EcoFlow DELTA 3 Series Portable Power Station | EcoFlow US | DELTA 3 Plus | EcoFlow
EcoFlow DELTA 3 Series Portable Power Station EcoFlow DELTA 3 Series Portable Power Station EcoFlow DELTA 3 Series Portable Power Station
USD $649.00
Regular price USD $649.00
Sale price USD $649.00 Regular price $799.00
-$150
Up to EcoCredits for cash deduction. Log in
•1-5kWh expandable with DELTA 3 Extra Battery, DELTA Pro 3 Extra Battery, DELTA 2 Extra Battery or DELTA 2 Max Extra Battery.
•1800W AC output, 2200W (surge 3600W) with X-Boost
•5 fast recharging methods (AC, Solar, 800W Alternator Charger, Smart Generator 3000 (Dual Fuel), Multicharging)
•5-year warranty
EcoFlow 800W Alternator Charger (Recommend)
USD $249 USD $599
USD $649 $799 -$150
DELTA 3 Series
AC Charging
Car Charging
Generator Charging
Multi-Charging
Solar Input with 1000W MPPT, Full Charge in 70 Minutes²
EcoFlow DELTA 3 Plus with 500W MPPT × 2 charges fully in 70 minutes, even with limited sunlight. Outdoors, it recharges during lunchtime.
With 1500W max input, it takes 56 minutes to fully charge. During daily use, plug in both AC and solar to charge DELTA 3 Plus, prioritizing solar to save money.
EcoFlow DELTA 3 Series supports 99% of household devices, including refrigerators, TVs, and computers. Plus, with X-Boost, continuously power appliances over 2600W, such as ovens (2150W), hair dryers (1800-2500W), and kettles (1200-3000W). Perfect for home backup, RV, and outdoor usage, this powerhouse ensures you're never left in the dark.
Home backup
Outdoors
RV
Professional work
30 dB Ultra-quiet Operation.
An intelligent energy management system powered by EcoFlow Oasis.
*EcoFlow DELTA 3 Series are compatible with Extra Battery of DELTA 3, DELTA Pro 3, DELTA 2 Max, DELTA 2.
Smaller Size, Same Power
1 Extra Battery, 5 x the Power
LFP Battery
IP65 Battery Pack
BMS
13 Outputs
Compact and lightweight
Approx. 397.6*202*283.6mm
(15.7*8.0*11.2in.)
Approx. 12.5kg
(27.6 lbs)
1024 Wh
Extra Battery
Support DELTA 2 EB, DELTA 2 Max EB, DELTA Pro 3 EB, and DELTA 3 EB (Up to 5kWh)
Total Output Ports
13
2200W
USB-A Output (Fast Charge)
2 ports, 36W Max
2 ports, 140W Max
Car Power Output
1 port, 12.6V, 10A, 126W Max
DC5521 Output
2 ports, 12.6V, 3A Max
AC Charging
1500W
2 ports, DC Charge Input, 11V-60V 500W Max
1500W
Car Charging
800W, in 1.3 Hour
LFP (LiFePO4 battery)
4000 cycles to 80+% capacity
Connectivity
IP65
UPS
<10ms
Noise
600W<30db;1200W<40db
5 years
Footnotes
* Download the EcoFlow PowerManager App to activate the NAS support function on your computer, then install the NUT Server software on your NAS system, connect your DELTA 3 Plus, and activate HID support. The formal launch version will come later in December.
