Rapid cooling and heating
6100 BTU cooling power & 6800 BTU heating power
Drop 15℉ in just 15 minutes [1] with 6100 BTU power, setting an ideal environment for any scenario. Quickly warm up with 6800 BTU heating, raising the temperature by 17°F in just 15 minutes [2], perfect for staying cozy during chilly outdoor activities like autumn camping.
8 Hours of Wireless Comfort
1024Wh LFP Add-On Battery
The add-on battery offers up to 8 hours of uninterrupted use [3]—perfect for a full night of restful sleep. High-quality LFP cells ensure a lifespan of up to 10 years in daily use.
It's All on the App
Powered by EcoFlow Oasis
Easily manage everything from real-time battery status to water drain notifications, mode changes, and scheduled shutdowns—all from your phone, no matter where you are.
What's In The Box?
EcoFlow WAVE 3
EcoFlow WAVE 3 Add-On Battery
WAVE 3 Specs
Approximately 33.7 lb (15.3 kg)
20.4×11.7×13.2 in (519×297×336 mm)
Cooling Capacity
6100BTU (1800W)
Heating Capacity
6800BTU (2000W)
Temperature Setting Range
60.8-86℉ (16-30℃)
Refrigerant/Amount
R290/0.25 lb (R290/112 g)
Air Volume
330m³/h
Rated Cooling Power (AC/DC)
690W/640W
645W/606W
Cooling Efficiency (AC/DC)
2.6/2.8
Heating Efficiency (AC/DC)
3.1/3.3
AC Input
100-240V~50/60 Hz, 820W Max
Add-on Battery Input
700W Max
Operating Temperature
41-122℉ (5-50℃)
IP Rating
IPX4
Noise Level
44-58 dB
Remote Control
App (Wi-Fi(2.4G, 5G), Bluetooth)
Run Time with EcoFlow Add-On Battery
2-8 hr
WAVE 3 Add-On Battery Specs
Approximately 21.4 lb (9.7 kg)
20.3×11.1×4.4 in (516×281×111 mm)
Battery Capacity
1024Wh 51.2V 20Ah
80%+ capacity after 4000 cycles
Maximum Input Power
1000W Max
Automobile Auxiliary Power Outlet Charging Input
12V/24V,8A Max, 200W Max
Solar Input
11-60V, 13A Max, 400W Max
Maximum Output Power
858W Max
5/9/12V, 2.4/2/1.5A, 18W Max
5/9/12/15V⎓3A Max; 20V/28V⎓5A Max, 140W Max
Charge Temperature
32-113℉ (0-45℃)
Discharge Temperature
14-122℉ (-10-50℃)
IP Rating
IP65
EcoFlow WAVE 3 $100 For $200 Coupon Terms & Conditions
- The EcoFlow WAVE 3 Portable Air Conditioner Launch Campaign runs from April 18, 2025, at 12:00 AM PDT to May 25, 2025, at 11:59 PM PDT, with the official launch date being April 25, 2025, at 12:00 AM PDT.
- Purchase a WAVE 3 $100 for $200 Coupon from April 18, 2025, 12:00 AM PDT to April 24, 2025, 11:59 PM PDT can save even more.
- Coupon validation period: WAVE 3 $100 for $200 Coupon are available to buy from April 18, 2025, 12:00 AM PDT till April 24, 2025, 11:59 PM PDT. The coupon can only be used during our EcoFlow WAVE 3 launch (April 25, 2025, 12:00 AM PDT - May 25, 2025, 11:59 PM PDT). Once the EcoFlow WAVE 3 launch campaign has finished, the WAVE 3 $100 for $200 Coupon will expire. WAVE 3 $100 for $200 Coupon must be used before the designated expiration date. No extensions will be allowed under any circumstances.
- WAVE 3 $100 for $200 Coupons are good for one-time use only, are not transferable, are not for resale or auction, and cannot be substituted for any other item, cash or credit.
- The WAVE 3 $100 for $200 Coupon can only be used on WAVE 3 and related bundles:
a. WAVE 3
b. WAVE 3 + WAVE 3 Add-on Battery
c. WAVE 3 + WAVE 3 Add-on Battery + 500W Alternator Charger
d. WAVE 3 + WAVE 3 Add-on Battery + 220W Solar Panel
e. WAVE 3 + DELTA 3 Plus
f. WAVE 3 + DELTA 2 Max
This product list is for reference purposes only. Please refer to the product page for accurate and up-to-date details.
The WAVE 3 $100 for $200 Coupon may only be used on https://us.ecoflow.com/
How to use WAVE 3 $100 for $200 Coupon:
a. Only one WAVE 3 $100 for $200 Coupon can be used per order, and each email address can only use the WAVE 3 $100 for $200 Coupon once. Only one coupon can be used per order. Coupons cannot be combined. WAVE 3 $100 for $200 Coupon can be combined with WAVE 3 (super)early bird price (April 25, 2025, 12:00 AM PDT - May 25, 2025, 11:59 PM PDT). WAVE 3 $100 for $200 Coupons cannot be combined across multiple orders. WAVE 3 $100 for $200 Coupons cannot be combined with Flash Sales or other offers and promotions, unless otherwise stated.
b. After purchase, we will send you an email with a unique WAVE 3 $100 for $200 Coupon code. In order to receive WAVE 3 $100 for $200 Coupon coupon code successfully, you must subscribe to the EcoFlow email list. The personal information collected is subject to our Privacy Policy. To do so, check the ✔ box for “Email me with news and offers” upon checkout.
*If your WAVE 3 $100 for $200 Coupon code email is not in your inbox, please check your spam folder.
c.To redeem an online WAVE 3 $100 for $200 Coupon, enter the WAVE 3 $100 for $200 Coupon code in the cart at checkout.
An email address can only receive one WAVE 3 $100 for $200 Coupon code. If you purchase another code using the same email address, you will receive the same code. To purchase another code, please use a different email address.
Refund conditions:
a. If you purchased a WAVE 3 $100 for $200 Coupon and did not use it, please contact our AfterSales service team at support@ecoflow.com for a refund. We will only accept and process refunds after May 25th.
b. If a WAVE 3 $100 for $200 Coupon has already successfully applied to an order, we will not be able to offer a refund.
c. If you return any of the items purchased with a WAVE 3 $100 for $200 Coupon, the coupon discount or value may be subtracted from the return credit. For the WAVE 3 $100 for $200 Coupon (Pay $100 and get a $200 Coupon), the refund will be processed separately, based on the actual amount paid for the coupon.
EcoFlow reserves the right to modify, adjust, or terminate this campaign, with any changes, adjustments, or terminations being announced on the online sales platform.
EcoFlow reserves the right to amend the Terms & Conditions of this promotion at any time without prior notice.
EcoFlow reserves the right to decide on any dispute arising from or in connection with the promotion.
We reserve the right to cancel or limit any purchase or offer redemption made
1) contrary to the terms of each offer, discount, promotion or coupon;
2) that otherwise is not in compliance with our Terms of Use;
3) that violates any applicable law;
4) that we believe is fraudulent or made through improper channels.
There may be certain orders that we are either unable to accept or must cancel. We reserve the right, at our sole discretion, to refuse or cancel any order for any reason. We are not responsible for inaccuracies or errors.
