EcoFlow DELTA 2 + EcoFlow DELTA 2 Smart Extra Battery
Regular price USD $799.00
Sale price USD $799.00 Regular price $1,798.00
-$999
  • Expandable capacityĀ - 1-3kWh expandable capacity to grow your storage to your needs. Add on the DELTA 2 extra battery to reach 2048Wh, or add on the DELTA Max Extra Battery to hit 3040Wh. Great for home backup or everyday appliances.
  • Huge AC outputĀ - 1800W AC output means you can power more than 90% of your home appliances. Or, try plugging in up to 15 devices at once. Unlike other brands, DELTA 2 can prevent overloading from devices up to 2200W thanks to X-Boost technology.
  • 7x Faster AC chargingĀ - X-Stream tech means that DELTA 2 charges 7 times faster than the competition. That’s 0–80% in just 50 minutes and 0-100% in 80 minutes with AC input.
  • Or go green without sacrificing speedĀ - Plug in portable solar panels and get up to 500W input to charge from anywhere in as fast as 3 hours.
  • Built to last 6x longerĀ - Get 10 years of daily use until hitting 80% of its original capacity. That’s down to its LFP battery chemistry giving you 3000+ cycles.
  • Control from anywhereĀ - Use the EcoFlow app to control your DELTA 2 from anywhere using Wi-Fi. Link with Bluetooth when off-grid. Either way, you can check charging data, customize settings and adjust the charging speed with ease.
  • 5-year warrantyĀ -Ā Unlock an extended 5-year warranty for worry-free experience.
ClickĀ hereĀ to learn more aboutĀ DELTAĀ 2 Smart Extra Battery.
    USD $799 $1,798 -$999
