EcoFlow RAPID Pro 3-in-1 Power Bank (10,000mAh, 67W) | RAPID Pro 3-in-1 Power Bank (10,000mAh, 67W)
EcoFlow RAPID Pro 3-in-1 Power Bank (10,000mAh, 67W) EcoFlow RAPID Pro 3-in-1 Power Bank (10,000mAh, 67W)
USD $46.99
Free Shipping
Regular price USD $46.99
Sale price USD $46.99 Regular price $119.00
-$72.01
1. Multi-functional 3-in-1 Office Essential: Compact power bank, foldaway laptop charger, and detachable USB-C cable lanyard, lightweight for travel and remote work.
2. Large Capacity, Air-travel-friendly¹: 10,000mAh high-density battery capacity for daily charging needs.
3. 67W USB-C Charging: High-power charging for laptops and a wide range of devices, including game consoles, drones and camera batteries.
4. 45W Fast Recharging Speed: Easily recover power with the built-in 67W AC Plug, ease charging anxiety while you drink a cup of coffee.
USD $46.99 $119 -$72.01
Subscribe to get 5% off and updates
Thank you for submission!
EcoFlow RAPID Pro Charging System
Functional All-in-One Design
Fast Charging
Charger Mode
Effortless Recharging
Compact and Portable 3-in-1 Essential
10,000mAh power bank with a folding 67W AC plug and a USB-C cable.
67W Fast Charging in Power Bank & Charger Modes
As a power bank, supports a maximum charging speed of up to 67W for your laptop, tablet, phone, or other small electronic device.
67W Fast Charger, Refuels All
When plugged into the wall, it prioritizes bypassing more current for devices with 67W output while also recharging itself.
45W Ultra-fast Power Recovery
With a 45W recharging speed, fully recharge in the time it takes to head out in the morning or enjoy a cup of coffee.
Pro-Grade Battery
Superior Safety
Smart Screen Display
Pro Battery, Long-lasting and Reliable
Advanced protection for maximum performance
Equipped with an LCD screen, view power status, charging speed, and remaining battery at a glance.
One Power Solution for Every Situation
Travel
Remote Work
Travel
Travel
Travel
Travel
Remote Work
Remote Work
Remote Work
Remote Work
Multi-Port Charging For Your Trip
Compatible with 99% of everyday electronic devices.
Single-Port Charging
Multi-Port Charging
Learn More About EcoFlow
Specifications
Total Cell Capacity
10000mAh(36Wh)
115*43*48mm
4.5*1.7*1.7in
(Lanyard Cable: 15cm)
360g
Total Output
67W
Single Output
C1/C2: 67W
Outlets
2
Input
45W
APP Support
No
Screen Display
LCD
Which devices are compatible?
Compatible devices are laptops, phones, tablets, headphones, smartwatches, game consoles and other devices with USB-C ports such as MacBook Pro/Air, iPhone,iPad, Dell XPS and Samsung Galaxy.
Why is there a difference rated capacity and nominal capacity?
Nominal capacity refers to the total capacity of the battery cells inside the power bank, while rated capacity refers to the actual amount of power the power bank can deliver under standard output conditions (such as 5V/3A). Nominal capacity is a theoretical value, whereas rated capacity accounts for energy conversion efficiency, circuit losses, and other factors, and is therefore lower than the nominal capacity.
Can a power bank be taken on the plane?
Yes, according to regulations by the International Civil Aviation Organization (ICAO) and most airlines, carrying a power bank with a capacity under 100Wh is allowed. The RAPID Pro, with a capacity of 10000mAh (36Wh), meets this requirement and can be carried on board without concern.
Battery life and temperature FAQs
The power bank retains over 80% of its battery capacity after 300 charge cycles. It supports charging and discharging at altitudes below 3000 meters and in environments with temperatures between 0°C and 25°C. If not used for an extended period, it is recommended to store the power bank in an environment between -10°C and 60°C and to recharge it at least once every three months.
Why does the power bank provide less electricity than expected?
There will usually be a difference from what is expected, with the capacity reduction mainly due to energy losses in the battery and the conversion circuit.
How to keep the power bank charging and discharging quickly?
"To ensure fast and stable charging and discharging performance when using the power bank, we recommend the following.
1. Choose the Right Charger:
Use a charger that supports fast charging protocols and has a high output power (such as PD 65W or 100W). Avoid using low-power chargers (such as 5V/1A).
2. Use a Good Charging Cable:
Select original or high-quality fast charging cables. Keep connectors clean and secure, and avoid excessively long cables.
3. Device Compatibility:
Make sure the connected devices support fast charging protocols; otherwise, fast charging will not be achieved."
¹ Airline regulations vary by region and carrier. Please confirm battery restrictions with your airline before travel.
² Based on an iPhone 16 Pro's official 33 hr battery life
