EcoFlow RAPID Mag Power Bank (5,000mAh, 7.5W) | Black
EcoFlow RAPID Mag Power Bank (5,000mAh, 7.5W) EcoFlow RAPID Mag Power Bank (5,000mAh, 7.5W)
USD $29.99
Free Shipping
Regular price USD $29.99
Sale price USD $29.99 Regular price
-$-29.99
Ultra-Slim 9.4 mm / 0.37 in: Around the same thickness as a stack of five 25-cent coins. Slides invisibly into pants pockets, a slim laptop bag, or a purse.
100°F Cool Touch: X-Cooling tech maintains a surface temp of less than 38℃/100°F.
5,000 mAh On-Demand Energy: No full charge? There's no need to panic. 5,000 mAh refuels an iPhone 16 50% in only 36 mins—enough to survive a missed train, sudden Zoom call, or 3-hour café work sprint.
11N Grip, Zero Drops: Military-grade N52 magnets withstand running, cycling, and subway chaos.
20W Recharging, 50% in 48 Min
Power Indicators: Four LEDs track battery levels in real time.
Color
Black
White
EcoFlow RAPID 20W GaN Charger with 60W Cable
USD $12.99 USD $29
EcoFlow RAPID 30W GaN Charger with 60W Cable
USD $12.99 USD $29
USD $12.99 USD $29
USD $12.99 USD $29
USD $29.99
Subscribe to get 5% off and updates
Thank you for submission!
Industry's Slimmest Magnetic Power Bank³
5 Vibrant Color Options
Silk-Soft Touch
LED Power Indicator
Around the same thickness as a stack of five 25-cent coins. A lithium cobalt battery packs 5,000mAh into a slimline design. Slides invisibly into pants pockets, a slim laptop bag, or a purse.
Match your personal style, whether at home or on the go.
Black/White/Green/Purple/Pink
Silky matte texture ensures a secure grip during workouts, commutes, or coffee runs. Sweat-proof, fingerprint-resistant, and lightweight.
Four LEDs track battery levels in real-time. Check remaining charge mid-flight, on hikes, or during outages, and plan your next recharge effortlessly.
100°F Cool Touch
Charge While Recharging
20W Recharging
X-Cooling tech maintains a surface temp of less than 100°F,¹ extending phone battery life.⁴
With 20W recharging, RAPID reaches 50% in only 48 minutes. Refuel RAPID and your smartphone while you sleep.
* 100% recharge in 126 min
Military-grade N52 magnets withstand running, cycling, and subway chaos.²
City Strolls
Café Hangouts
Trail Hikes
City Strolls
City Strolls
City Strolls
City Strolls
Café Hangouts
Café Hangouts
Trail Hikes
Trail Hikes
Trail Hikes
Trail Hikes
Model-by-Model Charging
Phone Case-Friendly
* Based on internal laboratory testing. A fully charged 5,000mAh power bank provides approximately 3000mAh to 3100mAh of usable power due to 35% to 40% energy loss.
Snap-on a magnetic case for instant coil alignment during workouts or busy commutes.
Learn More About EcoFlow
Specs - EcoFlow RAPID Mag Power Bank (5000mAh, 7.5W, Magnetic Charging)
5000mAh(19.35Wh)
103 mm × 71.6 mm × 9.4 mm
Weight
123 g
Ports
1C
Wired Charging Output
20W
Wireless Charging Output
7.5W
Wired Charging Input
20W
APP
No
Digital Display
LED
Can I use it while charging?
Supports simultaneous charging and discharging. Wireless charging up to 7.5W Max.When discharging simultaneously, wireless charging is disabled by default, but can be enabled by pressing and holding the button for 3 seconds.
Why does my phone get hot when charging with a power bank? Is there any impact?
It is considered normal for a smartphone to generate heat while being charged by a power bank.This may be caused by factors such as energy conversion losses, simultaneous charging and usage, and elevated ambient temperatures.To prevent overheating, ensure that both the smartphone and the power bank are placed in a well-ventilated environment.In cases of excessive heat, the device may reduce its power output. Charging may be paused and resumed once the device has adequately cooled down.Please rest assured that our product has obtained multiple regulatory safety certifications and meets strict compliance standards.
Is our power bank compatible with android phones?
Our power bank is compatible with most android phones, but does not support the proprietary wireless charging protocol of android phones. And we recommend that you choose a phone case that supports magnetic attraction for a better experience.
What is the function of the button?
A single press will wake up/display the remaining battery level.Double click to switch between wireless charging fast mode(green light on) and low temperature mode(blue light on).Press and hold for 3 seconds to turn on/off wireless charging.
Why does my power bank stop charging my device at 80%?
As part of the iOS system thermal management strategy, if the temperature gets too high during charging, your iPhone may automatically stop charging at 80% to prevent its battery from overheating. After waiting for the device to cool down, charging will resume. Moving it to a cooler place can help speed up this process.
Can I take a power bank on the plane?
Yes, the RAPID Mag has a capacity of 38.7Wh for 10000mAh and 19.5Wh for 5000mAh. According to the international civil aviation organization(ICAO) and most airlines, power bank with a capacity of less than 100Wh are allowed and can be used with confidence.
