EcoFlow RIVER 3 Portable Power Station | EcoFlow US | RIVER 3
EcoFlow RIVER 3 Portable Power Station EcoFlow RIVER 3 Portable Power Station EcoFlow RIVER 3 Portable Power Station EcoFlow RIVER 3 Portable Power Station EcoFlow RIVER 3 Portable Power Station
USD $199.00
Regular price USD $199.00
Sale price USD $199.00 Regular price $239.00
-$40
Save 29% with Refurbished Tech
Buy Now>>
Certified refurbished devices deliver the same power and performance.
Mechanical and structural components fully functional
No loose, missing, or rusted fasteners
Cleaned, tested, upgraded, and ready to go
Comes with complete accessories and packaging
Backed by official warranty and support
  • 245Wh capacity, 300W rated output, X-Boost up to 600W
  • Up to 2× runtime for light-wattage appliances 1
  • 30% smaller than the industry average
  • <20 ms UPS for uninterruptible backup
  • <30dB whisper quiet for 24/7 use
  • 1-hr fast charging, no battery damage
  • IP54 waterproof-rated battery pack
  • Charge up to 6 appliances at the same time
USD $199 $239 -$40
An ideal starter battery that is compact yet delivers powerful performance.
Compact design, longer runtime
Easily handle power outages and extend outdoor stays with GaN
With groundbreaking X-GaNPower, RIVER 3 is changing the industry with compact, quiet batteries that deliver long runtimes for small electronics. By tapping into the superior energy efficiency of GaN, this series stretches the operating time of low-wattage devices while reducing the size and controlling the volume.
2× light and network runtime
RIVER 3 revolutionizes energy efficiency, delivering double runtime for appliances under 100W, extending use at home and in the great outdoors.¹
30% more compact for on-the-go use
RIVER 3 minimizes heat loss, requires less cooling space, and supports a compact design. It easily fits into small spaces like closets, a minivan, or a bag for easy storage and portability.
<30 db whisper quiet for 24/7 backup
With X-GaNPower technology, from enhanced heat dissipation, RIVER 3 operates on a library-like silence level, with a volume of less than 30 dB at a distance of 1.5 ft.² You'll have peace day and night guaranteed, even when it's running nonstop.
<20 ms UPS solution for uninterrupted daily living
When a power outage occurs, your AC outlet will switch to the RIVER 3 supply in a barely noticeable 20 ms. It keeps vital home appliances running, maintaining food storage, security, and communication. Experience a seamless, automatic switchover for continuous peace of mind
AC charging
Car charging
Generator charging
RIVER 3 fast-charges in 1 hour with X-Stream, no battery damage with vehicle-grade cells and trickle charge technology.
Power up RIVER 3 in only 2.6 hours with 110W solar input. Go even more portable with our 45W Portable Solar Panel (Type-C), which folds to the size of a laptop and charges electronics directly.
Charge RIVER 3 using your car battery while you drive, making it an ideal choice for on-the-go.
Recharge RIVER 3 in just 1 hour with a gas generator for a full day of quiet, safe, and efficient power.
Extremely durable for worry-free outdoor use
With IP54 battery protection, water damaged is minimized.³ Its robust fire-retardant shell survives rough conditions. Even after a 3.3 ft fall, RIVER 3 won't get damaged.
RIVER 3 has a lifespan of 3000 charging cycles. That's around 10 years of everyday use before its capacity drops to 80%.
Featuring an advanced algorithm for cloud-based battery monitoring with 40+ safety measures, RIVER 3 protects against various current, voltage, temperature, and circuit risks.
Power up to 600W appliances
Your reliable companion in the wild or during an outage
RIVER 3 keeps 90% of your must-have appliances running with 300W of power. With X-Boost technology, it can power 600W heating devices without breaking a sweat. Keep your essentials running smoothly, even during power outages or outdoor getaways.
Upgraded smart control
Convenient, intelligent, customized power control
Product Details
245Wh
10×8.3×4.4 in
7.8 lb
UPS
<20 ms
Noise
<30 dB
2 outlets, 300W total (Surge 600W, X-Boost 600W)
2 ports, 5V=2.4A, 12W max per port, total 24W
1 port, 5/9/12/15⎓3A Max, 20V⎓5A Max,100W Max per port
Car Output
AC Input
320W, 0-100% in 60 min
Solar Input
110W, 0-100% in as fast as 2.6 hr
Car Input
100W, 11~30V, 0-100% in 2.8 hr
Generator Input
Optimal Operating Temperature
68°F-86°F
Charge Temperature
32°F-113°F
Discharge Temperature
14°F-113°F
Storage Temperature
68°F-86°F
Footnote:
All the test results displayed on the page are based on our internal testing, subject to different conditions, including temperature variations, humidity levels, and equipment calibration standards. Please note that these results are provided for informational purposes only and should not be considered as conclusive evidence for all scenarios. Data was tested in a controlled laboratory environment and actual user experience may vary.
1. The runtime is based on laboratory tests conducted with common household appliances under normal room temperature conditions. The "double runtime" claim specifically refers to tests using a 3W light or Wi-Fi router.
3. The input and output wattage of the Smart Extra Battery will decrease to 100W when ambient temperature is higher than 95°F (35°C).
4. The IP54 water-resistance rating applies only to the battery pack, not the entire package. It does not prevent water immersion but can prevent fire or explosion in the event of a short circuit if the battery is splashed with water or rain, ensuring user safety and property protection
Thanks for sharing!
