EcoFlow Smart Home Panel 2 | Ultimate Power Control | EcoFlow Smart Home Panel 2 + 2 x DELTA Pro Ultra
EcoFlow Smart Home Panel 2 EcoFlow Smart Home Panel 2 EcoFlow Smart Home Panel 2
USD $11,799.00
Regular price USD $11,799.00
Sale price USD $11,799.00 Regular price
-$-11,799
-Intelligent subpanel for home battery systems
-20 ms auto switchover
-EcoFlow app control
-Modular design
-12-circuit sub-panel
*Note: Smart Home Panel 2 requires installation before use, and the specific fee will depend on the assessment, and 'EcoFlow DELTA Pro Ultra + Smart Home Panel 2 + Installation' and  'EcoFlow DELTA Pro 3 + Smart Home Panel 2 + Installation' includes installation services.
EcoFlow DELTA Pro Ultra + Smart Home Panel 2 with EcoFlow's Official Installation Service
Secure your power from order to installation. Check for availability
Recommend
EcoFlow Installation Service Installation Service for Smart Home Panel 2 Turnkey Installation Service
Live Installation Support for SHP2/SHP3/Gateway
USD $0
By selecting this service, you agree to EcoFlow Live Installation Support Terms & Conditions (United States)
You acknowledge and consent that the Live Installation Support Service may record the site survey and installation process. Such recordings may capture identifiable images of you or other individuals present at the installation site. These recordings will be used solely for installation documentation and the resolution of any related disputes, and will be retained for no longer than 180 days, after which they will be securely deleted.
USD $0
USD $0
By selecting this service, you agree to the Installation Service Terms and Conditions.
USD $0
USD $0
USD $0
USD $11,799
An intelligent subpanel for outage protection and savings in one.
The EcoFlow Smart Home Panel 2 is the center of your whole-home backup solution, working alongside EcoFlow DELTA Pro Ultra, generators, and solar panels to protect your home. With a fast, automatic switchover, you'll have reliable backup whenever you need it. Its Smart Energy Management system extends backup duration and forecasts outages through hourly weather checks. Smart Home Panel 2 customizes your energy usage based on time-of-use rates and your home's solar energy production.
The commanding force behind your power system.
The Whole-Home Backup System Hub
EcoFlow Smart Home Panel 2 is the hub of the powerful EcoFlow DELTA Pro Ultra that allows you to get the full potential out of your energy system. Connect your home circuits with up to 3 plug-and-play inverters and 15 stackable 6kWh batteries, it not only takes care of your backup for even longer but allows you to control and run every single household appliance.EcoFlow Smart Home Panel 2 is not only future-proofed to work with our next-gen power solutions, but it works with EcoFlow DELTA Pro, too.
Even plan B has a plan B.
Compatible with Solar and Gas Generators
EcoFlow Smart Home Panel 2 can manage your energy from various sources, including solar and gas. With the sun's rays, brighten your home with cost-effective green energy and dramatically reduce your electricity expenses.When the weather turns gray and you're all out of sunshine, a seamless connection to any 3-12kW portable gas generator ensures your home stays energized without a hitch.
The nights of fumbling for a torch are over.
20-ms Auto-Switchover
When an outage hits, there's no need to brave the dark, cold night to switch to your backup manually. EcoFlow Smart Home Panel 2's automatic switchover feature ensures your home remains powered even when you're away. Forget spoiled food and damaged appliances. Embrace uninterrupted power so that life never stops.
Leave the power prep to the pro.
EcoFlow App
EcoFlow Smart Home Panel 2 ensures your home is blackout-proof with ample energy at all times. Even when an outage lingers on, it's business as usual.
EcoFlow App
Backup Extension
Emergency Weather Prep
Categorize your home circuits into three levels of power supply priority with Circuit Control mode. Ensure protection for the most mission-critical tasks and massively extend backup time.
With automatic storm warnings mode, batteries fully recharge 24 hours before an extreme weather event. Locking energy until an outage occurs. EcoFlow Smart Home Panel 2 monitors the weather hourly, updating the system based on the forecast, offering a more precise backup strategy.
