EcoFlow DELTA 3 1500 Portable Power Station | EcoFlow US | DELTA 3 1500 (Dark Grey)
EcoFlow DELTA 3 1500 Portable Power Station EcoFlow DELTA 3 1500 Portable Power Station EcoFlow DELTA 3 1500 Portable Power Station EcoFlow DELTA 3 1500 Portable Power Station EcoFlow DELTA 3 1500 Portable Power Station EcoFlow DELTA 3 1500 Portable Power Station EcoFlow DELTA 3 1500 Portable Power Station EcoFlow DELTA 3 1500 Portable Power Station
USD $599.00
Regular price USD $599.00
Sale price USD $599.00 Regular price $699.00
-$100
- Expandable to 5.5kWh capacity, 1800W Output
- Fast charge: 0%–80% in 60 min [1]
- 15 ms auto-switch to battery power
- Reliable and durable with a 10-year lifespan
- Enjoy a free 5-year warranty
- Powerful yet lightweight—take power anywhere
- Smart app control
- IP54-rated battery pack with BMS protection
USD $269
USD $299
25% Conversion Rate | IP68
USD $269
USD $249 USD $369
USD $299
USD $269
USD $249 USD $369
USD $299
USD $269
USD $249 USD $369
USD $299
USD $599 $699 -$100
EcoFlow DELTA 3 (1500)Portable Power Station
Same Size, 1.5 Times More Capacity
1536Wh Capacity
With a size nearly identical to 1kWh-class products, this model offers 1.5 times the capacity—letting your appliances run 1.5 times longer, all while maintaining convenient portability and easy storage. It’s the perfect solution for situations where "1kWh isn’t quite enough, but 2kWh is too much"—ideal for one- or two-night camping trips and more.
Conveniently ExpandableUp to 5.5kWh
You'll always be prepared with never-before-seen fast charging
5 industry-leading charging methods
AC outlets
Solar energy
Car charging
Generator charging
With EcoFlow's 1500W X-Stream AC input, DELTA 3 (1500) charges from 0-100% in only 90 minutes. Stay prepped for a power outage or take a last-minute camping trip.
Utilize the sun's energy with a huge solar input of up to 500W. Fully charge DELTA 3 (1500) in as fast as 3.5 hours with EcoFlow Portable Solar Panels.
Using an 800W Alternator Charger, it takes just 2 hours to fully charge, 8× faster than other methods. Charge on the road, so you don't need to prep in advance.
Fully charge DELTA 3 (1500) in only 1.5 hours. The EcoFlow Smart Generator 3000 (Dual Fuel) automatically replenishes power at night, ensuring constant backup without getting hands-on. [
Power 99% appliances without overloading
1800W output (3600W surge) with up to 2200W X-Boost
EcoFlow DELTA 3 (1500) can power 99% of household appliances, including refrigerators, TVs, and computers. With X-Boost, continuously run high-power appliances up to 2400W, from ovens (2150W) to hair dryers (1800-2500W).
Home backup
Outdoors
RV
Professional work
UPS for home backup
Constantly run your refrigerator, fish tank, or CPAP in case of emergencies. Keeps your home essentials powered up no matter what.
Long-lasting and durable, ensuring constant and reliable backup
Triple protection for guaranteed safety from the inside out
LFP battery
IP54-rated
BMS
Third-gen LiFePO4 (LFP) cells offer fast charging without sacrificing longevity. With 3000 cycles to 70% capacity, enjoy up to 10 years of reliable use, 25% above the industry standard.
IP54-rated for resistance against water splashes, dust, and smoke, ensuring durability in various environments. Protects against harsh conditions, providing long-lasting performance.
Powerful yet lightweight, take power anywhere
36.3 lb & 15.7 × 8.3 × 11.1 in
Power home appliances, outdoor activities, or DIY. Easily lift up and take it anywhere.
15.7 x 8.3 x 11.1 in(40 x 21 x 28 cm)
36 lbs/ 16.5kg
1536Wh
Life Span
3000 cycles to 70%
UPS
<15ms
AC Input
1500W
Solar Input
500W, 15A,single port
Car Charger
12V/24V, 8A
1800W, surge 3600W
X-Boost
2200W
12W
USB-A Fast Charge
18W
100W
Car Output
126W
DC5521 Output
38W
AC Charging
1500W
500W Max 3.5 hours
Car charging
12.6V/10A 126W Max~12.1 hours
Thanks for sharing!
