EcoFlow DELTA Pro Ultra + DELTA Pro Ultra Extra Battery + Smart Home P | DELTA Pro Ultra + DELTA Pro Ultra Extra Battery + Smart Home Panel 2 + Free Trolley
EcoFlow DELTA Pro Ultra + DELTA Pro Ultra Extra Battery + Smart Home Panel 2 + Free Trolley
USD $6,999.00
Starting at 0% APR with Pay
Save $500 on Installation.
Auto-Applied at Checkout Until Feb 15.
Ends in:
EcoFlow DELTA Pro Ultra + Smart Home Panel 2 with EcoFlow's Official Installation Service
Secure your power from order to installation. Check for availability
-LFP battery
Learn more
Compare
Selection Summary
EcoFlow DPU-BUNDLE DELTA Pro Ultra + DELTA Pro Ultra Extra Battery + Smart Home Panel 2 + Free Trolley EcoFlow DELTA Pro Ultra + DELTA Pro Ultra Extra Battery + Smart Home Panel 2 + Free Trolley
USD $6,999 $11,296
USD $6,999 $11,296 -$4,297
  • 2-Day Delivery
Order DELTA Pro Ultra by 7 AM (PDT) for delivery within 2 business days across select regions in California, Arizona, and Nevada. See T&C for more eligible regions.
Learn More
Free Shipping Policy
Eligibility
Eligibility for expedited shipping is determined by the shipping address zip code, warehouse coverage, inventory availability, and logistics capacity. Orders that do not meet the eligibility criteria will follow standard shipping timelines.
Estimated Delivery Times (After Shipment)
For eligible orders, EcoFlow will offer a free expedited shipping upgrade for eligible orders, with the following estimated transit times:
-One-Day Delivery (Estimated): Southern California, Northern California, Northern Georgia, New Jersey, Maryland, Southern Texas, Eastern Texas, and Florida.
-Two-Day Delivery (Estimated): California, Arizona, Nevada, Georgia, South Carolina, New York, Connecticut, Texas, and Oklahoma.
Delivery dates are estimates and not guaranteed. Actual delivery may vary due to order volume, inventory availability, warehouse allocation, carrier capacity, weather conditions, or other factors beyond EcoFlow’s reasonable control.
Members' Benefits
Earn More, Save More: Get 1 EcoCredit per $1 spent – redeem 20 Credits for $1 off anytime, or exchange for exclusive gifts and discounts.
Join EcoCredits Monthly Madness: Unlock more EcoCredits fun! Available every 4th Thursday of the month.
Bonus Rewards: Earn extra EcoCredits when you refer friends – unlock cash bonuses and special perks.
Priority Support: Enjoy 24/7 assistance, extended warranty coverage, and seamless trade-in options.
VIP Access: Be the first to shop new products, attend members-only events, and get insider update. Sign up>>
Step 1: Order Placement
When placing an order, please provide your full delivery address and contact details.
T&C:
One-Day Delivery
One-Day Delivery
Order DELTA Pro Ultra by 7 AM (PDT) for delivery within 1 business day across select regions of Southern California, Northern Georgia, New Jersey, and Florida.
One-Day Delivery Regions
Ways To Pay
Ret SFC
Basically, we had a full load of house totaling 10kW+ and the DPUs did not miss a beat.
Jimmy
Very easy to set up, update firmware, and start using.
UltraFan
The Ultra's output power is far more clean and accurate than what is delivered from the public grid.
Michael A
Easy to select and buy. Easy to install. Quality of the DPU and the SHP2 is excellent.
Doug N.
Upgraded to the Delta Pro Ultra from the older Delta Pro. Twice the watts and 240v built in make this the best option for wholehouse backup power.
NavFed
I am in the middle of a storm that is flooding Southern California and powering most of my house right now from EcoFlow.
Psychentics
I really appreciate the Ecoflow Delta Pro product line up. It is cost effective and easy to use.
M-DB
Very impressive product! Recently bought this unit and very satisfied so far with the performance and the pre product support.
Month-long power security.
6-90kWh Capacity
5.6kW-16.8kW Solar Input
Flexible Solar Systems
Rigid Solar System
EcoFlow DELTA Pro Ultra works seamlessly with existing rooftop solar panels, replacing sensitive solar inverters prone to failure. Working in tandem with EcoFlow Smart Home Panel 2, maximize the value of your solar power and cut a chunk of change off your energy bill.
*This information is intended for users who have not installed a solar inverter.
Always in charge
With a Generator or EV pile
Peace Of Mind With An Advanced Design.
EcoFlow X-Cooling
Boost Performance with BMS
Our state-of-the-art LFP tech and advanced battery management system (BMS) regulates vital data, ensuring the safety, longevity, and high performance of EcoFlow DELTA Pro Ultra.With each battery offering a cycle life of 3500+, you'll get years of use before capacity drops to 80%. Even then, it keeps powering on.
