EcoFlow Smart Gateway (200A) EcoFlow Smart Gateway (200A)
USD $1,699.00
Regular price USD $1,699.00
Sale price USD $1,699.00 Regular price
-$-1,699
  • Set it and forget it with 6 controlled circuits
  • Automatically sheds non essentials for seamless backup
  • Switches under 20 ms
  • Smarter Savings up to $6,000/year
  • Extend Backup time by up to 42%
Recommended
EcoFlow Installation Service Installation Service for Smart Home Panel 2 Turnkey Installation Service
Live Installation Support for SHP2/SHP3/Gateway/SHP10
USD $0
By selecting this service, you agree to EcoFlow Live Installation Support Terms & Conditions (United States)
You acknowledge and consent that the Live Installation Support Service may record the site survey and installation process. Such recordings may capture identifiable images of you or other individuals present at the installation site. These recordings will be used solely for installation documentation and the resolution of any related disputes, and will be retained for no longer than 180 days, after which they will be securely deleted.
USD $0
By selecting this service, you agree to the Installation Service Terms and Conditions.
USD $0
USD $0
USD $1,699
6 Independently Controlled Circuits · 200A Max Current · 120/240V Support
Effortless Energy Simplicity
EcoFlow Smart Gateway is a 200A intelligent panel with six remote-control circuits. Compatible with DELTA Pro Ultra X, solar, EV chargers, and generators, it switches in under 20 ms and automatically sheds non-essentials to extend backup—keeping your essentials running longer.
When Blackouts Hit: Lights Stay On
Smart Control, Always Reliable Regardless of Weather
Seamlessly Compatible with High-Power Generators
20 ms Auto Switchover Time
Smart Gateway transitions from grid to battery faster than a blink, so your home keeps running without interruption.
42% More Backup Time
Through the EcoFlow app, categorize appliances as “must-haves” or “nice-to-haves.” Critical loads stay on, while non-essentials automatically scale back—giving you up to 42% more backup time.
Backup for Your Backup
Build a multi-source backup system with DELTA Pro Ultra X and your generator. Just Connect your split-phase generator to Smart Gateway via its 5+8 port—no rewiring or extra hardware—and power your home while charging the battery.
Turn Sunlight Into Savings, No
Watt Wasted
For DIY Solar, Power Your Home for Less
Track and Use Every Solar Watt
Pair Smart Gateway with DELTA Pro Ultra X for true self-power. Once the battery reaches your set reserve, surplus solar flows directly to home appliances —free solar first, cheaper power all day, and backup ready at night.
Paired with a Current Transformer, Smart Gatewat tracks your rooftop generation in real time and directs surplus solar to your DELTA Pro Ultra X. No more waste, no more pennies to the grid.
Smart Saving with AI TOU Mode
Slash Bills with Your PowerPulse
AI Mode automatically manages battery charges and discharges based on solar forecasts and peak/off-peak rates, cutting your power costs. Before rainy days, it fills the battery with solar or off-peak power, bypassing peak rates with ease.
With AI charging—solar by day, off-peak by night—your EV stays ready. If your EV consumes 10 kWh per day, this system can save you up to $1,095 annually—equal to a year of free commuting.
The Fastest Installation
7 Days, 3 Steps
DAY 1 – Installer Match
DAY 2–6 – Site Visit
DAY 7 – One-Day Installation
After your installation order is placed, we’ll match you with an EcoFlow Authorized Installer. Nationwide coverage—from sunny California to snowy Maine.
*7‑Day Installation counts from permit issuance (after purchase & delivery) until on‑site installation is complete.
An Authorized Installer will schedule a visit to your home, analyze your setup, and plan installation.
Smart Home Panel 3 is wired, the EcoFlow app is set up. We provide end-to-end support, including initial app setup, so everything is safe and ready to use.
–30℃ to 50℃ Operation
Whether in extreme heat or freezing winters, Smart Home Panel 3 safeguards your power security.
10 Years
Enjoy complete confidence with a 10-year warranty.
Fast, Hassle-Free Install
Split design for clean indoor and outdoor placement.
What's in the box?
65.5±0.4lb(29.7±0.2kg)
Dimensions (HWD)
385 × 188 × 905mm (15.16 × 7.40 × 35.63 in.)
