triple power at up to 30% lower cost - 2-6kWh expandable capacity to fit your energy storage needs. Add up to two DELTA Max Smart Extra Batteries to gain a capacity of 6048Wh. And it's up to 30% more affordable than a power station of the same capacity.
· Easy to use - Plug-and-play without setup. And use the EcoFlow app to monitor and control the DELTA Max Smart Extra Battery.
· 5-Year Full Warranty - With one of the most comprehensive warranties in the industry, we go the extra mile to give you peace of mind.
USD $1,199 $1,599 -$400
Expandable capacity
Triple power & save up to 30% on costs
2-6kWh expandable capacity to fit your energy storage needs. Add up to two DELTA Max Smart Extra Batteries to gain a capacity of 6048Wh, ideal for home backup, RVing, outdoor adventures, and everyday use. Much more affordable, it costs up to 30% less than a power station of the same capacity.
Easy to use
There's no setup. Just plug it into your power station for more energy storage. Using the EcoFlow app, you can charge and monitor the DELTA Max Smart Extra Battery with ease.
Stackable, space-saving design
Featuring an ergonomic, compact design, the DELTA Max Smart Extra Batteries can be securely stacked on top of power stations and each other to save space and minimize clutter.
2016Wh
Weight
40 lb /18 kg
Size
18.3 × 9.3 × 11.1 in. / 46.4 × 23.5 × 28.3 cm
NCM
800 cycles to 80% capacity
Applicable Models
DELTA 2, DELTA Max, DELTA 2 Max
Which portable power station is compatible with the DELTA Max Smart Extra Battery?
DELTA 2, DELTA Max, and DELTA 2 Max are compatible with the DELTA Max Smart Extra Battery.
How many extra batteries can I use with a portable power station?
Can I charge the extra battery without connecting to a power station?
What makes the Smart Extra Battery "Smart"?
