EcoFlow PowerInsight 2 (Recommended Accessories)
/pages/delta-pro-ultra
*the function can only be access by EcoFlow Ocean Pro users
Automate Energy, Effortlessly Save
PowerInsight 2 learns your habits and the weather, then auto-adjusts devices based on your settings to extend backup power and cut bills. Set your rules, watch savings grow and sleep better knowing your system guards itself. Tap once to:
Shift loads to solar when the sun shines
Save battery before storms
Get smart tips to optimize usage
*Disconnect the microphone with a physical button to protect privacy
258.4 × 169 × 12.6 mm (H×W×D)
Button
Power on/off button + Volume adjustment button + Physical microphone disconnect button
Touchscreen
Fully laminated touch screen, glass surface + anti-fingerprint coating
WLAN
WLAN protocol: 802.11a/b/g/n/ac/ax; Frequency range: 2412 - 2472 MHz 5180 - 5320 MHz 5500 - 5700 MHz 5745 - 5825 MHz
Sensors
Photosensitive sensor: detects ambient brightness for screen brightness adjustment; ToF sensor: used for proximity screen-on, maximum sensing distance 1m, sensing distance error < 5cm
What are the usage scenarios and methods for EcoFlow PowerInsight 2?
It can be wall-mounted, handheld, or placed on a platform.
You can fix the mounting bracket to the wall and attach PowerInsight 2 to the bracket. (The bracket and mounting screws are included in the package.) If installed securely, the PowerInsight 2 screen will display "Charging" when turned on.
Flat: Use a desktop stand (sold separately) to place it on a table or hold it in your hand.
Note: The desktop stand is sold separately, while the wall-mounting bracket is included in the package.
Does it support external memory card expansion?
What are the differences between using PowerInsight 2 and running apps on a regular tablet? Can third-party tablets replace PowerInsight 2?
1. The current PowerInsight 2 supports EF voice function to wake up the AI assistant and perform the functions needed by users, while ordinary tablets + APP are restricted by the system and cannot use the EF voice function.
2. PowerInsight 2 can be used as a home control system, monitoring family electricity consumption data in real-time and controlling other Matter devices, while Apple Home no longer supports using the iPad as a home hub.
3. PowerInsight 2 supports CAN wired connections for more stability, while tablets do not support CAN wired connections.
4. PowerInsight 2 will automatically light up the screen when the user approaches, while the iPad does not have this feature.
5. PowerInsight 2 supports wall-mounted and handheld scenarios, making it more flexible as both a control system and a tablet, while the iPad does not have a wall-mounting function and cannot be powered via pins.
What are the new features compared to the first generation?
1. Smart voice is supported. You can turn on the microphone switch on the left side of the PowerInsight 2 to wake up the AI assistant with your voice and perform the desired functions.
2. The first generation of PowerInsight 2 uses the Matter 1.2 protocol, while the second generation uses the Matter 1.4 protocol, supporting more devices to be connected via the Matter protocol.
Does it need to be plugged in continuously? Can it be used independently?
It has a built-in 9300mAh battery and can be used as a standalone tablet. A full charge allows approximately 8 hours of continuous use.
Which third-party Matter-supported products can it be used with?
Third-party Matter-supported devices include smart light bulbs, smart plugs, thermostats, EVSE (electric vehicle supply equipment), heat pumps, water heaters, and room air conditioners.
Third-party devices:
- Smart plugs (Shelly, Kasa, Tapo)
- Thermostats (Ecobee, Google Nest, Tado)
- Smart meters (Shelly, Tibber Pulse)
Notes:
1. Ensure the Wi-Fi network connecting your mobile device is the same as that of the PowerInsight 2.
2. Only 2.4G/5G Wi-Fi local area networks are supported.
Does it support multiple PowerInsight/PowerInsight 2 devices being used simultaneously?
Yes. PowerInsight/PowerInsight 2 supports multi-device login under one account
Can firmware upgrades for connected devices be performed on PowerInsight?
Can PowerInsight remotely control device power on/off?
What sensors are built into the device?
Yes, it has:
An ambient light sensor (used to detect ambient brightness for screen brightness adjustment)
A ToF sensor (used to detect the distance between a person and the device, causing the screen to light up when a person approaches, with a maximum detection distance of 1 m and a detection distance error of less than 5 cm)
Does it support local network connection and control?
Supports LAN for Matter device connection and communication. Only supports 2.4G or 5G Wi-Fi.
