EcoFlow RAPID Pro Charger (140W, 4 Ports, GaN) | RAPID Pro Charger (140W, 4 Ports, GaN)
USD $66.11
Free Shipping
Regular price USD $66.11
Sale price USD $66.11 Regular price $89.00
-$22.89
·4-in-1 Charger, Charge Four Devices at Once: Power up your laptop, phone, and earbuds simultaneously with one multi-port fast charger.
·Fast, Cool, & Safe Charging: Advanced temperature control technology reduces power output to prevent overheating. Real-time monitoring protects both your charger and devices. For added peace of mind, in the rare event of a fire, built-in flame-retardant tech extinguishes flames within 10 seconds—no dripping or reigniting.¹
·Built to Last: The AC plug endures over 5,000 plug-and-unplug cycles without causing wear and tear—sturdy and reliable for the long haul.²
·Compact & Travel-Ready: Lightweight and space-saving design makes it easy to pack and carry. Protective build keeps the plug safe from being damaged. Dimensions: 67 × 63 × 31 mm / 2.64 × 2.48 × 1.22 in
USD $66.11 $89 -$22.89
Subscribe to get 5% off and updates
Thank you for submission!
Portable with GaN Technology
4-in-1 Fast Multi-Port Charger
Advanced Stability
Superior Safety
This charger's compact design ensures it seamlessly fits into your setup without taking up space or interfering with other devices. Boasting a size that's about 36% smaller than an Apple 140W USB-C Power Adapter.
When charging multiple devices simultaneously, it intelligently adjusts the power output based on the charging needs of each device, ensuring efficient, stable, and safe charging.
When plugged into the wall, its anti-gravity design allows a lifting weight of up to 0.6 kg / 1.32 lb without falling out and 10 uses per day without warping. The AC outlet is highly durable and can withstand 5,000 plug-unplug cycles without wear.²
Power Your Life, Anytime, Anywhere
Remote Work
Office
Travel
Remote Work
Remote Work
Office
Office
Travel
Travel
Travel
Travel
4 Devices Charging at Once
One-Port Charging
Two-Port Charging
Three-Port Charging
Four-Port Charging
Learn More About EcoFlow
Specs - EcoFlow RAPID Pro Charger (140W, 4 Ports, GaN)
67*63*31mm(±0.3mm)
220 g
Appearance
Silver
Total Output
140W
Single Output
3C1A, 140W Total
Outlets
4
Drop-resistant
1 m
Fire-proof
Housing V0 Fireproof
2 Years
Is it normal for the charger to get hot?
It is normal for the device surface to heat up under high power transmission. The device has multiple built-in protection mechanisms and can be used with confidence.
What devices are compatible?
This charger is compatible with laptops, smartphones, tablets, headphones, smartwatches, gaming consoles, and other devices equipped with USB-C or USB-A ports, such as MacBook Pro/Air, iPhone, iPad, Dell XPS, and Samsung Galaxy.
PPS/PD3.1/PD3.0/QC3.0/QC2.0/FCP/SCP/APPLE2.4A/BC1.2
What is the size of the adapter? How portable is it? Can it be carried in a carry-on bag on a plane?
The 100W model measures 55.5 × 40.6 × 46.6 mm, and the 140W model measures 67 × 63 × 31 mm.Both models feature foldable plug designs for easy portability, making them suitable for daily commuting or business travel.
Is there a data cable in the package? if not, which cable do you recommend?
This product package does not include a data cable. To fully utilize the high-power output capabilities of this charger (up to 100W / 140W), it is recommended to use a high-power USB-C to USB-C cable that supports the USB-C PD3.1 protocol and features an E-Marker chip. It is advised to choose cables rated for 5A current and 20V voltage (such as those labeled 100W or 240W) to ensure a safe and fast charging experience.
How many times can the plug be folded? Is it easy to loosen or break?
This product is constructed with high-strength metal materials and a reinforced hinge design. The plug prongs have undergone multiple folding tests, demonstrating excellent durability. Under normal usage, frequent folding will not cause looseness or breakage, ensuring a stable connection and portability over the long term. To extend the product’s lifespan, it is recommended to avoid excessive force or angled operations when folding or unfolding.
