EcoFlow 2 x DELTA 2 Portable Power Station | (members only) EcoFlow 2xDELTA 2
EcoFlow 2 x DELTA 2 Portable Power Station EcoFlow 2 x DELTA 2 Portable Power Station
USD $849.00
Regular price USD $849.00
Sale price USD $849.00 Regular price $1,998.00
-$1,149
EcoFlow DELTA 2 solar generator: Secure your power supply with an EcoFlow DELTA 2 solar generator bundle at home or on the go. Plug in 110W Portable Solar Panels and get up to 500W input to charge from anywhere in as fast as 3-6 hours.
Expandable home emergency power 1-3kWh expandable capacity to grow your storage to your needs. Add on the DELTA 2 extra battery to reach 2048Wh, or add on the DELTA Max Extra Battery to hit 3040Wh. Great for home backup or everyday appliances.
Rapid dual charging X-Stream tech means that DELTA 2 charges 7 times faster than the competition. That’s 0–80% in just 50 minutes and 0-100% in 80 minutes with AC input. Plug in portable solar panels and charge in as fast as 3-6 hours.
Powerfully portable Designed with a rubber handle and flexible bracket stand, our solar panel can be used to adjust the angle from 0-45 degrees. Power multiple devices 1800W AC output means you can power more than 90% of your home appliances. Or, try plugging in up to 15 devices at once. Unlike other brands, DELTA 2 can prevent overloading from devices up to 2200W thanks to X-Boost technology. Learn more about DELTA 2 >>
Highly Efficiency  The one-piece, folding 400W portable solar panel is perfect for home, camping, and off-grid living. With high solar output and an improved efficiency rating of up to 23%, charge your portable power station even faster than before.
USD $849 $1,998 -$1,149
