EcoFlow DELTA 2 MAX (1900Wh) Portable Power Station
EcoFlow DELTA 2 MAX (1900Wh) Portable Power Station EcoFlow DELTA 2 MAX (1900Wh) Portable Power Station EcoFlow DELTA 2 MAX (1900Wh) Portable Power Station EcoFlow DELTA 2 MAX (1900Wh) Portable Power Station EcoFlow DELTA 2 MAX (1900Wh) Portable Power Station EcoFlow DELTA 2 MAX (1900Wh) Portable Power Station
USD $1,199.00
Free RAPID Pro 3-in-1 Power Bank
Regular price USD $1,199.00
Sale price USD $1,199.00 Regular price $2,897.00
-$1,698
Ends
00 Days 00 : 00 : 00
• Expandable capacity - 1.9-6kWh expandable capacity to fit your energy storage needs. Add up to two DELTA 2 Max Smart Extra Batteries to hit a capacity of 5996Wh. Ideal for home backup, RVing outdoors or even everyday use.
• Built to last 6× longer - Get 10 years of daily use until hitting 80% of its original capacity. That’s down to its LFP battery chemistry giving you 3000+ cycles.
• Huge AC output - With X-Boost mode get up to 3400W output power to run 99% of home appliances. Power 15 devices at once including 6 AC outlets.
• Fastest recharging - World's fastest AC recharging and X-Stream dual AC+Solar charging speeds. Up to 1000W solar input to charge in as fast as 2.3 hours.
• Capture more energy - 99% MPPT efficiency maximizes solar generation anytime.
• Customized in-app energy management - Prioritize solar or AC charging, view input and output power, battery levels and more.
• 5-Year warranty
USD $1,199 $2,897 -$1,698
EcoFlow DELTA 2 Max (1900) Solar Generator
Ditch Gas, Go Solar
Winner of Red Dot Design Award 2023. EcoFlow EcoFlow DELTA 2 Max (1900) Solar Generator
Durable, Safe, Lightweight
With its upgraded LFP battery chemistry, DELTA 2 Max (1900) has a lifespan of 3000 complete cycles until it reduces to 80% capacity. You'll get pretty much 10 years of power, even if you use it every day. That's 6× longer than other power stations with a similar capacity and output.
LFP Battery Chemistry
Advanced BMS Protection
A built-in battery management system regulates vitals, including voltage, current, and temperature, keeping DELTA 2 Max (1900) safe, secure, and built to stand the test of time.
With LFP cells, DELTA 2 Max (1900) is safe, durable, and highly efficient.
Robust Design
Made with a sturdy one-piece design, DELTA 2 Max (1900) is designed for the rough and tumble of portability. Each port is reinforced, protecting them against wear and tear.
Upgraded Tech, Lighter Weight
Even with its upgraded LFP battery, DELTA 2 Max (1900) is still 30% lighter than similar power stations on the market.
Power pretty much anything with up to 3400W Output
DELTA 2 Max (1900) powers almost all the devices you need with a large 2400W AC output. With X-Boost proprietary technology, run appliances with an output of up to 3400W. Compared with similar portable power stations, DELTA 2 Max (1900) can power more devices while also preventing overloading and overheating.
120V Home Backup: Power through outages
Power your essential appliances with a hefty 2400W AC output by connecting DELTA 2 Max (1900) (1.9kWh) and up to two Smart Extra Batteries (5.9kWh) with your home's transfer switch for partial home backup. With a plug-and-play design, it's easier than ever to prepare for blackouts.
Power for the entire family
1900Wh Capacity
A generous 1900Wh capacity makes DELTA 2 Max (1900) ideal for home bpackup, running your essentials for hoursUsing your transfer switch, or plugged in directly, keep your fridge on and stop food from spoiling for up to13 hours. With its lightweight design, DELTA 2 Max(1900) is portable enough to grab and go on the next campingtrip.
Home Backup
RVing & Outdoors
DIY Projects
Filmmaking & Photography
Expandable up to 6kWh
Triple the power
Take DELTA 2 Max (1900) with you anywhere as a solo unit or connect it with two Extra Batteries for up to 6kWh of home backup.
Fuel Up 80% in Only 43 Mins*
With DELTA 2 Max (1900)'s upgraded tech, combine up to 1000W solar input with AC for world-leading charging speeds. In only 43 min get an 80% charge. Or stick with AC for an 80% charge in a speedy 1.1 hour.
Take control of your power
Smart Automatic Control
AC Always-on
Energy Management
Low Battery Reminder
Save more on electricity billsCustomize the working time of DELTA 2 Max (1900) to avoid peak rates.
Experience peace of mind during power outages With our all-new AC Always On Mode, the AC power button stays on, even during a power outage or after the grid power is back, keeping your appliances powered no matter what.
Easily adjust power Easily adjust AC or Solar input to fit your needs: backup power reserve or energy savings.Prioritize solar energy input via the EcoFlow app when using X-Stream AC + solar dual charging.
Always power readyGet a notification via the app when the battery hits a low.
Extensive 5-Year Warranty
As Quiet as 30 dB
Peaceful charging
At only 30 dB, DELTA 2 Max (1900) is quieter than other 2kWh power stations on the market.
DELTA 2 Max (1900)
DELTA 2 Max (1900)
AC Charging Cable
AC Charging Cable
Car Charging Cable
Car Charging Cable
DC5521 to DC5525 Cable
User manual & warranty card
1900Wh
Extra Battery
6 outlets, 2400W total (Surge 4800W)
X-Boost 3400 W
USB-A Fast Charge
Car Power Output
1 port, 12.6V, 10A, 126W Max
DC5521 Output
AC Charging
X-stream Fast Charge 1800W, 15A
AC Input Voltage
100-120V~ max. 15A 50Hz/60Hz
Car Charging
Support 12V/24V battery, 8A
EcoFlow WAVE & WAVE 2 & GLACIER & Smart Generator
Supported
LFP (LiFePO4 battery)
3000 cycles to 80+% capacity
Connectivity
Wi-Fi & Bluetooth
Net weight (lbs)
50 lbs
Net weight (kg)
23kg
Thanks for sharing!
