EcoFlow STREAM Plug & Play Solar System – Smart Home Power | STREAM Microinverter + 400W Solar Panels
EcoFlow STREAM Microinverter EcoFlow STREAM Microinverter EcoFlow STREAM Microinverter EcoFlow STREAM Microinverter
USD $799.00
Regular price USD $799.00
Sale price USD $799.00 Regular price $369.00
-$-430
Note:
Plug-in Solar installation of this product is currently permitted in Utah. More states are legalizing plug-in solar — check your local regulations before purchasing.
- UL1741 certificated & Build-in Output Overcurrent Protection, Output Overvoltage Protection, Anti-islanding Protection Features
- High efficiency with a 23%-25% conversion rate
- Actives with 3W solar input power your home even in low light
- NEMA 6 Water-resistant Rating
- Easy DIY installation
- 10-year warranty for long-term reliability
- AI-powered energy management for maximum efficiency
Option Name
USD $799
One-Step Plug & Play Solar System: Transform Any Space into a Solar Power Station¹
This adaptive solar solution turns any sunlit surface into a mini solar power station—from backyards to rooftops, gardens to vertical walls.
Capture Sunlight, Power Your Home — Save $385 Annually
The EcoFlow STREAM Plug & Play Solar System seamlessly integrates solar panels with a microinverter, converting sunlight into ready-to-use electricity for your home.It can power your Wi-Fi router, refrigerator, TV, and radio during the day. Capable of generating up to 2,409 kWh annually, this system can help you save up to $385 per year on energy costs.
Plug & Play: Start Generating Power in Minutes
No Drilling Required
The drill-free design allows flexible placement and easy movement—perfect for renters.
Easy DIY Setup
With a plug-and-play design, set it up yourself in no time—no electrician needed.
Flexible DIY Solar Panels for Optimal Energy Capture Flexible DIY Solar Panels for Optimal Energy Capture
IP68 Waterproof rating
Up to 23% Conversion Efficiency
All-black design that fits any house style
Dawn to Dusk, Rain or Shine:
Power Your Home Even in Low Light
The EcoFlow STREAM Plug & Play Solar System performs reliably even in low light. Its microinverter activates with just 3W of solar input, ensuring continuous power supply from early morning to dusk
EcoFlow App – Now Smarter with Eco-AI
Powered by Eco-AI, the EcoFlow app offers next-level smart energy management when connected to the EcoFlow STREAM Ultra Plug-in Solar Battery. AI-TOU Mode maximizes your savings by analyzing grid and solar data, while the AI Energy Assistant gives you 24/7 control. Customize energy routines and control devices remotely—anytime, anywhere.
AI-TOU (Dynamic Electricity Tariff)
24/7 AI Energy Assistant
The app cross-references electricity tariffs with your usage patterns and hourly weather forecasts to create the optimal bill-saving strategy. It automatically charges your battery during low-rate periods and switches to stored power during peak times. Manual tariff input is also supported⁷.
Your 24/7 AI Energy Assistant: Smarter, Simpler Power Your 24/7 AI Energy Assistant: Smarter, Simpler Power
Seamlessly integrates with multiple third-party smart meters, enabling real-time monitoring of your home’s energy use via the EcoFlow app.
Status Overview
Monitor all energy data in real time.
Savings Calendar
Track your daily and weekly savings.
Remote Control
Manage connected devices anytime, anywhere.
Easily Upgrade to Energy Storage in One Simple Step and Save More on Your Bills
Seamless integration with the EcoFlow STREAM Ultra—just connect and store. Scalable capacity from 1.92–11.52kWh lets you customize your storage setup to match your energy needs.
STREAM Microinverter Specs
Number of MPPTs
3
Number of PV Terminals
4 Pairs
Range of MPPT Voltage
16V-60V
Max. Input Voltage
60V
Start-up Input Voltage
20V
Max. Input Power
1200W (450W per MPPT)
Max. Input Current
3 × 14A
Max. Input Short Circuit Current
3 × 20A
Nominal Output Power
1200W
Max. Output Current
10A
Nominal Output Voltage
120V
Output Voltage Range
105.6V-127.2V
Nominal Output Frequency
60Hz
310 × 236 × 35.5 mm / 12.2 × 9.3 × 1.4 in.
Communication
Wi-Fi, Bluetooth
Type of Isolation
Galvanically Isolated HF Transformer
Built-in Feature
Operating Temperature
–40°C to 65°C / –40°F to 149°F
Weight
5.0 kg / 11.0 lb
IP Rating
NEMA 6
10 years
Q&A
Are there any household electricity billing requirements when using the STREAM Microinverter? If the requirements are not met, what should I do?
