EcoFlow PowerPulse EV Charger (9.6kW) (Recommended Accessory) | EcoFlow Power Pulse EV Charger (9.6kW)
USD $599.00
Regular price USD $599.00
Sale price USD $599.00 Regular price $899.00
-$300
  • Fast Charging: Delivers up to 40A and 9.6kW output—enough to add 35 miles of range per hour for a Tesla Model 3. Say goodbye to overnight charging.
  • Smart Home Scheduling: Seamlessly integrates with EcoFlow DELTA Pro Ultra and Smart Home Panel 2 to manage home power, appliances, EV charging, and backup systems—all automatically.
  • Free Daily Commutes: AI-powered charging modes optimize your energy use by drawing from excess solar power and off-peak electricity to charge your EV efficiently.
  • Plug & Play: Compatible with NEMA 14-50P outlets. No permits or professional installation required, save $1000+.
  • Flexible Parking: The 25-foot extra-long cable gives you the freedom to park where it's most convenient.
  • Built for Most Conditions: NEMA 4-rated for reliable outdoor use. Designed to withstand impacts, severe weather, and extreme temperatures (-22°F to 122°F). Waterproof, dustproof, and rust-resistant.
    To ensure full access to the software functionalities outlined below, please update the firmware of your EcoFlow DELTA Pro Ultra and EcoFlow Smart Home Panel 2 units to the latest available version.
USD $599 $899 -$300
Charge Faster, Live Freer
Up to 40A, 9.6kW = 35 miles¹ added per hour
9.6kW isn't just a number. For the Tesla Model 3, it delivers up to 35 miles of added range per hour.
Ready for your morning commute
Forgot to charge overnight? No worries. Top up your Tesla Model 3 over breakfast and be road-ready before your coffee is finished².
Power-up your electric vehicle with ease
Works with Tesla (with NACS Adapter), Ford Mustang Mach-E, and other major U.S. EVs.
Slash Bills with AI
Save more when you sync with the DELTA Pro Ultra whole-home backup system.
PowerPulse adapts to your routine using AI-driven charging modes. Seamlessly syncing with the EcoFlow Smart Home Panel 2 and EcoFlow DELTA Pro Ultra, it hunts for solar surplus at noon and switches to your utility's off-peak rates at midnight while keeping your EV ready for daily drives. If your EV consumes around 10kWh per day, this system can save you up to $1,095³ annually—equivalent to a full year of free commuting.
Cost-Efficient Charging Modes Compatible with DELTA Pro Ultra or Smart Home Panel 2
A Smart Day with Eco Mode
Solar Surge Hours
Off-Peak Savings
As solar production peaks, the system prioritises powering home appliances first, then charging your EV, and finally topping up the DELTA Pro Ultra battery as needed.
When electricity rates drop overnight, the system switches to the grid to power everything. By sunrise, both your home battery and EV are fully charged—ensuring your home is ready for the day and keeping your energy bills low.
Intelligent Charging Modes for EV Chargers Standalone Use
Smart Mode⁵
Fast Charge
Custom
Unlock Smarter EV Charging —
3 Flexible Setups
Full Power: 9.6kW Output
Connect your PowerPulse EV Charger (9.6kW) to NEMA 14-50P , enabling peak 9.6kW charging performance — ideal for faster home charging and maximum efficiency.
2 Ways for Intelligent Connect: 7.2kW Output
Connect your PowerPulse EV Charger (9.6kW) to the Smart Home Panel 2 or DELTA Pro Ultra for 7.2kW charging with intelligent features.
Plug & Play, Save Money
Plug & play, save $1000
Compatible with 14-50P
Can PowerPulse directly connect the home grid to charge the car?
PowerPulse can connect with the grid separately, but users need to purchase their own NEMA 14-50 plug cable (EcoFlow PowerPulse Input Cable (NEMA 14-50P) is available on official website).
Which models of vehicles can match the charger?
The standard charge cable can be connected with SAE J1772 port, if used with Tesla, you need to purchase an additional adapter (EcoFlow PowerPulse J1772 to NACS Adapter is available on official website.
The max charging power is up to 9.6 kW as put in product advertising, but why is it only 7.2kW when connected with DPU/SHP2?
9.6kW is the maximum output power supported by this product, but when used with other products, its output capacity will be determined according to the main ecosystem product.
What's the IP rating of this product?
This product is NEMA 4 rated for protection against dust, weather and water spray.
How long is the product warranty?
This product has three-year warranty period.
What are the protection features of PowerPulse?
The PowerPulse features:
  1. 1.Grid overvoltage protection
  2. 2. Grid undervoltage protection
  3. 3. Output overcurrent protection
  4. 4. Grid overfrequency protection
  5. 5. Grid underfrequency protection
  6. 6. Leakage protection
  7. 7. Overtemperature protection
  8. 8. Surge protection
  9. 9. Ground fault protection
  10. 10. Contactor stick/reject alarm
  11. 11. Self-test fault alarm
  12. 12. CP voltage abnormal alarm
What's the rated parameter that this product can output?
Rated current 40A, rated voltage 240V, rated output power 9600W.
What's the product size?
Net weight: 333 × 226 × 145 mm(13.1 × 8.9 × 5.7 in) Package: 460 × 321 × 300 mm (16.1 × 12.6 × 11.8 in)
What's the product weight?
Gross weight: 8.7 kg Net weight: 6.2 kg
What's the noise level of this product?
The noise level is ≤ 35dB within 1 meter.
Which communication methods does PowerPulse support?
It supports OCPP1.6-J communication protocol; and WIFI (2.4G), WLAN, Bluetooth, CAN for communication method.
Output Power
Up to 40A, 9.6kW, NEMA 14-50p
Connector Type
SAE J1772/NACS(Adapter)
Input Configuration
5p8
NEMA 14-50p
Output Cable
7.5m
Ingress Protection Rating
NEMA type 4
3 years
Communication Method
Bluetooth/ WiFi/ CAN/ RS485
333 x 226 x 145 mm (13.1×8.9×5.7 in)
Weight
6.2kg
Fire-proof
5V(UL 2594)
Operating Temperature Range
‒30 ~ 50° C
Rated Input Voltage (V)
208/240VAC (L1, L2, Gnd)
Compatible Products
EcoFlow DELTA Pro Ultra, EcoFlow Smart Home Panel 2
1. Data based on EcoFlow laboratory testing results.
2. Charging times may vary with conditions and other factors.
3. Savings are estimated based on daily consumption of 10kWh, an electricity rate of $0.30 per kWh, and 365 days of use. Actual savings may vary depending on individual usage and electricity rates.
4. For vehicle owners with solar systems.
5. Input your utility’s rate schedule once during setup in the EcoFlow app.
6. The NEMA 14-50P outlet and compatible charging cable are sold separately.
* Unless specifically stated, the information provided in this product description is based on EcoFlow's technical parameters, laboratory tests, and supplier data. These specifications may vary in actual use due to factors such as usage environment, device condition and other factors.
** Unless specifically stated, the advertising claims on this page are for comparison with EcoFlow products series.
