RIVER 2 Pro Portable Power Station with 768Wh Capacity | EcoFlow US
EcoFlow RIVER 2 Pro Portable Power Station EcoFlow RIVER 2 Pro Portable Power Station EcoFlow RIVER 2 Pro Portable Power Station EcoFlow RIVER 2 Pro Portable Power Station EcoFlow RIVER 2 Pro Portable Power Station
USD $315.00
Regular price USD $315.00
Sale price USD $315.00 Regular price $599.00
-$284
•Sizeable 768Wh capacity and 800W output
•Provide up to 1.8kWh a day with solar charging
•Fastest Recharge 0-100% in only 70 min
•Safest LFP battery provides 10 years of use
•First power station with a TÜV Rheinland safety certification
•X-Boost output to 1600W and run 80% of home appliances
•4 ways to charge: AC, car, solar, and USB-C
•Lightweight at only 18.2lbs
•<30ms EPS auto-switch for essential devices
•Smart app control with Bluetooth or Wi-Fi
USD $315 $599 -$284
♻️Trade in to save up to $130. Learn more
Power. Never Been This Easy
编组备份.png__PID:94a3d66f-a819-4fad-8b17-6638fd8f8e1e
编组备份.png__PID:0fffed83-795f-4951-b9cf-46832292244d
Charge 0-100% in 70 mins
Fastest charging speeds ever.
RIVER 2 Pro beats the industry charging speed standard, fully charging in only 70 minutes. That's 5x faster than other portable power stations on the market and 27% quicker than previous generations. Fully charge RIVER 2 Pro while you pack your bags, so you'll always be ready for a last-minute trip.
LiFePO4 Battery Chemistry
5-year Warranty
Our state-of-the-art Battery Management System (BMS) constantly monitors the voltage, current, and temperature of RIVER 2 Series with multiple aspects of protection, extending its life to the max.2
4 Ways to Charge
Charge anywhere.
AC Charging
Car Charging
USB-C Charging
AC Charging                                               Car Charging
Solar Charging                                          USB-C Charging
The most easy-to-use independent solar power system. Take it to camping, RV trips, or run your home essentials with it. Whether you are on the go or chilling at home, have stable, durable, and reliable energy on hand whenever you need. Join hands with us in this energy-sharing world and live green.
RIVER 2 Pro Solar Generator produces up to 1.8kWh daily, which means sufficient power to run your essential home appliances smoothly for almost half a day. Sudden power outages? You'll always be ready. Using RIVER 2 Pro Solar Generator every day decreases your whole-year carbon emissions by about 143kg. That's like planting 8 trees in a year!*
Up to 23% Solar Conversion
Faster Solar Charging 0-100% in 4.5-9 hr
IP68 Waterproof Solar Panel
Easily Plug & Unplug
10 Years of Use
Long-term Saving
*Based on an average carbon emission of 0.371kg/kWh and an average sunshine duration of 6 hours/day.
X-Boost Up to 1600W
Small size. Big power.
RIVER 2 Pro has an AC output of up to 800W. Need to power a hair dryer, microwave or electric kettle? Crank it up to 1600W with X-Boost mode to run up to 80% of high-wattage home appliances.
Lightweight at only 18.2 lbs
<30ms EPS Auto-switch
Ultra-fast home backup switchover.
With a switchover speed of less than 30ms, you won't even know the power was down. Use RIVER 2 Series as an emergency power supply for overnight outages to keep essentials running from a light to your fish tank.
EcoFlow App
Control at your fingertips.
Use the EcoFlow app to control and monitor RIVER 2 Series, even from afar. View charging levels, customize settings, and adjust charging speeds, all from the convenience of your phone.
LEARN MORE >
Power. Anywhere. Anytime.
r2p-us-1678954515449 1.jpg__PID:ffadebd5-fe87-43d5-9050-1e72680713ce
1. RIVER 2 Pro 2. 1.8m AC Charging Cable 3. Quick Start Guide
RIVER 2 Pro Specs
768Wh
Approximately 18.2lbs
270 x 260 x 226mm
AC Input
100-120V~50Hz/60Hz, 940W Max
Solar Input
11-50V 13A, 220W Max
USB-C Input/Output
5/9/12/15/20V 5A, 100W Max
DC Output
12.6V, 10A/3A/3A, 126W Max
5V, 2.4A, 12W Max
Pure Sine Wave, 800W total (surge 1600W), 120V ~ 50Hz/60Hz
Cell Chemistry
Discharge Temperature
14°F to 113°F
Charge Temperature
32°F to 113°F
Optimal Operating Temperature
68°F to 86°F
Storage Temperature
14°F to 113°F (68°F to 86°F is best)
Car Input
12V/24V, 8A, 100W Max
DC5521 Output
12.6V, 3A, 36W Max
App Control
Wi-Fi, Bluetooth
