EcoFlow RIVER 2 Portable Power Station (Costco Sale) | Default Title
USD $189.00
• Charge 0-100% in only 60 mins
• Charge without limits
• Run up to 99% of your consumer electronics
• Grab-and-go-power
• Essential home backup with a 30ms switch-over mode
• Power at your fingertips
Power. Never Been This Easy
Charge 0-100% in 1 Hour
Fastest charging speeds ever.
LiFePO4 Battery Chemistry
With upgraded long-lasting LFP battery chemistry at its core, charge and empty RIVER 2 Series over 3000 times. That's pretty much 10 years of everyday use1and 6x longer than the industry average. With LFP cells, RIVER 2 Series issafe, durable, and highly efficient, even in warm temperatures.
The first power station that's TÜV Rheinland certified.
RIVER 2 Series is a cut above the rest as the first portable power station in the world to get certified. With it's high safety standard, the TÜV Rheinland certification means the security and reliability of RIVER 2 Series is guaranteed.
5-year Warranty
4 Ways to Charge
Charge anywhere.
With 4 different ways to top up the RIVER 2 Series, there’s a recharge option no matter what.3From fast AC in-car charging when you’re on the go.
Why not harness renewable energy while you camp or head off on a trip? Plug in a couple of portable solar panels to fully recharge off-grid in as fast as 3 hours.
Small size. Big power.
Lightweight at only 7.7 lbs
With a compact portable design, taking travel-friendly power off-grid has never been this easy. With a light-weight that's 30% lighter than the previous generation, RIVER 2 is ready to power all your outdoorsy escapades, from boondocking to BBQs at the beach.
<30ms EPS Auto-switchUltra-fast home backup switchover.
EcoFlow AppControl at your fingertips.
Use the EcoFlow app to control and monitor RIVER 2, even from afar. View charging levels, customize settings, and adjust charging speeds, all from the convenience of your phone.
Power. Anywhere. Anytime.
SPECS
256Wh
Approximately 7.7lbs
9.6 x 8.5 x 5.7inches
AC Input
100-120V 50Hz/60Hz, 360W Max
Solar Input
8A Max,11-30V 110W
Car Input
12V/24V, 8A, 100W Max
USB-C Input/Output
5/9/12/15/20V 3A, 60W Max
120V 50Hz/60Hz, 300W (Surge 600W)
DC Output
12.6V 8A, 100W Max
5V 2.4A 12W Max
DC5521 Output
Cell Chemistry
App Control
Wi-Fi, Bluetooth
Discharge Temperature
-10°C to 45°C (14°F to 113°F)
Charge Temperature
0°C to 45°C (32°F to 113°F)
Optimal Operating Temperature
20°C to 30°C (68°F to 86°F)
Storage Temperature
-10°C to 45°C (20°C to 30°C is best)/14°F to 113°F (68°F to 86°F is best)
1. Using RIVER 2 six times a week, 3000 full 100% cycles will last 9.6 years until it drops to 80%.
3. When charging and discharging at high wattage, RIVER 2 Max and RIVER 2 Pro may make a noise up to 62db.