Usage environment and storage requirements for power banks
The battery capacity of the power bank is greater than 80% after 300 cycles. It supports charging and discharging at an altitude below 3000m and an environment of 0~40℃. If it is not used for a long time, it is recommended to store it in an environment of -10~40℃ and charge the power bank at least once every 3 months.The battery capacity of the power bank is greater than 80% after 300 cycles. It supports charging and discharging at an altitude below 3000m and an environment of 0~40℃. If it is not used for a long time, it is recommended to store it in an environment of -10~40℃ and charge the power bank at least once every 3 months.
How to charge your device wirelessly more effectively?
Do not use a phone case or choose a thin phone case with a magnetic design that is less than 2.5mm thick and align it with the wireless charging position of the power bank.
Is the charging cable includes in the package?
Yes, it comes with a 30 cm C to C charging cable that supports 60W.
Why is there a difference between the rated capacity and the nominal?
Nominal capacity refers to the total capacity of the internal battery cells of the power bank, while rated capacity refers to the actual amount of the power that the power bank can output under standard output conditions( such as 5V/2A). The nominal capacity is a theoretical value, while the rated capacity takes into account factors such as energy conversion effiencicy and circuit loss, it will be lower than the nominal capacity.
Can the USB-C port of the power bank be used for charging and discharging?
Yes, the USB-C port is bidirectional port that can be used for both charging or discharging.
¹ Verified in lab conditions
² Phone model dependent
³ Benchmark is EcoFlow RAPID 5K
⁴ Phone model dependent
Campaign Period
EcoFlow RAPID Power Bank officially launches on August 18, 2025. The EcoFlow RAPID Power Bank Series Launch Campaign (hereinafter referred to as "campaign period") runs from August 18, 2025, 12:00 AM (PDT) to September 1, 2025, 11:59 PM (PDT).
Eligibility of Participants
This promotion is available to all U.S. residents with a valid shipping address in the continental U.S. (Offers are not valid in Alaska, Hawaii, Puerto Rico, or the Virgin Islands.)who are 18 years or older as of August 18, 2025 (hereinafter referred to as "Participants").
Launch Benefits
Benefit 1: Double EcoCredits + Free Gift in Purchase
  • For orders with a pre-tax subtotal of $59.99 or more:
Receive one (1) free EcoFlow RAPID 20W GaN Charger with 60W Cable(MSRP: USD $17.00).
Limit one charger per order.
  • For orders with a pre-tax subtotal of $139.99 or more:
Receive one (1) free EcoFlow RAPID 65W GaN Charger with 100W Cable(MSRP: USD $58.99).
D. For canceled/returned orders: all double EcoCredits will be fully reversed, and for orders over $59.99, the undamaged charger must be returned with the product; partial refunds (including price adjustments) will proportionally deduct EcoCredits, with failure to return the charger resulting in its value being deducted from the refund amount.
E. Complimentary gifts shall generally be dispatched together with the original order, and the delivery address for such gifts shall be identical to that of the original order, unless otherwise specified.
Benefit 2: Get More for Less
(a) 5-10 units purchased: 7% discount for all units; 11-20 units purchased: 9% discount for all units;20+ units purchased: 10% discount for all units. The discount applies automatically at checkout.
(b) Only valid for the same product in the same order on our official EcoFlow website (us.ecoflow.com). Cannot be combined with other promotions.
(c)This discount can't be stacked with other coupons.
(d) If you request a partial return, the applicable discount will be recalculated based on the remaining quantity. And the refund amount will be adjusted accordingly.
E.If a product purchased through a referral link is returned or exchanged, it will follow the standard return and exchange procedures as outlined in the EcoFlow Returen and Refund policy.
F. The referrer's unique referral link may not be shared, sold, or used in any way except by the referrer alone to obtain qualified referrals; referrers are limited to one (1) qualified referral for each referred customer; in other words, additional/repeat purchases made by a referred customer are not counted as additional qualified referrals. Referral links shared to or obtained through other sources (such as through a posting to a third-party intermediary or website) will not be honored.
G. If the referrer and referee share an IP/device, only the referred person may receive a reward. EcoFlow may prohibit a referrer from participating in the program or receiving a credit or reward, at EcoFlow's sole discretion, if EcoFlow determines that such referrer is attempting to undermine the fairness, integrity, or legitimate operation of the program in any way by cheating, hacking, deception, or any other unfair playing practices or intending to annoy, abuse, threaten, or harass any other referrers or any representatives of EcoFlow.H.For other questions regarding the referral program, please refer to:https://www.ecoflow.com/us/referral
Coupon Terms
C. Coupons are valid only for U.S. customers and may only be used on https://us.ecoflow.com.
General
B. Delivery service is unavailable for orders shipped to Guam, island regions, the Virgin Island, Puerto Rico, Hawaii, or Alaska. Please refer to our shipping policyfor more details.
E. During the promotion, all orders must comply with EcoFlow's purchase agreement and return policy.This promotion is not available for wholesale or distributor orders.
