EcoFlow PowerInsight 2
USD $499.00
Regular price USD $499.00
Sale price USD $499.00 Regular price
-$-499
· 11-inch touch screen
· Real-time home's energy flow
· Smart Home all-in-one. One screen to rule different devices
· AI Assistant Voice Control
USD $499
The Visual Hub of Your Smart Home Energy System
Watch electricity flow like water—simple and intuitive
Simplified, intuitive energy data, high-resolution clarity, and game-like visuals. The whole family easily see your real-time home's energy flow – solar generation, battery reserves, and appliance usage – without squinting, zooming, or switching apps.
See Your Energy, See your Home
PowerInsight 2’s clear dashboard shows exactly where every watt goes—solar power, battery storage, and home usage. Powered by OASIS, it turns complex data into simple insights.
Power your home. Treasure your memories
Turn your energy hub into a digital photo frame. Upload favorite moments as the lock screen—so every glance shows sunny days, birthday laughs, and cozy nights.
VIP service Access*, your 24/7 expert energy concierges.
Tap the VIP button in PowerInsight 2. Your dedicated energy expert answers in 30 seconds or less—24/7. No waiting, no hassle—just instant solutions.
*the function can only be access by EcoFlow Ocean Pro users
Smart Home all-in-one. One screen to rule all
Now with Matter 1.4, it connects and controls lights, thermostats, EV chargers, heat pumps, and more—all in one place. Plus, PowerInsight 2 works with Google Nest, ecobee, and other top brands. No more app-hopping between smart plug, HVAC, and lights. Simple control. Smarter home. Less hassle.
Automate Energy, Effortlessly Save
PowerInsight 2 learns your habits and the weather, then auto-adjusts devices based on your settings to extend backup power and cut bills. Set your rules, watch savings grow and sleep better knowing your system guards itself. Tap once to:
Shift loads to solar when the sun shines
Save battery before storms
Get smart tips to optimize usage
Talk. Command. Live easier
Voice control. Enjoy intuitive, hands-free power management. Ask PowerInsight 2 for an energy report or adjust settings—hands-free from across the room. Just speak naturally within 5 meters, and your home listens.
*Disconnect the microphone with a physical button to protect privacy
Built to Last, Works Anywhere
With a 9,300mAh big battery, larger than most of android pad (same size). It runs 24+ hours screen-off—no daily charging needed.
Specifications
Specifications
258.4 × 169 × 12.6 mm (H×W×D)
Net Weight (lb)
Approx. 620g
Color
Black
Button
Power on/off button + Volume adjustment button + Physical microphone disconnect button
Size
10.95 in
Type
IPS
Resolution
1920 × 1200 pixels
Touchscreen
Fully laminated touch screen, glass surface + anti-fingerprint coating
NPU Computing Power
6 TOPS
ROM
64GB
RAM
6GB
Battery
9300mAh
Charging
18W wired fast charging
WLAN
WLAN protocol: 802.11a/b/g/n/ac/ax; Frequency range: 2412 - 2472 MHz 5180 - 5320 MHz 5500 - 5700 MHz 5745 - 5825 MHz
IoT Support
Wi-Fi, BLE, Matter
Sensors
Photosensitive sensor: detects ambient brightness for screen brightness adjustment; ToF sensor: used for proximity screen-on, maximum sensing distance 1m, sensing distance error < 5cm
What are the usage scenarios and methods for EcoFlow PowerInsight 2?
It can be wall-mounted, handheld, or placed on a platform. You can fix the mounting bracket to the wall and attach PowerInsight 2 to the bracket. (The bracket and mounting screws are included in the package.) If installed securely, the PowerInsight 2 screen will display "Charging" when turned on. Flat: Use a desktop stand (sold separately) to place it on a table or hold it in your hand. Note: The desktop stand is sold separately, while the wall-mounting bracket is included in the package.
Does it support external memory card expansion?
What are the differences between using PowerInsight 2 and running apps on a regular tablet? Can third-party tablets replace PowerInsight 2?
What are the new features compared to the first generation?
Does it need to be plugged in continuously? Can it be used independently?
Which third-party Matter-supported products can it be used with?
Does it support multiple PowerInsight/PowerInsight 2 devices being used simultaneously?
Can firmware upgrades for connected devices be performed on PowerInsight?
Can PowerInsight remotely control device power on/off?
What sensors are built into the device?
Does it support local network connection and control?
What is Matter?
How to add Matter devices to the EcoFlow ecosystem?
Can the EcoFlow APP scan the Matter QR code of EcoFlow Smart Plug to add the device?
What Wi-Fi requirements are there when adding Matter devices?
What are the weight and dimensions of PowerInsight 2?
What is the water resistance rating of PowerInsight 2?
What is included in the PowerInsight 2 package?
What is the effective distance for the automatic wake-up feature?
Why can't some devices be added to PowerInsight 2?
What's PowerInsight 2's working mode and main functions?
How to pair third-party accounts?
What are the screen specifications?
What are the product's memory and storage parameters?
How many speakers and microphones are inside the product?
What are the product's interface specifications?
What are the product's operating environment requirements?
