EcoFlow x Velotric | E-Bike & Portable Power for Adventure | EcoFlow DELTA 3 Plus + Velotric Nomad 2x (Step-Thru Sage)
EcoFlow × Velotric EcoFlow × Velotric EcoFlow × Velotric EcoFlow × Velotric EcoFlow × Velotric
USD $2,948.00
Regular price USD $2,948.00
Sale price USD $2,948.00 Regular price $3,298.00
-$350
  • EcoFlow DELTA 3 PLUS + Velotric Nomad 2x
Velotric Nomad 2X Full Suspension Fat Tire Ebike
- Full air suspension
- 750W motor peaking at 1400W
- Up to 75 miles of range
- 1kWh Capacity, provides 1.4 full charges Nomad 2X, up to 85 additional miles.
- 3600W AC Output, Stable Power, X-Boost™ Tech.
- <10 ms EPS for Uninterrupted Productivity.
  • EcoFlow DELTA 2 + Velotric Fold 1 Plus
Velotric Fold 1 Plus Premium Folding Ebike
- 60-Second Quick Fold
- 450-lb Max Load Capacity
- ComfortMax™ Design for Extended, Smooth Rides
- 1kWh Capacity, provides 1.6 full charges Fold 1 Plus, up to 87 additional miles.
- 2200W AC Output, Stable Power, X-Boost™ Tech.
- <30 ms EPS for Uninterrupted Productivity.
*All coupon codes can't be applied to the products.
*After placing an order, products will be shipped separately by EcoFlow's official website and Velotric's official website with an estimated delivery time of 5–10 business days.
From classic tones to Multi-Terrain Camo
For additional options, please visit Velotric’s official store.
EcoFlow DELTA 3 Series Smart Extra Battery (Recommended Accessory)
USD $499 USD $599
EcoFlow 220W Bifacial Solar Panel (Recommended Accessory)
USD $269 USD $649
EcoFlow DELTA 2 Smart Extra Battery (Recommended Accessory)
USD $350 USD $799
USD $269 USD $649
USD $2,948 $3,298 -$350
EcoFlow X Velotric:
Powering Your Ride, Empowering Your Journey
Powerful e-bikes and portable power stations keep you energized for longer rides, commutes, and adventures—anytime, anywhere. Ride farther, explore more, and reduce your carbon footprint with every journey.
Velortric
Velotric is a leading Ebike brand in North America, trusted by over 100,000+ riders and supported by a network of 1,000+ local shops and service partners. Built on industry-leading manufacturing, proprietary ComfortMax™ and SensorSwap™ technologies, UL-certified safety, and IPX7 battery / IPX6 whole-bike waterproofing, Velotric makes riding simpler, smoother, and fun. Embracing the freedom of two wheels is what we're all about.
EcoFlow is a leading provider of eco-friendly energy solutions, committed to powering a new world. Since its founding in 2017, EcoFlow has aimed to be the FIRST in power solutions — Flexible, Innovative, Reliable, Simple, and Thorough — for individuals and families, whether at home, outdoors or on the go. With a smart manufacturing center in China, and headquarters in the USA, Germany and Japan, EcoFlow has empowered over 5 million users in 140 markets worldwide.
Velotric Nomad 2X Full Air Suspension Fat Tire Ebike
Locked and loaded with a 120mm adjustable front air fork and up to 80mm of rear wheel travel, the Nomad 2X is built to glide through the gnarliest terrain. Power through rocky trails, loose sand, muddy slopes, or uneven dirt paths, our dual suspension system keeps you all-terrain ready.
Equipped with a 750W motor peaking at 1400W and 105Nm of torque, steep climbs and tough trails are no trouble. Paired with an 801.6Wh battery delivering up to 75 miles of range, your next escape has no limits.
Comes with a 560 lb total payload capacity, a 120 lb-rated rear rack, and towing strength up to 1000 lbs. Ready to haul gear, game, and whatever else the journey demands.
A ride you can trust. Every Nomad 2X is officially UL-certified, featuring an IPX7 waterproof battery and IPX6-rated components, delivering proven quality no matter how rough the ride gets.
FULL AIR SUSPENSION FOR ALL TERRAINS
POWER UNLEASHED
UNBEATABLE PAYLOAD
BUILT FOR THE GREAT OUTDOORS
DELTA 3 Plus
AC Charging
Car Charging
Generator Charging
Multi-Charging
Solar Input with 1000W MPPT, Full Charge in 70 Minutes²
EcoFlow DELTA 3 Plus with 500W MPPT × 2 charges fully in 70 minutes, even with limited sunlight. Outdoors, it recharges during lunchtime.
With 1500W max input, it takes 56 minutes to fully charge. During daily use, plug in both AC and solar to charge DELTA 3 Plus, prioritizing solar to save money.
EcoFlow DELTA 3 Series supports 99% of household devices, including refrigerators, TVs, and computers. Plus, with X-Boost, continuously power appliances over 2600W, such as ovens (2150W), hair dryers (1800-2500W), and kettles (1200-2600W). Perfect for home backup, RV, and outdoor usage, this powerhouse ensures you're never left in the dark.
Home backup
Outdoors
RV
Professional work
Ensure reliable backup for specialized equipment with a 10 ms UPS.
30 dB Ultra-quiet Operation
An intelligent energy management system powered by EcoFlow Oasis.
*EcoFlow DELTA 3 Series power stations are compatible with the following Extra Battery models:DELTA 3, DELTA Pro 3, DELTA 2 Max, DELTA 2.
