EcoFlow DELTA 3 Classic Solar Generator | EcoFlow US | With 160W Solar Panel
EcoFlow DELTA 3 Classic Solar Generator EcoFlow DELTA 3 Classic Solar Generator EcoFlow DELTA 3 Classic Solar Generator
USD $619.00
Starting at 0% APR with Pay
Ends in
Days
1. Fast Charging Options – 4 ways to charge, including 0–80% in just 45 mins via AC. Portable solar panels collect up to 25% more energy with a two-in-one bifacial design, up to 25% conversion efficiency, and feature a 30–60° adjustable bracket with integrated angle guide.
2. Powerful Output – 1800W AC output (3600W surge) with X-Boost™ tech powers devices up to 2600W, including fridges, microwaves, laptops, and heated blankets.
3. Seamless Backup – 10ms auto-switch keeps critical devices like NAS systems and servers running without interruption.
4. Whisper-Quiet – Ultra-low noise ≤30dB at 600W for a quiet home or outdoor environment.
5. Built to Last – Automotive-grade full-tab LFP cells deliver 10 years of reliable use, with 24/7 BMS protection and EV-grade CTC structure. Solar panels use durable tempered glass and ETFE coating with IP68 rating to resist water and dust.
6. Compact & Portable – Lightweight design fits any setting, easy to carry indoors or outdoors.
7. Smart App Control – OASIS 3.0 app provides real-time monitoring, Storm Guard backup, self-powered mode, and scheduled tasks to save costs daily.
8. Extended Warranty – 3-year standard + 2-year extended via app registration. Includes solar-to-XT60 charging cable.
Learn more
Regular price USD $619.00
Sale price USD $619.00 Regular price
-$-619
Solar Panel Options
Selection Summary
EcoFlow D3C DELTA 3 Classic (1024Wh) + 160W Solar Panel EcoFlow DELTA 3 Classic Portable Power Station (1024Wh)
USD $619
USD $619
1kWh Ultra-Fast Charging, Ready in Just 45 Mins
EcoFlow DELTA 3 Classic (1024Wh)
Ready Fast. Trusted Always.
X-Stream: Ready in Just 45 Mins
DELTA 3 Classic (1024Wh) charges from 0–80% in just 45 minutes and fully charges in 60 minutes with AC charging. It keeps you powered faster, smarter, and with greater peace of mind—whether indoors, outdoors, or on the move. X-Stream enables ultra-fast charging without compromising battery life. It intelligently adjusts voltage and power to ensure safe, high-speed recharging. With X-Stream, you’re ready in just 45 minutes. [2]
4 Ways to Charge—Anytime, Anywhere
AC Charging
Generator Charging
Car Charging
Activate EcoFlow's exclusive Storm Guard Mode [3] to auto-start charging when extreme weather alerts hit—so you're always prepared, even when away.
Charge fully in 1 hour with 1400W hybrid smart generator input. [4] Ideal backup when solar isn’t an option.
Fully charged in 2.5 hours with 500W solar input. Clean, renewable energy—wherever the sun shines.
Charge to 80% in 1.8 hours or 100% in 2.5 hours using the EcoFlow 500W Alternator Charger. [5]
1800W Output, 3600W Surge
Power Essentials Without Compromise
EcoFlow DELTA 3 Classic (1024Wh) delivers a steady 1800W pure sine wave output with grid-level stability—enough to handle high-demand appliances like microwaves and power tools [6]. With X-Boost™ mode, it supports devices up to 2600W without tripping or slowing down—giving you seamless power for the moments that matter.
Kitchen
Living Room
Outdoors
Office
10ms Auto-Switch. Zero Interruptions.
When the power drops, DELTA 3 Classic (1024Wh) responds in just 10 milliseconds—fast enough to keep critical devices like NAS systems and servers running smoothly. No data loss. No downtime. Just uninterrupted peace of mind.
Built to Last
From battery chemistry to structural design, DELTA 3 Classic (1024Wh) is engineered for extreme durability, environmental resilience, and whisper-quiet performance—delivering power you can count on for over 10 years.[1]
Compact, Portable — Works Anywhere
Lightweight and easy to carry, DELTA 3 Classic (1024Wh) fits seamlessly into any setting, from your home to the great outdoors.
Monitor your energy usage and solar generation—all with one intuitive dashboard. Set timed charging/discharging missions so that you can charge during off-peak hours and discharge during peak rate periods to save costs.
Compatibility
What's In The Box?
[1] Based on proper product usage, DELTA 3 Classic (1024Wh) is estimated to have a lifespan of approximately 10 years, according to internal simulation test data. This information is for reference only; actual user experience may vary.
[2] All Charging speed data comes from EcoFlow labs and is for reference only. The actual data may vary slightly depending on the usage environment, device condition, software version, and other factors.
[3] Feature requires preset activation via the EcoFlow App.
[4] EcoFlow Smart Generators are sold separately.
[5] EcoFlow 500W Alternator Charger is sold separately.
[6] Single-appliance runtime based on ideal conditions; actual results may vary.
[7] Refers to the internal resistance of EF Full-Tab LFP Cells being 1.5mΩ, which is 25% lower than the 2mΩ internal resistance of the previous EF #C33 Battery Cell.
[8] A 25% reduction in single-cell internal resistance. According to the heat generation formula Q = I²Rt, under the same current, a 25% reduction in resistance leads to a proportional 25% decrease in heat generation.
[9] Unless otherwise noted, all images, videos, and screen display contents about the product itself on this page are for reference only. Actual product effects (including but not limited to appearance, color, and size) and screen display contents (including but not limited to backgrounds, UI, and illustrations) may vary.
12.1kg+0.3kg
Dimensions (HWD)
398mm×200mm×283mm
Rated Capacity
1024Wh 51.2V 20Ah
Cell Chemistry
LFP(LiFePO4)
120V~60Hz 1800W total
X-Boost
2600W
USB-A: 5V=3A,9V=2A,12V=1.5A,18W Max
USB-C1:5/9/12/15V=3A, 20V=5A, 100W Max
USB-C2:5/9V=3A, 15V=2A,30W Max
AC Input (Charge Only)
100-120V~15A 50/60Hz 1400W Max
Maximum PV Input Power(W)
500W
Optimal operating temperature
20°C to 30°C (68°F to 86°F)
Charge Temperature
0°C-45°C(32°F-113°F)
Discharge Temperature
-10 to 45°C(14°F-113°F)
Storage Temperature
5-Year Warranty
Communication Method
Wi-Fi & Bluetooth
UPS
10ms