1. Before purchasing or using this product, please confirm whether your household's electricity billing supports net metering.2. If not, we do not recommend purchasing or using STREAM Microinverter. If you still wish to experience a solar power system, you may consider using STREAM Ultra together with Shelly Pro 3EM. For more details, please refer to the STREAM Ultra FAQ and User Manual.
How can I confirm whether my household electricity billing supports net metering?
Please contact the utility company to confirm whether net metering is supported for your house.
Can the AC output cable plug be connected to a power strip?
Due to safety regulations, this is not recommended.
How should I connect multiple solar panels to my STREAM Microinverter?
When connecting multiple solar panels in series or parallel, ensure that the maximum operating voltage (V) and maximum operating current (I) of each panel group do not exceed the limits of a single PV port on the STREAM Microinverter:
Maximum Operating Voltage: 60V
Maximum Operating Current: 14A
If you require extension or parallel cables for solar panels, they can be purchased separately from EcoFlow.
Additionally, each group of solar panels connected in series or parallel must have consistent Maximum Operating Voltage (V) and Maximum Operating Current (I).
Can the STREAM Microinverter connect to 5G WiFi?
Currently, it only supports 2.4GHz WiFi.
Is the STREAM Microinverter waterproof and dustproof?
The STREAM Microinverter has a NEMA 6 rating and can be used indoors/outdoors. We recommend installing it in a well-ventilated, shaded, and cool location.
Can multiple STREAM Microinverters be used simultaneously?
It is advised to purchase or use them in compliance with local laws and regulations.
How does the system continue supplying power during a blackout?
For safety reasons, the STREAM Microinverter will automatically detect grid power anomalies and stop power output during a blackout.
Can EcoFlow’s Portable Power Stations be used in a system with the STREAM Microinverter?
The STREAM Microinverter is exclusively compatible with EcoFlow STREAM Ultra. For a more intelligent and higher-yield system experience, we recommend purchasing additional EcoFlow STREAM Ultra.
Can I install the STREAM Microinverter myself?
The system can be installed and maintained by users themselves (only available in Utah, USA now).
*Please refer to the Power Connection Requirements section under the Environment chapter in the QUICK START GUIDE to choose the installation method that suits your household situation.
*Each time you change the installation location, please refer to the above information again.
Does the STREAM Microinverter require separate grounding?
EcoFlow provides AC cables with an equipment grounding conductor/grounding plug. If the cable is plugged into a socket that is properly installed and grounded according to all local codes and regulations, the device will be correctly grounded.
If you are unsure about the socket’s grounding status or if local regulations mandate specific grounding standards, contact a qualified electrician to establish proper grounding via the product’s grounding terminal. For detailed procedures, contact EcoFlow technical support.
Can I use third-party solar panels?
Yes, third-party solar panels are compatible if they meet the PV input specifications and use MC4 connectors. The input range per PV port is:
Operating Voltage: 16-60V
Operating Current: ≤14A
How to monitor the electricity generated by the STREAM Microinverter in real time?
On the EcoFlow app, you can view real-time statistics of energy generation.
Is elevated temperature during operation normal?
A moderate temperature increase during operation is normal and will not impact product longevity. The system undergoes rigorous testing and incorporates a multi-stage thermal management system. For safety and performance, install the unit in a well-ventilated, non-sun-exposed area, away from children/pets.
Footnote:
1. Due to restrictions under the H.B. 340 Solar Power Amendments, this product is only available for plug-and-play installation within the state of Utah. Please consult with local professionals before installing rigid solar panels on rooftops or using the STREAM Microinverter with third-party rooftop installations.
2. Projected power generation values are based on the use of 1 × EcoFlow STREAM Microinverter under simulated conditions, calculated with 5.5 hours of sunlight per day in the U.S., including weather factors such as rain throughout the year.
3. The estimated savings are based on projected generation from 1 × EcoFlow STREAM Microinverter, combined with the average U.S. electricity rate. Actual savings may vary depending on regional utility rates, usage patterns, and environmental conditions.
4. Self-consumption is calculated using power generation estimates from 1 × EcoFlow STREAM Microinverter, aligned with average annual U.S. household electricity use. Results may vary based on location, climate, and system configuration.
5. Certain AI features in the EcoFlow app require a premium subscription. Please refer to the EcoFlow app for details on subscription plans and feature availability.
6. Due to restrictions under the H.B. 340 Solar Power Amendments, this product is only available for sale and plug-and-play installation within the state of Utah.