Savings just roll on in.
With the EcoFlow App
With Backup Reserve mode, EcoFlow Smart Home Panel 2 secures an assigned battery percentage. Fear an impending outage? Set a higher reserve for home backup. For everyday use, set a lower portion and customize your EcoFlow Smart Home Panel 2's performance using Self-Power, Scheduled Tasks, or TOU Modes to lower your energy bills.
TOU Mode
Based on Time Of Use peak and off-peak rates and your energy habits, EcoFlow Smart Home Panel 2 intelligently manages battery charge and discharge, significantly offsetting electricity costs.
Self-Power Mode
Once battery capacity exceeds the pre-set reserve, solar begins to top up energy supplies while powering the home to lower utility bills.
See your entire energy strategy at work.
EcoFlow App, PowerInsight & Web Dashboard
View real-time energy insights for your home anywhere you go. On your phone, wall-mounted dash, or even online. Get a complete home energy consumption overview as well as solar and gas input, battery capacity, and much more. With EcoFlow Smart Home Panel 2 comes PowerInsight, a wall-mounted screen, and a web dashboard, accessible anywhere online.
EcoFlow app
EcoFlow PowerInsight
Web dashboard
Monitor, control, and customize your power usage at your fingertips.
Home Energy Manager, an all-in-one dedicated monitor.
A full suite of data and customizations accessible online.
Fits into your home with ease.
Modular design
To work with your home layout, decor, and to save space, we've split EcoFlow Smart Home Panel 2 into two modules—a battery connection box and a distribution panel. Install each separately or together with less wiring and more flexibility to place your batteries.
What’s in the box
*For 30 minutes of use.
The 3-ton central air conditioner's LRA rating must be within 120A.
3.X-Fusion technology ensures that all AC output sockets provide optimal output in terms of wattage and amp. In fast charging mode, the output will always be 7.2kW, no matter how much the input is.
Switch to fast charging for a continuous 7200W output.
If you connect the DELTA Pro Ultra to PV system circuits installed on or in buildings, according to NEC regulations, the system shall include a rapid shutdown function to ensure operation safety and reduce shock hazards for emergency responders. If you wish to connect the DELTA Pro Ultra to PV system circuits, a pre-purchase consultation must be completed by a qualified electrician or installer.
EcoFlow Trolley Gift Activity Terms & Conditions
Article 1: Event DescriptionEvent Period: From January 9, 2024, 12 AM (EST) to February 9, 2024, 11:59 PM (EST).Eligibility: This event is only applicable to the first 300 customers who purchase at least one EcoFlow DELTA Pro Ultra and one EcoFlow Smart Home Panel 2 in a single order during the event period.Gift: Qualified customers will receive a trolley valued at $299. Limited to one trolley per customer.Eligibility Confirmation: Customer eligibility will be determined based on the order of completion of payment during the event period. Only orders fully paid within the event period will be considered.Gift Distribution: The gift will be shipped in February. Gifts are limited and available while supplies last.Geographical Restrictions: This event is exclusive to the EcoFlow US Online Store (us.ecoflow.com).Article 2: Additional TermsNon-Returnable/Non-Exchangeable: The gift accompanying the purchase is non-refundable, non-exchangeable, and ineligible for after-sales service or cash redemption.Liability: The organizer is not responsible for any delays or damages during the shipment of the gift.Rights Reserved: The organizer reserves the right to modify, suspend, or terminate the event at any time without liability to participants or third parties.Article 3: Legal ResponsibilityAgreement to Terms: Participation in this event signifies your agreement to these terms and conditions.Interpretation Rights: The final interpretation right of these terms and conditions of the gift usage belongs to the company.