What is Matter?
Matter is a relatively new communication protocol for smart home devices. It allows your devices to work with any Matter-certified ecosystem using a single protocol. Matter offers significant advantages in interoperability, simplicity, security, compatibility, and scalability.
How to add Matter devices to the EcoFlow ecosystem?
Follow these steps:
1. Pair your PowerInsight 2 with the EcoFlow APP. On PowerInsight 2, go to [Settings] > [Matter] > [Binding Matter] to display a QR code on the screen. Then, in the EcoFlow APP, tap [+] > [Scan] and scan the QR code to complete pairing.
2. Connect your Matter device to the EcoFlow APP by scanning the device's QR code with the app.
Can the EcoFlow APP scan the Matter QR code of EcoFlow Smart Plug to add the device?
No. To add an EcoFlow Smart Plug, open the EcoFlow App, tap [+] > [Add Device], and complete the process. This method provides more device data and smart services than scanning the Matter QR code.
What Wi-Fi requirements are there when adding Matter devices?
1. When adding a Matter device, your phone must connect to a 2.4 GHz WiFi network.
2. If your phone and PowerInsight are connected to a dualband WiFi network, some routers may not support adding Matter devices. If you encounter this issue, switch to a 2.4 GHz WiFi network and try again.
PowerInsight 2 Supported WiFi Parameters:
2.4 GHz
Frequency Range:
CN/BR/MX/EU/GB/JP/KR/AU: 2,412 2,472 MHz
TW/US/CA: 2,412 2,462 MHz
Maximum Output Power: <20 dBm (EIRP)
5.0 GHz
Frequency Range:
CN/MX: 5,180 5,320 MHz, 5,745 5,825 MHz
BR/AU/CA/US: 5,180 5,320 MHz, 5,500 5,700 MHz, 5,745 5,825 MHz
EU: 5,180 5,320 MHz, 5,500 5,700 MHz
JP: 5,180 5,320 MHz, 5,500 5,720 MHz
GB/KR/TW: 5,180 5,320 MHz, 5,500 5,720 MHz, 5,745 5,825 MHz
What are the weight and dimensions of PowerInsight 2?
Weight is approx. 620g (1.4 lbs)
Size is 258.4 x 169 x 12.6 mm (10.17 x 6.265 x 0.5 in)
What is the water resistance rating of PowerInsight 2?
What is included in the PowerInsight 2 package?
1. PowerInsight 2 display
2. Wall-mounting bracket
3. USB-C to USB-C power cable (2 m/6.6 ft)
4. Anchors and screws (x4)
5. Quick start guide and warranty card
What is the effective distance for the automatic wake-up feature?
After enabling the proximity wake-up screen option in PowerInsight 2's "Settings" > "Display and Brightness," the screen will auto-brighten when you approach within ≤1 m (≈39.37 in). The detection distance error is <5 cm.
Why can't some devices be added to PowerInsight 2?
Add new devices via the EcoFlow app on your phone. PowerInsight 2 will sync and show them. If a device isn't supported yet, it won't appear on PowerInsight 2.
What's PowerInsight 2's working mode and main functions?
The PowerInsight 2 display connects to the EcoFlow IoT cloud via Wi-Fi to access system data and manage the power system's lifecycle from generation to storage and consumption. It can also integrate other brands' devices via the Matter protocol, such as thermostats, smart plugs, and smart light bulbs.
How to pair third-party accounts?
In the EcoFlow app, tap "+" > "Add Device" > "Add third-party device" to pair third-party accounts, and the information will be synced to PowerInsight 2.
What are the screen specifications?
The screen is a 10.95-inch touchscreen with an aspect ratio of 16:10, resolution of 1920x1200, refresh rate of 60Hz, and typical brightness of 300nits.
What are the product's memory and storage parameters?
It has 6GB of memory and 64GB of ROM.
How many speakers and microphones are inside the product?
There are 2 speakers and 4 microphones.
What are the product's interface specifications?
The main unit has one Type-C port (USB3.0 transfer rate, supports 18W charging) and Pogopin (supports 30W power supply). The standard wall mount has two Type-C ports (one for power supply, the other for wired connection to other devices via CAN protocol) and a Pogopin probe (max 30W power supply).
What are the product's operating environment requirements?
Operating temperature: 0-45°C, storage temperature: -10-55°C, storage humidity: 10%-90%, operating altitude: below 3000m.
