EcoFlow DELTA 2 + EcoFlow DELTA 2 Smart Extra Battery | (Members-only) DELTA 2 + DELTA 2 Smart Extra Battery + Free DELTA 2 Bag | EcoFlow
EcoFlow DELTA 2 + EcoFlow DELTA 2 Smart Extra Battery EcoFlow DELTA 2 + EcoFlow DELTA 2 Smart Extra Battery
USD $1,199.00
Regular price USD $1,199.00
Sale price USD $1,199.00 Regular price $1,798.00
-$599
Up to EcoCredits for cash deduction
  • Expandable capacity - 1-3kWh expandable capacity to grow your storage to your needs. Add on the DELTA 2 extra battery to reach 2048Wh, or add on the DELTA Max Extra Battery to hit 3040Wh. Great for home backup or everyday appliances.
  • Huge AC output - 1800W AC output means you can power more than 90% of your home appliances. Or, try plugging in up to 15 devices at once. Unlike other brands, DELTA 2 can prevent overloading from devices up to 2200W thanks to X-Boost technology.
  • 7x Faster AC charging - X-Stream tech means that DELTA 2 charges 7 times faster than the competition. That’s 0–80% in just 50 minutes and 0-100% in 80 minutes with AC input.
  • Or go green without sacrificing speed - Plug in portable solar panels and get up to 500W input to charge from anywhere in as fast as 3 hours.
  • Built to last 6x longer - Get 10 years of daily use until hitting 80% of its original capacity. That’s down to its LFP battery chemistry giving you 3000+ cycles.
  • Control from anywhere - Use the EcoFlow app to control your DELTA 2 from anywhere using Wi-Fi. Link with Bluetooth when off-grid. Either way, you can check charging data, customize settings and adjust the charging speed with ease.
  • 5-year warranty Unlock an extended 5-year warranty for worry-free experience.
Click here to learn more about DELTA 2 Smart Extra Battery.
    USD $1,199 $1,798 -$599
    EcoFlow DELTA 2 is a must-have for any home that puts power security & comfort first. Ensure you're prepared with the power station made for almost any situation your family could find themselves in. All while staying green.
    With a capacity of 1kWh to start with, you’ve got enough energy for your essentials for hours on end. Need even more? Add on the DELTA 2 extra battery to reach 2048Wh, or add on the DELTA Max Extra Battery to hit 3040Wh. Great for home backup or everyday appliances.
    Power pretty much anything.
    A 1800W AC output means you can power more than 90% of your home appliances. That’s your microwave, fridge, or even coffee maker covered in a blackout. Or, try plugging in up to 15 devices at once for when you’re around the table with the family. Unlike other brands, DELTA 2 can prevent overloading from devices up to 2200W thanks to X-Boost technology.
    The fastest charging on the market.
    X-Stream tech means that DELTA 2 charges 7 times faster than the competition. That’s 0–80% in just 50 minutes with AC input, or 0-100% in 80 minutes.
    Go green without sacrificing speed.
    Pair with solar panels and charge in as fast as 3-6 hours with 1x400W, 2x220W portable solar panels. With its MPPT (Maximum Power Point Tracking) smart algorithm, DELTA 2 can actively detect the voltage and current in real-time to reach the maximum power point with >98% efficiency. That means a more efficient charge than other brands.
    Built to last 6x longer.
    Finally… tech that’s made to last. Get years of regular use until hitting 80% of its original capacity. That’s down to its LiFePO4 battery chemistry giving you 3000+ full charge and drain cycles.
    Ready for emergencies.
    Portable & light.
    Designed so you can take power anywhere, DELTA 2 weighs about as much as a medium-sized dog. Compared to generators, it’s portable, indoor-friendly, and light. Add on the waterproof bag and you can use it outdoors in any weather too.
    You've got our word.
    With a 5-year extended warranty, you can rest easy knowing you've got a unit built to last.
    Compare The Models
    DELTA
    Capacity:1260Wh
    Life Cycles: 800+ Cycle
    Output: 1800W (Surge 3300W)
    AC Input: 1200W Max
    Solar Input: 400W
    $1399
    RIVER Pro
    Capacity:720Wh
    Output: 600W (Surge 1200W)
    AC Input: 660W Max
    Solar Input: 200W
    $649
    RIVER Max
    Capacity:576Wh
    Life Cycles: 500+ Cycle
    AC Input: 500W Max
    Solar Input: 200W
    $599
    Specs of DELTA 2
    1024 Wh
    Extra Battery
    6 outlets, 1800W total (Surge 2700W)
    2200W
    2 ports, 5V, 2.4A, 12W Max
    USB-A Fast Charge
    Car Power Output
    1 port, 12.6V, 10A, 126W Max
    DC5521 Output
    2 ports, 12.6V, 3A, 38W Max
    AC Charging
    1200W
    11-60V, 15A, 500W max
    Car Charging
    Support 12V/24V battery, 8A
    DC Charging
    1100W
    LFP (LiFePO4 battery)
    Cycle life
    3000 cycles to 80+% capacity
    Connectivity
    Wi-Fi & Bluetooth
    Dimension
    27 lbs / 12 kg