Terms and Conditions for EcoCredits
Article 1: EcoCredits AccumulationApplicability: These terms apply to all members participating in the EcoFlow Membership Program (hereinafter referred to as "Members").Triple EcoCredits on Specific Products: Members can earn triple EcoCredits (hereinafter referred to as "EcoCredits") when purchasing designated products (hereinafter referred to as "Specific Products").Specific Products: Include purchases of an EcoFlow DELTA Pro Ultra Inverter, EcoFlow DELTA Pro Ultra Battery, EcoFlow Smart Home Panel 2, EcoFlow DELTA Pro Ultra (Inverter+Battery), EcoFlow DELTA Pro Ultra+EcoFlow Smart Home Panel 2, 2 × EcoFlow DELTA Pro Ultra + EcoFlow Smart Home Panel 2 made on the EcoFlow US Online Store (us.ecoflow.com).Geographical Restrictions: This program is exclusive to the EcoFlow US Online Store (us.ecoflow.com).Article 2: EcoCredits CalculationTriple EcoCredits Period: Valid from January 9, 2024, 00:00 (EST) to February 9, 2024, 23:59 (EST).Calculation Basis: EcoCredits are calculated based on the actual payment amount for Specific Products, excluding amounts involving coupons, EcoCredits redemption, returns, or cancellations.Accumulation Ratio: EcoCredits will be accumulated at three times the actual payment amount for Specific Products.EcoCredits Credit: EcoCredits will be automatically credited to the member's account after the transaction is completed and payment is confirmed, along with EcoCredits from other products.Inquiries: For any questions regarding EcoCredits accumulation or calculation, please contact the customer service department.Article 3: Legal StatementAgreement to Terms: Participation in this program signifies your agreement to these terms and conditions.Interpretation Rights: The final interpretation right of these terms and conditions of EcoCredits usage belongs to the company.
Ecoflow Installation Terms & Conditions (United States)
I. Scope of Installation Service
A. Service Content
This installation service is strictly limited to the standard installation service of the EcoFlow Smart Home Panel 2 (“SHP2”) , EcoFlow Smart Home Panel 3("SHP3"), EcoFlow Smart Gateway("ATS") or any bundle that includes the SHP2, SHP3 and ATS alongside other EcoFlow products, including but not limited to the Delta Pro/ Delta Pro Ultra/ Delta Pro Ultra X Series (collectively referred to as the “Products”). Standard installation service includes on-site visit by a certified electrician and the installation of the Products, including replace the existing load center with SHP3, wiring the SHP2/SHP3/ATS to the existing load center.Please note that this installation service does NOT include wiring the Delta Pro/ Delta Pro Ultra/ Delta Pro Ultra X Series to solar panels or photovoltaic (PV) systems, nor does it cover the cleaning or disposal of any debris generated during the installation process. If a user requests wiring to solar or PV systems, the electrician reserves the right to decline the installation service.
B. Installation Conditions
The user's home electrical system must fully comply with all applicable local government regulations and electrical standards. Any unauthorized modifications to the home circuit—i.e., changes made without official government approval—will render the property ineligible for installation.If the user's residence is unusually large, resulting in extended wiring distances or undervoltage risks, the installation may fail to meet the requirements of the National Electrical Code (NEC) or other applicable codes and regulations. In such cases, the installation cannot proceed.Furthermore, in the event of any unforeseen circumstances that affect the safety, legality, or practicality of the installation, EcoFlow reserves the sole right to determine the final feasibility of performing the service.
C. Territory:
Our installation service covers most areas in the United States. Please verify coverage by entering your ZIP code during checkout. If the order cannot be placed, it indicates your area is currently not serviced - please contact customer support for assistance. Note: ZIP code verification may have minor discrepancies. If service is ultimately unavailable in your location, our customer service team will contact you and process your refund.
D. Service Benefits
The installation service benefits promoted are exclusively available to users who place an order and complete a successful payment for the installation service through the official EcoFlow website (https://www.ecoflow.com/us & https://us.ecoflow.com/). Orders made through third-party platforms or other sales channels are not eligible for these benefits.
