EcoFlow GLACIER + EcoFlow DELTA 2 Max
EcoFlow GLACIER + EcoFlow DELTA 2 Max EcoFlow GLACIER + EcoFlow DELTA 2 Max
USD $2,799.00
Regular price USD $2,799.00
Sale price USD $2,799.00 Regular price $2,998.00
-$199
WHY THIS BUNDLE
• Charge more than 6 cycles of plug-in battery
• Cooling for up to 7 days
• Runs even longer with 100% clean energy (with 400W Portable Solar Panel)
DELTA 2 Max
• Expandable capacity - 2-6kWh expandable capacity to fit your energy storage needs. Add up to two DELTA 2 Max Smart Extra Batteries to hit a capacity of 6144Wh. Ideal for home backup, RVing, outdoors or even everyday use.
• Built to last 6× longer - Get 10 years of daily use until hitting 80% of its original capacity. That’s down to its LFP battery chemistry giving you 3000+ cycles.
• Huge AC output - With X-Boost mode get up to 3400W output power to run 99% of home appliances. Power 15 devices at once including 6 AC outlets.
•Fastest recharging - World's fastest AC recharging and X-Stream dual AC+Solar charging speeds. Up to 1000W solar input to charge in as fast as 2.3 hours.
GLACIER
• Dual zone, dual control
• 38L large capacity
• Detachable suitcase design
• Smart app control
*Plug-in Battery, detachable wheels and lever are sold separately.
Solar Panel
USD $2,799 $2,998 -$199
Industry's first integrated ice maker.
120W compressor
Equipped with a powerful 120W compressor, it brings you 18 solid ice cubes in 12 minutes.* For all the spine-tingling moments along your journey, spice them up with chilled sodas.
* The test result was gained with the ambient temperature of 77℉ (25°C) and water temperature of 59℉ (15°C). The first round of ice making might take longer than 12 minutes.
A fridge-freezer at its best.
Dual zone, dual control.
Equipped with a removable divider separating it into two zones, and independent temperature control, both sections can refrigerate and freeze from 50°F (10°C) to -13°F (-25°C). Steak, cheese, or soft drinks...whatever you want to stock up on, it shape-shifts to meet your needs.
The fastest cooling in the industry.
Cooling at the optimum speed when empty, GLACIER rapidly refrigerates from 86°F (30°C) to 32°F (0°C) in around 15 minutes.
Cooling for up to 40 hours wire-free.
298Wh plug-in battery
Designed for absolute portability, GLACIER can be powered by the Plug-in Battery* and free from messy, limiting cables.With a large battery capacity of 298Wh, savor up to 40 hours[3] of easy access to frozen meals, fresh fruit, and ice-cold beverages.
*Plug-in Battery is sold separately.
Charge laptops and more on the go.
100W max USB-C
With 100W max USB-C charging, it even powers up your phones and laptops so you'll never lose touch with your loved ones.
Durable, Safe, Lightweight
LFP Battery Chemistry
Advanced BMS Protection
Robust Design
Upgraded Tech, Lighter Weight
Power pretty much anything with up to 3400W Output
DELTA Max powers almost all the devices you need with a large 2400W AC output. With X-Boost proprietary technology, run appliances with an output of up to 3400W. Compared with similar portable power stations, DELTA 2 Max can power more devices while also preventing overloading and overheating.
Power for the entire family
2048Wh Capacity
Home Backup
RVing & Outdoors
DIY Projects
Filmmaking & Photography
Expandable up to 6kWh
Triple the power
Experience the world's fastest 43 minute recharge
Fuel Up 80% in Only 43 Mins*
With DELTA 2 Max's upgraded tech, combine up to 1000W solar input with AC for world-leading charging speeds. In only 43 min get an 80% charge. Or stick with AC for an 80% charge in a speedy 1.1 hour.
*When combined solar and AC input is 2400W.
99% MPPT Efficiency
Maximise solar generation during daylight hours
EcoFlow's smart (MPPT) algorithm automatically detects voltage and current in real-time to give you optimum solar generation throughout the day, even during cold and cloudy days. With a solar input of 1000W, connect up to 2 EcoFlow 400W Portable Solar Panels or 4 sets of 220W Bifacial Solar Panels.
Take control of your power
Smart Automatic Control
AC Always-on
Energy Management
Low Battery Reminder
Save more on electricity billsCustomize the working time of DELTA 2 Max to avoid peak rates.
Experience peace of mind during power outages With our all-new AC Always On Mode, the AC power button stays on, even during a power outage or after the grid power is back, keeping your appliances powered no matter what.
Easily adjust power Easily adjust AC or Solar input to fit your needs: backup power reserve or energy savings.Prioritize solar energy input via the EcoFlow app when using X-Stream AC + solar dual charging.
Always power readyGet a notification via the app when the battery hits a low.
As Quiet as 30 dB
Peaceful charging
