Power Kits 5kVA 48V Power System
Power Kits 5kVA 48V Power System Power Kits 5kVA 48V Power System Power Kits 5kVA 48V Power System
USD $8,296.00
Regular price USD $8,296.00
Sale price USD $8,296.00 Regular price
-$-8,296
The first 200 customers* to place an order will become EcoFlow Elite200 Users.
Please kindly note that shipments are expected to begin from mid-December, 2024.
  • High 5kVA output power, to run 2 × 13500 BTU rooftop a/c units at the same time
  • As quiet as 48 dB¹, a volume lower than a quiet office
  • 45kWh capacity for up to 7 days off-grid
  • 4 diverse charging methods: shore power, solar, vehicle alternator, and generator.
  • Charge 11kWh in only 1 hour
  • Utilize free energy, 0 upkeep costs
  • App & screen smart control
  • Compact & light, stores easily
EcoFlow 5kWh LFP Battery
USD $1,749
2-15kWh Storage Capacities
EcoFlow 10kWh LFP Battery
USD $9,198
Power Hub 5kVA with Cable Pack
USD $3,499
EcoFlow 30/50A AC/DC Smart Distribution Panel
USD $449
EcoFlow Power Link
USD $399
EcoFlow Power Dock
USD $439
EcoFlow Smart Generator 4000 (Dual Fuel)
USD $1,259
USD $1,749
USD $9,198
USD $3,499
USD $449
EcoFlow Power Link
USD $399
EcoFlow Power Dock
USD $439
USD $1,259
USD $1,749
USD $9,198
USD $3,499
USD $449
EcoFlow Power Link
USD $399
EcoFlow Power Dock
USD $439
USD $1,259
USD $8,296
Solutions for All Types of RV
Whether you're replacing the electrical equipment in your vehicle or building a system from scratch, the Power Kits plug-and-play system lets you customize every component to meet the needs of your vehicle and your getaway.
PowerLuxe
PowerSwift
PowerTrail
Suitable for luxurious RV travel in Class A and Class C motorhomes, the EcoFlow PowerLuxe solution ensures comfort and a steady energy flow for your entire motorhome. Its advanced 48V electrical architecture offers industry-leading safety and efficiency. For extended road trips, store up to 45kWh of power and generate tremendous amounts of energy from solar and alternator, for ultimate on-the-go comfort.
This safe, high-performing, compact system is perfect for adventurers and van life enthusiasts who demand unlimited power without a bulky battery system. Ideal for off-grid journeys, the EcoFlow PowerSwift solution can be tailored to fit the lifestyle of a compact van owner. With its intelligent and efficient design, this solution delivers super fast charging and smart control over your power.
This versatile solution is perfect for RV power system upgrades. Whether you are looking for a powerful lithium battery or simply adding more solar power to your RV, the EcoFlow PowerTrail solution delivers robust, efficient power with smart control features. Boost your RV's energy storage to meet more outdoor power needs.
Meet All Your Power Needs
Run 2 × 13500 BTU RV A/C Units
With up to 4000W output and 8000W surge power, the Power Kits 5kVA system can simultaneously run 2 × 13500 BTU RV air conditioners and other high-powered appliances, like air fryers and space heaters, without the need for a soft starter.
Keep the Peace
X-Quiet volume of only 48 dB[1]
With a volume as low as 48 dB at a 50% wattage load, run your Power Kits system all day and night on any campground without worrying about disturbing the neighbors.
Stay Full of Energy
Power on for up to 7 days
With up to 45kWh energy storage and 4 unique charging methods, stay charged while you're on the road no matter how long you're away.
Rain or shine, at home or on the go, there's always a charging option.
Solar Power
Up to 4800W solar input capacity, fully charge a 5kWh battery in almost 1 hour.
Shore Power
Use shore power for a 4000W charge and top up a single 5kWh battery in only 1.5 hours.
Vehicle Alternator
Combine all charging methods to reach the maximum charging capacity.
Smart Generator
Plug in your EcoFlow Smart Generator (Dual Fuel) and fully charge a 5kWh battery in 1.6 hours with an input of 3.2kW.
1-Hour to Fully Charge
With DC integrated charging, which includes a Power Hub, AC shore power, and Power Dock, you can recharge a massive 20kWh in 1.6 hours!
Full-Vehicle Control on One Screen
Track your entire vehicle's power and water usage right from your smartphone or EcoFlow PowerInsight.
Intelligent Monitoring & Control
Multi-Device & Screen
Customize & Automate
Power Kits integrates water, electricity, and access control systems for smart vehicle monitoring. It offers remote control of charging and discharging, independent management of 16 DC circuits, and reads power usage for each circuit and total charging/discharging amounts.
Seamlessly track data across multiple devices and screens, including 2 monitors and the EcoFlow app.
Set smart always-on tasks, including vehicle battery auto-charging, to ensure your batteries are always charged.
Safe & Reliable
Our Tech in One System
Durable Structure
On Guard 24/7
Safety, Certified.
Our industry-first CTC (cell-to-chassis) process integrates the battery shell and internal components into a single, robust structure. This innovative design offers higher strength, external security, and improved drop resistance.
Our X-Guard BMS (Battery Management System) algorithm provides around-the-clock protection. Covering up to six monitoring and safeguard measures, including low temperature, over-discharge, overcharge, high temperature, short circuit, and overcurrent, it ensures a fail-safe recovery.
Experience reliable RV power and safety with our UL1973-certified 48V LFP batteries, UL458-certified Power Hub and UL67-certified distribution panel.
50% Lighter, 50% More Compact
Designed with small spaces in mind, Power Kits uses half the space and weighs 50 lb less than comparative solutions. It's a convenient, plug-and-play system that leaves more time for off-grid adventures.
Simple Assembly
We made our modular system plug-and-play so you can quickly customize your van power whenever you want. Simply stack a battery to increase capacity or plug in a solar panel for faster charging.We've got experts on hand to guide you through the installation process or put you in touch with authorized and reputable installers.
Worry-free Business Partner Service
