Already have an account? Sign In
EcoFlow Members only: Log in & Save Now
Electric Vehicle Charging: With the grounding adapter, use a DELTA Pro or DELTA 2 Max/DELTA Max/DELTA 2 to charge your EV safely as an emergency backup power, giving you the extra mile.
For DELTA Pro:
For DELTA 2 Max, DELTA Max, DELTA 2,DELTA 3 Classic,DELTA 3 Max,DELTA 3 Max Plus,DELTA 3 Ultra,DELTA 3 Ultra Plus:
Only use the USB-C Cable included with a portable power station grounding adapter. The Cable does not have any charging function, and other USB-C cables should not be used instead.
Adding product to your cart
Please note the difference in voltage between the US and EU. If you are a Ukraine user we will redirect your to the EU site to continue shopping.
Since each region has specific voltage and plug requirements, we'll redirect you to your location.
You’ll be redirected to our Canadian site for a better shopping experience. Here’s a special welcome gift — use code WELCOMETOCA at checkout!
Your shopping cart is empty
I agree to EcoFlow's Privacy Policy and Terms of Service.
* EcoCredits can be redeemed for discounts and gifts
I agree to comply with EcoFlow’s Privacy Policy and Terms of Use.
We'll help you create an account. You can also register with password.
- Or log in with -
Only one add-on per order. Remove it from your cart to pick another.
We've added a free gift to your cart.
The free gift has been removed as your cart no longer qualifies.
You now qualify for a free gift with your order.