Why can not some devices be charged at the maximun rated power?
This product can automatically detect the type of charging device and match the appropriate charging protocol. It adjusts the output voltage and current accordingly to ensure safe and reliable charging, reducing charging time. If the protocol is not compatible, the actual output will be lower than the maximum.
¹ Based on internal laboratory testing.
² Based on internal laboratory testing.
Campaign Period
EcoFlow RAPID Power Bank officially launches on August 25, 2025. The EcoFlow RAPID Power Bank Series Launch Campaign (hereinafter referred to as "campaign period") runs from August 25, 2025, 12:00 AM (PDT) to September 7, 2025, 11:59 PM (PDT).
Eligibility of Participants
This promotion is available to all U.S. residents with a valid shipping address in the continental U.S. (Offers are not valid in Alaska, Hawaii, Puerto Rico, or the Virgin Islands.) who are 18 years or older as of August 25, 2025 (hereinafter referred to as "Participants").
Launch Benefits
Benefit 1: Double EcoCredits + Free Gift in Purchase
  • For orders with a pre-tax subtotal of $59.99 or more:
Receive one (1) free EcoFlow RAPID 20W GaN Charger with 60W Cable(MSRP: USD $17.00).
Limit one charger per order.
  • For orders with a pre-tax subtotal of $139.99 or more:
Receive one (1) free EcoFlow RAPID 65W GaN Charger with 100W Cable(MSRP: USD $58.99).
D. For canceled/returned orders: all double EcoCredits will be fully reversed, and for orders over $59.99, the undamaged charger must be returned with the product; partial refunds (including price adjustments) will proportionally deduct EcoCredits, with failure to return the charger resulting in its value being deducted from the refund amount.
E. Complimentary gifts shall generally be dispatched together with the original order, and the delivery address for such gifts shall be identical to that of the original order, unless otherwise specified.
Benefit 2: Get More for Less
(a) 5-10 units purchased: 7% discount for all units; 11-20 units purchased: 9% discount for all units;20+ units purchased: 10% discount for all units. The discount applies automatically at checkout.
(b) Only valid for the same product in the same order on our official EcoFlow website (us.ecoflow.com). Cannot be combined with other promotions.
(c)This discount can't be stacked with other coupons.
(d) If you request a partial return, the applicable discount will be recalculated based on the remaining quantity. And the refund amount will be adjusted accordingly.
E.If a product purchased through a referral link is returned or exchanged, it will follow the standard return and exchange procedures as outlined in the EcoFlow Returen and Refund policy.
F. The referrer's unique referral link may not be shared, sold, or used in any way except by the referrer alone to obtain qualified referrals; referrers are limited to one (1) qualified referral for each referred customer; in other words, additional/repeat purchases made by a referred customer are not counted as additional qualified referrals. Referral links shared to or obtained through other sources (such as through a posting to a third-party intermediary or website) will not be honored.
G. If the referrer and referee share an IP/device, only the referred person may receive a reward. EcoFlow may prohibit a referrer from participating in the program or receiving a credit or reward, at EcoFlow's sole discretion, if EcoFlow determines that such referrer is attempting to undermine the fairness, integrity, or legitimate operation of the program in any way by cheating, hacking, deception, or any other unfair playing practices or intending to annoy, abuse, threaten, or harass any other referrers or any representatives of EcoFlow.H.For other questions regarding the referral program, please refer to:https://www.ecoflow.com/us/referral
Coupon Terms
C. Coupons are valid only for U.S. customers and may only be used on https://us.ecoflow.com.
General
B. Delivery service is unavailable for orders shipped to Guam, island regions, the Virgin Island, Puerto Rico, Hawaii, or Alaska. Please refer to our shipping policyfor more details.
E. During the promotion, all orders must comply with EcoFlow's purchase agreement and return policy.This promotion is not available for wholesale or distributor orders.
M. Ecoflow reserves the right to decide on any dispute arising from or in connection with the promotion.