Important Notification on Power Outage:
During the installation of the Smart Home Panel 2 (SHP2), Smart Home Panel 3 (SHP3), or Smart Gateway (ATS), there will be a temporary power outage lasting several hours at the installation site. Users are advised to prepare in advance for any impact on household appliances, business operations, or other electricity-dependent activities.
II. Installation Fees and Additional Costs
Before proceeding with installation, please note that additional travel costs, labor costs, excess materials, or permit application fees may apply depending on local conditions, regulatory requirements, or site-specific circumstances.
A. Installation Service Fee Coverage
The standard Installation Service Fee for Smart Home Panel 2 (SHP2), Smart Home Panel 3 (SHP3), or Smart Gateway (ATS) ONLY covers the standard installation labor costs. Scope of Standard Installation:Smart Home Panel 2 (SHP2): Replacement of the existing electrical panel; or installation as a sub-panel located within 2 (two) feet from the existing electrical panel, including back-to-back installation on opposite sides of the same wall within this distance.Smart Home Panel 3 (SHP3): Replacement of the existing electrical panel; or installation as a sub-panel located within 2 (two) feet from the existing electrical panel, including back-to-back installation on opposite sides of the same wall within this distance.Smart Gateway (ATS): Installation upstream of the existing electrical panel and located within 2 (two) feet from it, including back-to-back installation on opposite sides of the same wall within this distance.
B. Exclusions from the Installation Service Fee
The installation service fee listed on the official EcoFlow website does NOT include the following additional costs, which must be borne by the user:
- All materials, hardware, and accessories required to either connect the Smart Home Panel 2 (SHP2), Smart Home Panel 3 (SHP3), or Smart Gateway (ATS) to the upstream distribution panel, or replace the existing distribution panel with the SHP2, SHP3, or ATS.
- Replacement or addition of electrical components such as Overcurrent Protection Devices (OCPD), outdoor disconnect, EPO, circuit breakers, fuses, junction boxes, fuse box, electric meter box, distribution panel, etc. The costs for such electrical components required for installation, as well as the labor costs associated with their installation, shall be borne by the user. If local regulations require the installation of certain electrical components, failure to comply may result in fines or enforcement actions by the Authority Having Jurisdiction (AHJ). Such penalties shall be the sole responsibility of the user.
- Existing electrical panel upgrade.
- Permit application fees required by local regulations or utility companies, and any engineering design and drawing costs associated with PE‑stamped drawings, if applicable.
- Electrician’s on-site visit fee. This fee may be waived if (a) the user proceeds with the installation service, and (b) the electrician confirms that the installation site meets the necessary installation conditions.
- Any structural modifications, wall openings, patching, painting, or non-electrical work needed to complete the installation.
- Additional labor costs for installing the Smart Home Panel 3 (SHP3) or Smart Gateway (ATS) as a sub‑panel located more than 2 (two) feet from the existing electrical panel..
- Additional travel costs if the installation site is located outside the electrician’s standard service area.
C. Permit fee coverage
A permit application fee of $500 will be charged on the official website. If the actual permit application fee exceeds $500, the user shall pay the amount exceeding $500 directly to the electrician. The permit application fee and any engineering design and drawing costs, where applicable, shall be based on the invoice or receipt provided by the electrician.
D. Payment Method
Any additional fees not covered by the standard installation service—such as materials, or permit application fees—must be paid directly by the user to the electrician, based on the actual quotation provided and the prevailing local permit costs. EcoFlow reserves the right to the final interpretation of the installation service fee and its applicable scope.
III. Service Limitations and Liabilities
A. Independent Service Agreement
The installation service constitutes a direct agreement between the customer and the electrician. Ecoflow is NOT a party to this agreement and therefore assumes no responsibility or liability for the electrician’s pricing, workmanship, performance, or service quality.
B. Service Refusal Based on Property Assessment
The electrician reserves the right to refuse installation service if, upon on-site assessment, the property is determined to be unsuitable for installation. In such cases, the user remains responsible for the cost of the on-site assessment, regardless of whether the installation proceeds.