Overvoltage Category
IV
Rated Input Voltage (V)
120/240V, 120/208V,60Hz
Enclosure Protection
NEMA 3R
Operating Temperature Range
-30~50℃(-22~122℉)
Storage Temperature Range
-30~50℃(-22~122℉)
Maximum Operating Altitude
≤3000m(9842.52ft)
Branch Circuit Rated Current
60A*6 circuits output
Maximum Branch Output for the Backup Panel
200A
Noise Emission
≤40dB
Certificates
UL67, UL869A, UL916, UL1741
10 Years
EMC
FCC Part 15B
FCC Part 15C
Communication Method
Bluetooth/Wi-Fi/Ethernet/CAN/RS485
Main circuit power detection accuracy
0.5%
Sub circuit power detection accuracy
1%
Ecologically compatible products
EcoFlow DELTA Pro Ultra Inverter/EcoFlow DELTA Pro Ultra X Inverter/PowerPulse EV Charger
Which EcoFlow Portable Power Stations does the Smart Home Panel 3/Smart Gateway support connecting to? Does it support the DELTA Pro 3?
Currently, it only supports connecting the DELTA Pro Ultra X via the EcoFlow Smart Inlet Box Connection Cable (5P8 Port to 5P8 Port) or connecting the DELTA Pro Ultra to the Smart Inlet Box (Smart Home Panel 2 Upgrade) via the EcoFlow Power Input/Output Cable. You can also connect the DELTA Pro Ultra X and the DELTA Pro Ultra simultaneously using the cables that meet the corresponding requirements.Currently, it does not support connecting the DELTA Pro 3. For future updates, please refer to the official information.
Will the Smart Home Panel 3/Smart Gateway send the power from the Backup Battery back to the power grid? Will it affect the use of the existing photovoltaic system?
No, the Smart Home Panel 3/Smart Gateway is not a grid-connected system. The power of the Backup Battery will only be supplied to the branch circuits inside the system and the Sub-Panel connected to the Smart Gateway, and will not be output to the power grid.The Smart Home Panel 3/Smart Gateway only indirectly utilizes the existing photovoltaic system and will not affect its original functions.
What types of Generators does the Smart Home Panel 3/Smart Gateway support for use as Backup Power, and do I need to purchase any accessories?
It supports 3 - 12kW split - phase 240V generators. Connect it to the AC1 - 5p8/GEN IN port of the Smart Inlet Box (Smart Home Panel 2 Upgrade) via the EcoFlow AC Generator Charging Adapter (NEMA L14 - 30P to 5P8 Port) (allowing the generator to generate 3 - 7.2kW) or the EcoFlow Generator Charging Adapter (NEMA 14 - 50P to 5P8 Port) (allowing the generator to generate 3 - 12kW). In addition, we need to remind you that you must connect at least one DELTA Pro Ultra X/DELTA Pro Ultra to the AC2/3 port of the Smart Inlet Box for the generator to generate electricity.
What are the maximum rated current and peak current of the mains input allowed by the Smart Home Panel 3/Smart Gateway respectively?
Rated current: 160A; Peak current: 200A
What is the waterproof rating of the Smart Home Panel 3/Smart Gateway? Can it be installed outdoors?
The protection level of the Smart Home Panel 3/Smart Gateway is NEMA 3R, which is waterproof and can be installed indoors or outdoors.However, the Smart Inlet Box (Smart Home Panel 2 Upgrade) used in conjunction with it has a protection level of NEMA 1, is not waterproof, and can only be installed indoors.
What is the EPS mode of the Smart Home Panel 3/Smart Gateway? Can it be enabled simultaneously with the Operating modes: AI Mode, Self-powered, and Scheduled tasks?
Enabling the EPS mode allows the system to switch to the powered-on Backup Battery within 20ms during a power outage, reducing the impact of power outages on the important loads in your home.
*Note that for the EPS to take effect within 20ms, only the powered-on DELTA Pro Ultra X should be included in the connected Backup Battery.
*When the DELTA Pro Ultra is connected, the EPS mode and Operating modes cannot be enabled simultaneously; and if the DELTA Pro Ultra is in the charging state under EPS mode, it cannot switch to the DELTA Pro Ultra for power supply within 20ms at the moment of a power outage.
Does the Smart Home Panel 3/Smart Gateway support 5G WiFi connection?
It is not supported. Only 2.4G WiFi is supported when connected via WiFi.
Does the Smart Home Panel 3/Smart Gateway only support household electricity of 120/240V~ (split phase)? My apartment uses commercial electricity of 208Y/120V~, 3W (from 3Ø 4W). Can it be used?