290V high voltage tolerance
6144Wh, 102.4V⎓60A
30kWh (5 x DPU Battery)
AC Continuous Output
7200W
Expanable Capacity(System*)
90kWh (15 x DPU Battery)
AC Surge Output
10.8kW
Scalability(System*)
21.6kW
IP Rating
IP54
Battery Cycle Life
UPS
DC Output
12.6V⎓30A, 378W Max
AC Output Socket (Backup UPS)
2 x 120V, 20A Max per port
1 x 120V/240V, 30A Max
USB-A
AC Output Socket (Online UPS)
1 x 120V, 30A Max
USB-C
AC Input
Solar Charging Input
Total 5600W, 2 ports
Inverter Dimension
Inverter Net Weight
31.7 kg (70 lb)
Battery Dimension
Battery Net Weight
50.7 kg (111.8 lb)
5-year warranty
Connection
Bluetooth & Wi-Fi & 4G
Discharging temp
-20°C to 45°C | -4°F to 113°F
Charging temp
Storage temp
Hassle-Free bundle Installation Terms & Conditions
Installation Conditions
2. If a customer's house is too large, resulting in excessive wiring and undervoltage, there may be a risk that the NEC regulations will not be met, and the installation will be prevented.
3. In the event of unforeseen circumstances that may prevent installation, EcoFlow reserves the right to determine the final feasibility of installation.
Installation Service Package ONLY covers the installation labor costs.It does not include wiring the EcoFlow Power Station to solar panels or PV systems. If the customer requires the installation to include wiring to solar panels or PV systems, the electrician reserves the right to refuse to take order.
The installation service excludes:
a. Additional material and labor costs due to excessive distance or incompatibility between the existing circuit breaker and Smart Home Panel 2.
c. The electrician's on-site assessment fee, which can be waived if the circumstance has been assessed by the electrician to be suitable for installation and the customer does not request for refund of the installation service fee.
The above extra costs and fees shall be subject to the actual quote from the electrician. Customers are responsible for directly paying the electrician for any extra costs incurred. EcoFlow reserves the right to final interpretation of the installation service fee.
By agreeing to EcoFlow's installation services, you consent to the collection and processing of personal information necessary for completing the service. This may include, but is not limited to, your name, address, contact information, and any relevant details related to the installation. We will handle your personal information in compliance with applicable data protection laws and regulations and will only use it for the purpose of fulfilling the installation service. Please refrain from directly providing your personal information to the electrician during the installation process, otherwise you will be responsible for any loss or damage caused by the disclosure of such information.
3. Should a customer opt for our installation service and then decide to return the Smart Home Panel 2 due to dissatisfaction after installation, the paid installation fee cannot be refunded. Additionally, the customer will be responsible for any costs associated with the removal of Smart Home Panel 2.
4. The installation service does not include any cleaning or removal of debris generated during the installation process. Residents are responsible for managing and disposing of all trash and debris resulting from the installation.
5. Any holes or modifications made to the premises during the installation are considered normal and necessary for the proper completion of the service. The installer shall not be held liable for any unavoidable damages or alterations made to the premises during the installation process.
7. Any product issues or defects resulting from installation by an unauthorized installer shall be the sole responsibility of the resident. The resident shall bear full responsibility for any after-sales service or repairs needed due to such unauthorized installations.
Comparison
DELTA Pro Ultra
DELTA Pro 3
DELTA Pro
Discharging: Pure sine, 7,200W total, 120V/240V~ 60Hz
102.4V⎓60A, 6,144Wh
4kWh
3600Wh
102.4V⎓60A, 6,144Wh
4kWh
3600Wh
240V/30A
240v/20A
120v/15A
240V/30A
240v/20A
120v/15A
AC Input Charging: 100-120V~15A; 200-240V~12.5A, 50/60HzBypass: 100-120V~15A, 50/60Hz (duration < 3hrs when the current exceeds 12A)Solar Charging InputTotal 5600W, 2 portsHigh-PV Input: 80-450V/15A, 4000W MaxLow-PV Input: 30-150V/15A, 1600W Max
AC Charging Input1800W Max, 120V~15A, 3000W Max, 240V~12.5ASolar Charging Input1600W Max, 11-150V, 15A Max
120V AC Output Socket (Backup UPS): 2 x 20A Max per port
120V AC Output Socket (Online UPS): 2 x 20A Max per port
120V AC Output Socket (Online UPS): 1 x 30A Max
120V/240V AC Output Socket (Backup UPS): 1 x 30A Max
Total: 7
4 x NEMA 5-20R, 120V/20A
1 x TT-30, 120V/30A
1 x L14-30, 120V/240V/16.7A
1 x NEMA 6-20R, 240V/16.7A
Total: 7
1 x TT-30, 120V/30A
10ms
10ms
10ms
10ms
Up to 90kWh, 21.6kW
Up to 36kWh, 12kW
Up to 25kWh, 7.2kW
Up to 90kWh, 21.6kW
Up to 36kWh, 12kW
Up to 25kWh, 7.2kW
YES
Auto switchover <20ms when paired with EcoFlow Smart Home Panel 2
YES
NO
YES
YES
NO
Customized Widget Dashboard Third-party Devices Integration Future Electricity Price Analysis Generator Auto Start/Stop Self-Powered TOU Mode Scheduled Tasks API
DashboardThird-party Devices Integration Generator Auto Start/Stop Scheduled TasksAPI
Dashboard
Third-party Devices IntegrationGenerator Auto Start/Stop Scheduled Tasks API
Dashboard
Inverter: 31.7 kg (70 lb)
Battery: 50.7 kg (111.8 lb)
Approx. 51.5 kg
Approx. 45 kg
Approx. 51.5 kg
Approx. 45 kg
