Power Hub 5kVA with Cable Pack
USD $3,499.00
Regular price USD $3,499.00
Sale price USD $3,499.00 Regular price $3,499.00
-$0
The first 200 customers* to place an order will become EcoFlow Elite200 Users.
USD $3,499
The hassle-free, high-powered EcoFlow 5kVA Power Hub is the newest version of EcoFlow's integrated, plug-and-play 48V off-grid power solution designed for camper vans, motorhomes, trailers and RVs of any kind.
Includes:
5 kVA Power Hub
5 kVA Power Hub AC Charge Cable (4.5m/14.9ft)
5 kVA Power Hub Alternator Charge Cable (6m/19.8ft)
5 kVA Power Hub DC Main Out Cable (4.5m/14.9ft) 3AWG
5 kVA Power Hub AC Main Out Cable (4.5m/14.9ft) 6AWG
5 kVA Power Hub Solar Charge Cable (6m/19.8f) x 2
Installation/Mounting Hardware.
Net weight
15.7kg (34.6 lb)
Dimension (HWD)
300 x 480 x 151 mm (11.8 x 18.9 x 5.9 in)
Communication
Wi-Fi(2.4G, 5G), Bluetooth
GPS
Supported
IP Rating
IP 20
AC Output(Discharge Only)
120V~4000W, 5000VA, 60Hz(Surge 10KVA)
AC Output(Bypass Mode)
100-120V~50A Max, 50/60Hz
X-Fusion (Power Assist)
33.3A Max, 5000VA Max
DC Output(12V/24V)
13.6V⎓100A Max, 1360W Max; 26.4V⎓60A Max, 1584W Max
48V DC Output / Smart Generator (48V)
51.2V⎓55A Max
USB A Output
5V⎓2.4A Max
EF BUS Output (x2)
12V⎓Total 1.2A Max
Total Output
8752W Max
AC Input (Charge Only)
100-120V~ 4000W Max, 50Hz/60Hz
AC Input (Bypass Mode)
100-120V~50A Max
Alternator Input 1 / PV Input 1
13-60V⎓100A Max, 4000W Max
Alternator/PV Input 2/3
13-60V⎓30A Max, 1600W Max
BATTERY 3 / Smart Generator
40-57.6V=100A Max
40-57.6V=70A Max
Charge
40-57.6V⎓100A Max per port, total 270A Max
Discharge
40-57.6V⎓100A Max per port, total 181A Max
Operating Temperature
-25°C to 60°C (-13°F to 140°F), derating>40°C (104°F)
Discharging Temperature
Storage Temperature
-25°C to 70°C (-13F to 158°F)
Operating Humidity
0%-95% RH (non-condensing)
Altitude
<2,000 m (6,562ft)
5 Years
