EcoFlow DELTA Max Solar Generator (PV400W) | DELTA Max (1600) / 1*400W | EcoFlow
EcoFlow DELTA Max Solar Generator (PV400W) EcoFlow DELTA Max Solar Generator (PV400W) EcoFlow DELTA Max Solar Generator (PV400W) EcoFlow DELTA Max Solar Generator (PV400W)
USD $2,099.00
Regular price USD $2,099.00
Sale price USD $2,099.00 Regular price $2,998.00
-$899
Up to EcoCredits for cash deduction
• Home emergency power
• Rapid dual charging
• Power multiple devices
• Highly Efficient Solar Panels
• Self-supporting
• Durable and Lightweight
• Weatherproof
Model
Number of Solar Panel
USD $2,099 $2,998 -$899
Expandable Capacity
Dual Charging
Power Multiple Devices
800W max Solar Input
Expandable home backup power.
DELTA Max charges up safely and rapidly from 0-80% in just 65 minutes. And it gets even better. If you’re looking for an even faster way to charge up DELTA Max, you can combine AC with the smart generator to get up to 3400W, AC with solar to get up to 2600W, or the Smart Generator with solar to get up to 2600W.*
With EcoFlow’s X-Boost technology, DELTA Max can power heavy-duty devices up to 3400W. That means during a power outage or blackout, you can continue to power your fridge, dryer, and more. That’s the industry gold standard for a portable power station of this size and capacity.
Harness the power of the sun.
DELTA Max connects with up to 2x 400W EcoFlow solar panels to deliver 800W Max solar charging speeds. With a voltage range from 11-100V and the Solar connector, you can also connect other solar panels to your DELTA Max. Even during cold or cloudy days, our smart maximum power point tracking (MPPT) algorithm automatically detects voltage and current in real time to give you optimum solar generation throughout the day.
Emergency backup power.
Multiple ways to charge.
Specs of DELTA Max (2000)
2016Wh
Extra Battery
Support up to two DELTA Max Smart Extra Battery/Smart Generator
6 outlets, 2400W total (Surge 5000W)
3400W
USB-A Fast Charge
Car Power Output
12.6V, 10A, 126W Max
DC5521 Output
AC Charging Input
1800W Max, 15A
Solar Charging Input
800W Max, 11-100V, 13A
Car Charging Input
Support 12V/24V battery, 8A
NCM
800 cycles to 80% capacity
Connection
Wi-Fi
Approx. 48lbs
Dimension
19.6*9.5*12 in
Specs of DELTA Max (1600)
1612Wh
Extra Battery
6*20A outlets, 2000W total (Surge 5000W)
2800W
USB-A Fast Charge
Car Power Output
DC5521 Output
AC Charging Input
1600W Max, 15A
Car Charging Input
NCM
500 cycles to 80% capacity
Connection
Wi-Fi
Approx. 48lbs
Dimension
19.6*9.5*12 in
Specs of 400W Solar Panel
Rated Power
400W
Cell Type
Monocrystalline silicon
Efficiency
22.40%
42.0*94.1*1.0 in (106.8*239.0*2.4cm)
Connector Type
Solar Connector
Open Circuit Voltage
48V (Vmp 41V)
Short Circuit Current
11A (Imp 9.8A)
Weight(Solar Panel)
Approx. 35.3lbs (16.0Kg)
Weight (with Kickstand Case)
Approx. 41.9 (19kg)
*DELTA Max needs to be connected to the DELTA Max Smart Extra Battery for dual charging.