C. Liability for Unauthorized Installation
EcoFlow shall NOT be held liable for any product issues, defects, or damages resulting from installation performed by an unauthorized installer. In such cases, the user shall bear full responsibility for any required after-sales service, maintenance, or repairs, and such services may not be covered under EcoFlow’s standard warranty or support policies.
D. No Refund after Installation
Once the installation service has commenced, the installation fee is non-refundable, regardless of the outcome. If the user is dissatisfied with the product after the Product(s) has been installed and wishes to request a return, the user shall be responsible for (a) the non-refundable installation fee, and (2) the full cost of removing the installed SHP2/SHP3/ATS. These costs will not be covered by EcoFlow under any circumstances. Ecoflow Installation Service Refund Policy can be found at https://us.ecoflow.com/pages/installation-refund-policy
E. Cancellation After On-Site Assessment
If the user cancels the installation service after the electrician has conducted an on-site assessment, but before the comemencement of the installation of the Products, the installation fee will be refunded, less a deduction for the on-site assessment fee. This assessment fee may be up to USD $500, and the exact amount varies by state.
IV. User Responsibilities
A. Accurate Information Provision
When placing an order, the user must provide accurate personal details, including shipping address and home installation address. The user is also responsible for ensuring that someone is present at the premises and that the provided contact information is reachable at the time of the engineer’s visit.
If the user needs to reschedule the installation, they must notify EcoFlow customer service via the official hotline or other designated methods at least one (1) day in advance. Failure to do so may result in an on-site visit fee of up to USD $500, which will be charged to the user.
B. Installation Conditions Assurance
The user shall ensure that their residence, existing distribution panel, and electrical load equipment meet the required installation conditions. If installation cannot proceed, or if additional costs arise due to issues with the home’s infrastructure or non-compliance, the user shall bear full responsibility for such circumstances and related expenses.
V. Disclaimer and Final Interpretation
A. Service Interruption
EcoFlow does not guarantee that the installation service will be free from interruptions, delays, or failures. EcoFlow shall NOT be held liable for any service interruptions caused by force majeure, third-party actions, or circumstances attributable to the user.
B. Limitation of Liability
To the fullest extent permitted by applicable law,
Ecoflow and its affiliates shall NOT be liable for any indirect, incidental, or consequential damages arising from or related to the installation service, including but not limited to property damage, loss of use, or loss of profits, unless such damages result from Ecoflow's gross negligence or willful misconduct. In all cases, the total liability of Ecoflow and its affiliates shall be limited to the amount actually paid by the user for the installation service.
C. Wall Damage
The drilling of holes or structural modifications made during the installation process are deemed standard and necessary procedures to complete the service. The installer shall not be liable for restoring or repairing any normal wall damage or alterations (such as drilling, mounting, or cutting) that occur as part of the installation.
D. Final Interpretation and Updates
EcoFlow reserves the right to the final interpretation of these Installation Terms and Conditions. Users are encouraged to review these Terms periodically, as EcoFlow may update or modify them at its sole discretion without prior notice.
How does Smart Home Panel 2 differ from Smart Home Panel 1 and the transfer switch?
Smart Home Panel 2 is equipped with 12 circuits and can be expanded to a capacity of up to 90kWh with a 21.6kW output, and it can receive a maximum solar input of 16.8kW. Additionally, it includes enhanced features on the EcoFlow APP, such as storm guarding and Time of Use (TOU) functionalities. These features can help save money by automatically switching from grid to backup power during high rate periods and in the event of an impending natural calamity.
Will installingEcoFlow Smart Home Panel 2 and EcoFlow DELTA Pro Ultra affect NEM 2.0?
How long is theEcoFlow DELTA Pro Ultra warranty?
What is the Smart Home Panel 2and Delta Pro Ultra weatherprotection level?
Does EcoFlow DELTA Pro Ultra work with an existing grid tied system that does not have a backup feature?
Why can't the smart home panel be connected to a rooftop solar system using AC coupling?
What if my house panel is already connected to a rooftop solar system?
Which device combinations does Smart Home Panel 2 support?
