EcoFlow DELTA 3 Portable Power Station | EcoFlow US | DELTA 3 + 220W Portable Solar Panel
EcoFlow DELTA 3 Portable Power Station EcoFlow DELTA 3 Portable Power Station EcoFlow DELTA 3 Portable Power Station EcoFlow DELTA 3 Portable Power Station EcoFlow DELTA 3 Portable Power Station EcoFlow DELTA 3 Portable Power Station EcoFlow DELTA 3 Portable Power Station EcoFlow DELTA 3 Portable Power Station EcoFlow DELTA 3 Portable Power Station EcoFlow DELTA 3 Portable Power Station
USD $849.00
Regular price USD $849.00
Sale price USD $849.00 Regular price $1,348.00
-$499
* 5 fast recharging methods (AC, Solar, 800W Alternator Charger, Smart Generator 3000 (Dual Fuel), Multicharging)
*5-year warranty
Extra 5% OFF
*Limited-time bundle-only discount – not valid for DELTA 3 unit. Use code at checkout!
Professional Outdoor Performance
1000W Max, Dual port, 70 min rapid solar charging
EcoFlow 800W Alternator Charger (Recommend)
USD $399 USD $599
USD $849 $1,348 -$499
AC Charging
Car Charging
Generator Charging
Multi-Charging
With EcoFlow's X-Stream technology and 1500W AC input, DELTA 3 charges from 0-100% in 56 minutes. A 30-minute charge provides hours of emergency backup before a power outage.
Solar Input with 500W MPPT, Full Charge in 2 hrs²
EcoFlow DELTA 3 with 500W MPPT charges fully in 2 hrs, even with limited sunlight. Outdoors, it recharges during lunchtime.
With 1500W max input, it takes 56 minutes to fully charge. During daily use, plug in both AC and solar to charge DELTA 3 , prioritizing solar to save money.
EcoFlow DELTA 3 supports 99% of household devices, including refrigerators, TVs, and computers. Plus, with X-Boost, continuously power appliances over 2600W, such as ovens (2150W), hair dryers (1800-2500W), and kettles (1200-3000W). Perfect for home backup, RV, and outdoor usage, this powerhouse ensures you're never left in the dark.
Home backup
Outdoors
RV
Professional work
30 dB Ultra-quiet Operation.
An intelligent energy management system powered by EcoFlow Oasis.
*EcoFlow DELTA 3 are compatible with Extra Battery of DELTA 3 Plus, DELTA Pro 3, DELTA 2 Max, DELTA 2.
Smaller Size, Same Power
1 Extra Battery, 5 x the Power
LFP Battery
IP65 Battery Pack
BMS
13 Outputs
Compact and lightweight
Approx. 397.6*202*283.6mm
(15.7*8.0*11.2in.)
Approx. 12.5kg
(27.6 lbs)
1024 Wh
Extra Battery
Support DELTA 2 EB, DELTA 2 Max EB, DELTA Pro 3 EB, and DELTA 3 EB (Up to 5kWh)
Total Output Ports
13
2200W
USB-A Output (Fast Charge)
2 ports, 18W Max
2 ports, 100W Max
Car Power Output
1 port, 12.6V, 10A, 126W Max
DC5521 Output
2 ports, 12.6V, 3A Max
AC Charging
1500W
DC Charge Input, 11V-60V 500W Max
1500W
Car Charging
800W, in 1.3 Hour
LFP (LiFePO4 battery)
4000 cycles to 80+% capacity
Connectivity
IP65
UPS
<10ms
Noise
600W<30db;1200W<40db
5 years
Footnotes
* Download the EcoFlow PowerManager App to activate the NAS support function on your computer, then install the NUT Server software on your NAS system, connect your DELTA 3 Plus, and activate HID support. The formal launch version will come later in December.
Stay in the Loop & Save More!
Price Drop Alerts
Cost Savings
Whole-Home Backup
Intelligence Solutions
Thank you for subscribing!