The Smart Home Panel 3/Smart Gateway supports household electricity of 120/240V~ (split phase) and commercial electricity of 208Y/120V~, 3W (from 3Ø 4W). You just need to ask your electrician to find the corresponding live wire, connect the wires according to the Installation Guide, and select the corresponding voltage in the Grid Setting of the APP.
Who can install the Smart Home Panel 3/Smart Gateway?
The Smart Home Panel 3/Smart Gateway must be installed by EcoFlow authorized installers and licensed electricians, and the installers must have successfully completed the EcoFlow product training. If you are interested in contacting an authorized installer, please select the Installation Service when making a purchase. If you already have installers but they haven't obtained the relevant materials for installing EcoFlow products, please go to Support->User Manual on the EcoFlow official website and download the latest Installation Guide for the corresponding product so that they can start learning and performing the installation.
How long does it take to install the Smart Home Panel 3/Smart Gateway?
The installation time of the Smart Home Panel 3/Smart Gateway may vary depending on the scope of work required and the current wiring configuration of your home. For most households, the Smart Home Panel 3 can be installed within 10 hours, and the Smart Gateway can be installed within 6 hours.
How many years is the warranty for the Smart Home Panel 3/Smart Gateway?
The warranty period for the Smart Home Panel 3/Smart Gateway is 10 years. For specific warranty terms, please refer to the "Warranty Service" Card inside the packaging box.
How does the EcoFlow Smart Home Panel 3/EcoFlow Smart Gateway help save money?
When your system is equipped with solar panels or your household electricity price has peak and off-peak periods, you can choose AI Mode or Self-powered Mode according to your household situation. Charge the battery during low electricity price periods or when *solar energy is predicted to be available, and use the battery to power your home during high electricity price periods or when there is redundant solar energy. In addition, you can also use the Smart Circuit Settings to turn on/off some circuits with high standby power consumption at a scheduled time, and only run them when necessary.*Solar forecast requires subscribing to the professional feature package - Energy Master. For specific subscription rules and feature details, please refer to the latest information in the APP.
Which circuit breakers are compatible with Smart Home Panel 3/Smart Gateway?
The Smart Home Panel 3/Smart Gateway is compatible with industry-standard single-pole and double-pole circuit breakers. For specific Main Circuit Breakers and Branch Circuit Breakers, please refer to the Circuit Breaker Compatibility section in the Installation Guide.
Is it necessary to drill holes on the Smart Home Panel 3/Smart Gateway to reserve an entry for the cables during installation?
There are already 5 knockouts reserved on the body of the Smart Home Panel 3/Smart Gateway. If you still need more cable holes, it is recommended that you use a hydraulic hole puncher and keep the plastic protective cover inside the machine in place during the punching process to prevent iron filings and other debris from damaging the machine during the process.
Can the Smart Home Panel 3/Smart Gateway be used as a Sub-Panel in the home?
Yes, but please note that when used as a Sub-Panel, you need to remove the Main bonding jumper between the Main neutral terminal and the Main ground terminal.
If my local electrical regulations require me to install an external emergency stop switch [EPO] when installing the Smart Home Panel 3/Smart Gateway, how should I meet this requirement?
Both the Smart Home Panel 3 and the Smart Gateway have an EPO port reserved inside the product. When you have a need, you can optionally purchase an Emergency Power Off Button when buying the main product and install it according to the Installation Guide in the Support -> User Manual on the official website.
If my local electrical regulations require me to have an overcurrent protection device [OCPD] between the Smart Home Panel 3 or Smart Gateway and the Backup battery storage, where should I install it?
You can install an overcurrent protection device [OCPD] in the middle of the Smart Inlet Box Connection Cable (5P8 Port to 5P8 Port). The actual OCPD specifications shall comply with your local electrical regulations. We recommend that you use a 70A 2P circuit breaker.
Does the use of Smart Home Panel 3 or Smart Gateway have any requirements for the APP version?
You need APP version ≥ 6.8.5 to add Smart Home Panel 3 or Smart Gateway to the APP for use.
Does the Smart Gateway support connecting rooftop photovoltaic circuit to the branch circuits?
When the Smart Gateway is located upstream of the Main-Panel, you can connect the rooftop photovoltaic circuit to the branch of the Smart Gateway to improve the utilization rate of photovoltaic power and reduce electricity costs.*The operation of connecting the rooftop photovoltaic circuit must be carried out by an EcoFlow Installer after purchasing EcoFlow's Installation Service, and the settings should be made on the EcoFlow Pro APP.
