EcoFlow RAPID Charger (65W, Retractable Cable, GaN) | White
EcoFlow RAPID Charger (65W, Retractable Cable, GaN) EcoFlow RAPID Charger (65W, Retractable Cable, GaN)
USD $49.99
Free Shipping
Regular price USD $49.99
Sale price USD $49.99 Regular price
-$-49.99
· 65W Fast Charging: Multi-port, single port max 65W output; Ultra-fast charging, compatible with various electronic devices (laptops, tablets, phones, gaming consoles)
· Multi-devices charger: 2* USB-C ports,1* 70cm retractable USB-C cable
· Space-Saving & Portable Design: Save desktop power resources, one charger for multiple device charging needs.Retractble design prevents cable tangling, no more messy cables. Foldaway Compact Prong saves more space
Color
Black
White
USD $49.99
Subscribe to get 5% off and updates
Thank you for submission!
Multi-Functional Fast Charging for Everyday Convenience
GaN Technology
65w Fast Charging
All-in-One Design
Powerful and Compact Design with GaN Technology
Boasting a volume smaller than an Apple 67W USB-C Adapter, this charger's
compact design ensures it seamlessly fits into your setup without encroaching
on space or interfering with other devices.
65W Fast Charging
Ultra-fast charging, compatible with various devices (laptops, tablets, phones gaming consoles, and more)
-1h44min to fully charge an iPhone 16
-2h12min to fully charge a MacBook Air
All-in-One Charging Solution
Save desktop space with one charger that simultaneously handles The charging needs of up to three devices. When travelling, its tangle-free design, makes storage and transportation hassle-free.
- 2 output ports (1C1A)
-70 cm Retractable USB-C Cable
- Foldable Wall Plug
Advanced Durability
Superior Safety
Enhanced Stability and Reliability
Designed for a secure connection, the plug went through 4kg weight bearance tests and 3000-time plug and unplug tests without damage.The retractable cable has passed a 10,000-time twisting test, ensuring years of daily-use durability.
Advanced Protection, Maximum Performance Protected by EcoFlow's X-Guard
EcoFlow RAPID maintains its fast charging levels 24/7 with arourid-the-clock safety checks. Its temperature sensor tests and adjusts for overfheating up to 60,000 times every minute, while the V0-level fireproof shell delivers robust external protection.
Power Your Life, Anytime, Anywhere
At Home
Remote Work
Travel
At Home
At Home
Remote Work
Remote Work
Travel
Travel
Travel
Travel
65W Max Multi-Port Charging
Compatible with 99% of Daily-use Electronic Devices
65W Multi-Port Charging
One-Port
Two-Port
Three-Port
Learn More About EcoFlow
Dimension
52.5*51*50.71mm (Built-in Cable: 70cm)
Weight
171.5±10g
Total Output
65W
Output: Type-C Cable/Type-C2: 5V=3A/9V=3A/12V=3A/15V=3A/20V-3.25A,65W Max
USB-A: 5V=3A, 9V=2A, 12V=1.5A, 18W Max
Type-C Cable+Type-C2:65W Max
Type-C Cable+USB-A: 45W+18W
Type-C2+USB-A: 5V=2A+5V=2A, 20W
Type-C Cable+(Type-C2+USB-A): 45W+15W+15W
Single Output
C1 (Cable): 65W
C2: 65W
A: 18W
Outlets
3
APP Support
No
Is it normal for the charger to get hot?
It is normal for the device surface to heat up under high power transmission. The device has multiple built-in protection mechanisms and can be used with confidence.
What devices are compatible?
This charger is compatible with laptops, phones, tablets, earphones, smartwatches, gaming consoles, and other devices with USB-C or USB-A ports, such as MacBook Pro/Air, iPhone, iPad, Dell XPS, and Samsung Galaxy.
PPS/PD3.2/PD2.0 ,QC4+/QC4.0/QC3.0/QC2.0/APPLE2.4A/BC1.2/DCP1.5A
Why can not some devices be charged at the maximun rated power?
This product can automatically detect the type of connected device, match the appropriate charging protocol, and intelligently adjust the output voltage and current. This ensures safe and reliable charging while optimizing charging speed.If the charging protocol is not supported or does not match, the actual output power may be lower than the maximum rated output.
