Buy EcoFlow DELTA mini Portable Power Station | DELTA Mini (Refurbished)
EcoFlow DELTA mini Portable Power Station (Refurbished)
USD $389.00
Regular price USD $389.00
Sale price USD $389.00 Regular price $999.00
-$610
• The lightest DELTA model, designed for portability
• Large 882Wh capacity to power through almost any situation
• Powerful 1400W output for 90% appliances & power 12 devices at once
• 1.6 hours X-Stream fast charging
• 300W solar input, recharge in 2.5 hours
Power Station
USD $209 USD $399
22.8% Conversion Rate | IP68
USD $389 $999 -$610
Bring along DELTA mini and keep your devices powered at all times. DELTA mini’s 882Wh capacity is perfect for power outages, outdoor adventures, and professional work.
Big capacity
Portable
Power Multiple Devices
Solar Power
Pint-sized Powerhouse
More possibilities open up when you bring along 1400W for up to 12 devices. Whether it’s professional gear or the comforts of home, it’s good to know you’re good to go.
Charge Faster
DELTA mini snags up to 300W from solar panels for a full recharge in 3 to 6 hours. It can also go from 0-100% in 96 minutes when charging from the wall.
Smarter with the App
The EcoFlow app shows how much solar you’re bringing in and how many watts your slow cooker and mini-fridge are pulling. Connect it to the internet and control it from anywhere.Learn more
Solar charging
Harness the power of the sun by linking up to two 160W solar panels, and be fully charged in as little as 4 to 8 hours.
Car charging
Heading on a road trip? Charge DELTA mini along the way from your car outlet.
Wall outlet
Plug into any standard AC wall outlet to fast charge from 0–80% in under 1 hour with X-Stream charging.
Compare The Models
RIVER Pro
Capacity:720Wh
AC Output: 600W
Solar Input: 200W
$649
DELTA Mini
Capacity:882Wh
AC Output: 1400W
Solar Input: 300W
$999
DELTA
Capacity:1260Wh
AC Output: 1800W
Solar Input: 400W
$1399
23.6 lb (10.7 kg)
14.9 × 7.2 × 9.4 in (37.8 ×18.4 × 24 cm)
Charge Method
AC Wall Outlet, 12V Car Outlet, Solar Panel
Full Recharge Time
1.6 Hours (AC) 9½ Hours (12/24V Car Outlet) 3¾–7½ Hours (Using 2x 160W Solar Panels) 3–6 hours (Using 1x 400W Solar Panel)
882Wh
Cell Chemistry
NCM Li-ion
800 cycles to 80% capacity
Battery Management System
AC Charge Input Power
X-Stream Fast Charge 900W max
Solar Charge Input
300W 11–75V DC 10A max
Car Charger
12V/24V DC 8A default
AC Output (×5)
Pure Sine Wave, 1400W total (surge 2100W), 120V~ (50Hz/60Hz)
USB-A Output (×2)
5V DC, 2.4A, 12W Max, per port
USB-A Fast Charge (×1)
5V, 2.4A / 9V, 2A / 12V, 1.5A, 18W Max
5/9/12/15/20V, 5A, 100W Max
Car Power Output
12.6V, 10A, 126W Max
Charge Faster
Solar charging
Car charging
Wall outlet
23.6 lb (10.7 kg)
Charge Method
Full Recharge Time
882Wh
Cell Chemistry
NCM Li-ion
Solar Charge Input
Car Charger
AC Output (×5)
USB-A Output (×2)
Car Power Output
