EcoFlow RIVER Bank | Default Title
EcoFlow RIVER Bank
EcoFlow RIVER Bank
Regular price USD $194.00
Sale price USD $194.00 Regular price
-$-194
Up to EcoCredits for cash deduction. Log in
RIVER Bank is the largest capacity rechargeable battery in the world that you can take on a plane. It is smart, packed with power (Up to 94Wh, 25,600 mAh @3.7V), and lightweight (1.88 Ibs).
  • Unthinkably Versatility
  • More Ports: The Rarely Seen Hub function allows you to plug in more USB devices. Fast and Reliable charging, yet still allows us to connect multiple devices simultaneously.
  • Half Your Recharging Time: Breakthrough Technology – Bidirectional PD Input(45W)/Output(60W), reducing the Recharging Time to 1.5 hours for up to 90% (with 2*45W wall charge)
  • Flying with RIVER Bank: The ONE portable charger that is allowed on board at this capacity.
*Please NOTE: This item is only applicable to orders in the US mainland states(except Hawaii, Alaska, the Virgin Islands and Puerto Rico).
USD $194
Travel Together
Bring along 25,600mAh (94Wh) of capacity, which is just within how much you can take on a plane.
Doubles as a Hub
Transfer files to your laptop from the extra USB ports on the back of RIVER Bank.
Two Ways to Recharge
Go from 0 to 100% in under 3 hours with wall charging, or opt for solar charging by connecting a solar panel. Power devices while you recharge with pass-through charging.
What’s in the box
1.RIVER Bank 2.USB C Cable 3.User Manual
Compare The Models
RIVER Bank
Capacity:94Wh
Size: 5.28 × 3.45 × 1.02 in
Fast Charge
2 USB-A; 2 USB-C
$194
RAPID PLUS Power Bank
Capacity:36.4Wh
Size: 3.00 × 2.32 × 1.06 in
Fast Charge
1 USB-A; 1 USB-C
$59
RAPID Power Bank
Capacity:18.2Wh
Size: 3.00 × 1.38 × 1.06 in
Fast Charge
1 USB-A; 1 USB-C
$39
RIVER Bank adapts to any 10–22V power source that is connected to either USB-C port.
Yes, this is possible with its pass-through charging technology.
We recommend storing RIVER Bank with more than 30% battery and in a cool and dry place.
1.88 lb (850 g)
Dimension
5.28 × 3.45 × 1.02 in (13.41 × 8.76 × 2.59 cm)
Certifications
FCC, CE, UN 38.3
Operating Temperature
32 to 113°F (0 to 45°C)
25600mAh @3.7V (94Wh)
Cell Type
18650 Li-ion Battery by LG
Lifespan
500 cycles (80% of original capacity)
Shelf Life
6 months after full recharge
Output
9W max Positionless charging, Qi standard
USB-A
Both USB-A ports are fast charging
Port 1
5V/9V/12V — DC 1.5A, 18W max
Port 2
USB-C
Both USB-C ports input and output power
Input
5V/9V/15V — DC 3A; 20V — DC 2.25A; 45W max Total Input: 90W
Output
5V/9V/15V/20V; up to 3A, 60W max Total Output: 120W
Highlights of RIVER Bank
  • Portable with a huge 25,600mAh capacity, with additional support for wireless charging.
  • Recharge RIVER Bank through solar or AC outlet.
  • Charge up to five devices simultaneously or act as a three-port USB hub while charging your laptop.
  • Features two fast-charging 60W USB-C PD ports, two full-size 24W USB-A ports
  • Informative LED screen displaying watt input/output and remaining time.
Two Ways To Power RIVER Bank
  • Recharge from the sun by connecting a compatible solar panel. Fully recharge RIVER Bank within 6-9 hours (weather dependent)
  • Recharge fully from AC outlet in 2-3 hours.
Specifications
General Info
Net Weight1.88 lbs (850 g)
Dimension5.28”x3.45”x1.02” (13.41×8.76×2.59 cm)
CertificationsFCC, CE, UN38.3
Operating Temperature32℉ to 113℉ (-20-60°C +/- 3°C)
Battery Info
Capacity94Wh, 25600mAh @3.7V
Cell Type18650 Li-ion battery by LG
Life Span500 cycles (depleted to 80% of original capacity)
Shelf Life6 months
Wireless Charging
Output9W max
Position Free Charging Experience
Supports any Qi standard device
USB
Port 15V/9V/12V 1.5A, 18W max
Port 25V/9V/12V 1.5A, 18W max
USB-C Input & Output
Input5V/9V/15V 3A; 20V 2.25A; 45W max   Total Input: 90W
Output5V-9V-15V-20V; up to 3A, 60W max   Total Output: 120W
USB-A Fast Charge (x1)5V DC,9V DC,12V DC,2.4A,28W Max
Both USB-C ports are bidirectional Input/Output charging
ProductQuantity
RVIER BANKx 1
USB C Cablex 1
User Manualx 1
User Manual
  • Click to Download the RIVER BANK User Manuel