How many times can the plug be folded? Is it easy to loosen or break?
This product is constructed with high-strength metal materials and a reinforced hinge design. The plug prongs have undergone multiple folding tests, demonstrating excellent durability. Under normal usage, frequent folding will not cause looseness or breakage, ensuring a stable connection and portability over the long term. To extend the product’s lifespan, it is recommended to avoid excessive force or angled operations when folding or unfolding.
What is the size of the adapter? How portable is it? Can it be carried in a carry-on bag on a plane?
The 65W model measures 52.5 × 51 × 51.3mm and the 45W model measures 61 × 55 × 35.2mm.Both models feature foldable plug designs for easy portability, making them suitable for daily commuting or business travel.
Campaign Period
EcoFlow RAPID Power Bank officially launches on August 25, 2025. The EcoFlow RAPID Power Bank Series Launch Campaign (hereinafter referred to as "campaign period") runs from August 25, 2025, 12:00 AM (PDT) to September 8, 2025, 11:59 PM (PDT).
Eligibility of Participants
This promotion is available to all U.S. residents with a valid shipping address in the continental U.S. (Offers are not valid in Alaska, Hawaii, Puerto Rico, or the Virgin Islands.)who are 18 years or older as of August 25, 2025 (hereinafter referred to as "Participants").
Launch Benefits
Benefit 1: Double EcoCredits + Free Gift in Purchase
  • For orders with a pre-tax subtotal of $59.99 or more:
Receive one (1) free EcoFlow RAPID 20W GaN Charger with 60W Cable(MSRP: USD $17.00).
Limit one charger per order.
  • For orders with a pre-tax subtotal of $139.99 or more:
Receive one (1) free EcoFlow RAPID 65W GaN Charger with 100W Cable(MSRP: USD $58.99).
D. For canceled/returned orders: all double EcoCredits will be fully reversed, and for orders over $59.99, the undamaged charger must be returned with the product; partial refunds (including price adjustments) will proportionally deduct EcoCredits, with failure to return the charger resulting in its value being deducted from the refund amount.
E. Complimentary gifts shall generally be dispatched together with the original order, and the delivery address for such gifts shall be identical to that of the original order, unless otherwise specified.
Benefit 2: Get More for Less
(a) 5-10 units purchased: 7% discount for all units; 11-20 units purchased: 9% discount for all units;20+ units purchased: 10% discount for all units. The discount applies automatically at checkout.
(b) Only valid for the same product in the same order on our official EcoFlow website (us.ecoflow.com). Cannot be combined with other promotions.
(c)This discount can't be stacked with other coupons.
(d) If you request a partial return, the applicable discount will be recalculated based on the remaining quantity. And the refund amount will be adjusted accordingly.
E.If a product purchased through a referral link is returned or exchanged, it will follow the standard return and exchange procedures as outlined in the EcoFlow Returen and Refund policy.
F. The referrer's unique referral link may not be shared, sold, or used in any way except by the referrer alone to obtain qualified referrals; referrers are limited to one (1) qualified referral for each referred customer; in other words, additional/repeat purchases made by a referred customer are not counted as additional qualified referrals. Referral links shared to or obtained through other sources (such as through a posting to a third-party intermediary or website) will not be honored.
G. If the referrer and referee share an IP/device, only the referred person may receive a reward. EcoFlow may prohibit a referrer from participating in the program or receiving a credit or reward, at EcoFlow's sole discretion, if EcoFlow determines that such referrer is attempting to undermine the fairness, integrity, or legitimate operation of the program in any way by cheating, hacking, deception, or any other unfair playing practices or intending to annoy, abuse, threaten, or harass any other referrers or any representatives of EcoFlow.H.For other questions regarding the referral program, please refer to:https://www.ecoflow.com/us/referral
Coupon Terms
C. Coupons are valid only for U.S. customers and may only be used on https://us.ecoflow.com.
General
B. Delivery service is unavailable for orders shipped to Guam, island regions, the Virgin Island, Puerto Rico, Hawaii, or Alaska. Please refer to our shipping policyfor more details.
E. During the promotion, all orders must comply with EcoFlow's purchase agreement and return policy.This promotion is not available for wholesale or distributor orders.
M. Ecoflow reserves the right to decide on any dispute arising from or in connection with the promotion.