*EcoFlow DELTA 3 Series are compatible with Extra Battery of DELTA 3, DELTA Pro 3, DELTA 2 Max, DELTA 2.
Smaller Size, Same Power
1 Extra Battery, 5x the Power
LFP Battery
IP65 Battery Pack
BMS
IP65-rated for resistance against water splashes and dust,ensuring durability in various environments. Protects against harsh conditions, providing long-lasting performance.
13 Outputs
Compact and lightweight
Approx. 398x202x283.6mm(16x8.0x11 in)
Approx. 12.5kg(27.6 lb)
1024 Wh
Extra Battery
Support DELTA 2 EB, DELTA 2 Max EB, DELTA Pro 3 EB, and DELTA 3 EB (Up to 5kWh)
Total Output Ports
13
2200W
USB-A Output (Fast Charge)
2 ports, 36W Max
2 ports, 140W Max
Car Power Output
1 port, 12.6V, 10A, 126W Max
DC5521 Output
2 ports, 12.6V, 3A Max
AC Charging
1500W
2 ports, DC Charge Input, 11V-60V 500W Max
1500W
Car Charging
800W, in 1.3 Hour
LFP (LiFePO4 battery)
4000 cycles to 80+% capacity
Connectivity
IP65
UPS
<10ms
Noise
600W<30db;1200W<40db
5 years
Terms & Conditions
30-Day Price Match Guarantee
A. The EcoFlow x Velotric Bundle products are eligible for a 30-day price-match guarantee policy.
B. Orders placed on our official website will benefit from a 30-day price match guarantee service. If customers find a lower price on our official website within 30 days of placing their order, they can apply for a refund of the price difference.
C. Please note that this price-match guarantee only applies to our official website. This Price Guarantee applies to purchases from us.EcoFlow.com only. Lower price must be for identical product on us.EcoFlow.com.
D. This price-match does not apply to marketplace resellers, financing offers, coupons, gift card offers, bundles, free items, customizable configurations, specialty products, pricing errors, service and installation offers, items advertised as limited-quantities, out-of-stock items, deal-of-the-day, flash sales, closeouts, discontinued, clearance, final sale, or any paid membership club offers.
Coupon Terms
A. Coupon codes are not valid for EcoFlow × Velotric Bundle products.
B. The bundle is excluded from all promotional discounts, including percentage-based and fixed-amount coupons.
Return Policy
A. Each product is subject to its respective official store's return policy. For more information, please refer to the following links: EcoFlow Return Policy, Velotric Return Policy.
B. Contact EcoFlow Support at support@EcoFlow.com to start the return process. Please provide them with proof of purchase, such as an invoice.
C. After you have returned the product to our warehouse, we will issue a refund within 14 business days. You will be notified by email when your order is refunded.
D. Please note that a restocking is subject to charge. For unused bike, a $200 restocking fee will be deducted from the final refund. For used bike, a 20% of the total order amount will be deducted from the final refund. The ebike must be free of any wear and tear, dirt, dust, fragrance, or any other signs of use and must be in the same packaging and condition that you receive it and must include all items that were inside the box (charger, pedals, bell, front & rear reflectors, headlight, toolkits (9 tools in total), user manual, quick start guide, etc.).
E. Orders cannot be canceled more than 30 days after they are shipped.F. The refund will be calculated based on the individual item values (DELTA 2: $499, DELTA 3 PLUS: $649,Nomad 2X $2399, Fold 1 Plus $1499) minus applicable processing fees, shipping charges, and other deductions.
General Terms
A. After placing an order, products will be shipped separately by EcoFlow's official website and Velotric's official website with an estimated delivery time of 5–10 business days.
B. Offers are subject to availability and are valid while supplies last.
C. For more product specifications, please visit the product detail page to learn more. EcoFlow DELTA 2 , EcoFlow DELTA 3 PlusVelotric Nomad 2X, Velotric Fold 1 Plus.
D. Each product is subject to its respective official store's shipping policy. For more information, please refer to the following links: EcoFlow Shipping Policy, Velotric Shipping Policy. (*Note: Delivery service is unavailable for orders shipped to Guam, island regions, Puerto Rico, Hawaii, or Alaska.)
E. For inquiries regarding specific products or quality issues, please contact the respective brand's customer service: EcoFlow: support@EcoFlow.com,Velotric: help@velotricbike.com.
F. By purchasing, you agree to EcoFlow's Privacy Policy and Terms of Use, Velotric's Privacy Policy.
G. We reserve the right to cancel or limit any purchase or offer redemption made 1) contrary to the terms of each offer, discount, promotion or coupon; 2) that otherwise is not in compliance with our Terms of Use; 3) that violates any applicable law; or 4) that we believe is fraudulent or made through improper channels.
H. There may be certain orders that we are either unable to accept or must cancel. We reserve the right, at our sole discretion, to refuse or cancel any order for any reason. We are not responsible for inaccuracies or errors.
I. EcoFlow / Velotric reserves the right to modify or cancel the promotion at any time, as permitted by applicable law. We also reserve the right to exclude any customer from the promotion in cases of fraud or abuse.
J. EcoFlow / Velotric reserves the right to decide on any dispute arising from or in connection with the promotion.
K. EcoFlow / Velotric is not responsible for delays caused by reasons beyond its control, including, but not limited to, network transmission failures.
L. EcoFlow / Velotric is not liable to the customers for any direct or indirect losses or damages incurred by customers due to actions or negligence related to the promotion.
Stay in the Loop & Save More!
Price Drop Alerts
Cost Savings
Whole-Home Backup
Intelligence Solutions
Thank you for subscribing!
