EcoFlow DELTA Pro + Smart Home Panel - DELTA Pro*2 + Smart Home Panel (Combo) - EcoFlow
EcoFlow DELTA Pro + Smart Home Panel EcoFlow DELTA Pro + Smart Home Panel
USD $6,299.00
Regular price USD $6,299.00
Sale price USD $6,299.00 Regular price $8,997.00
-$2,698
Get up to $1,889.70 in rebates through the Residential Clean Energy Credit. Learn More >
Up to $1,889.70 in rebates
Amount 30% off
Claim By: December 31, 2032
Program: Residential
  • Rentals do not qualify.
  • Must be grid-tied.
Professional electrician installation required; installation fees not included.
The portable home battery: DELTA Pro supports a 3.6kWh capacity that can be expanded all the way to 25kWh. The kicker? You can integrate it directly with your home circuits via the Smart Home Panel. Ideal for home backup.
Power pretty much anything: DELTA Pro leads the industry when it comes to AC output. With 3600W you’ve got a portable generator that can power heavy-duty appliances such as dryers, AC units & more. Need even more power? Pair two units together to hit a massive 7200W.
A smart home battery system Made specifically for the DELTA Pro ecosystem, the Smart Home Panel connects the DELTA Pro portable power station right to your home’s wiring.
Backup power for essential home appliances When the grid goes down, the Smart Home Panel instantly switches to battery backup mode using any connected DELTA Pro units. Your home will go on strong with up to 7200W of power and 25kWh of energy when properly equipped.
EcoFlow app control Monitor, control, and manage energy through the EcoFlow app. The app gives real-time metrics and lets you avoid peak rates.
Peak rate avoidance If you’re on a time-of-use billing rate, you can use the Smart Home Panel and attached DELTA Pros to store energy when rates are low and consume it when rates are high.
Sustainable & self-sufficient When you attach Solar-compatible solar panels to DELTA Pro, your home gets a little more eco-conscious. The Smart Home Panel links free, renewable solar energy to your wall outlets, lighting, and other fixtures. With enough solar input, your home can become self-sufficient.
Smart Home Panel Only will require Relay Module to work.
*Installation Fees Not Included
You Could Apply for 30% Tax Credit*, When You Install DELTA Pro as a Home Power Solution Learn more
USD $6,299 $8,997 -$2,698
Citi Pay® Credit – Special financing available. Learn More
Citi Pay® Credit Badge Citi Pay® Credit. Special financing available
The EcoFlow Smart Home Panel integrates EcoFlow DELTA Pro with your home to achieve a flexible, expandable home battery solution to store energy for later use. Link up to 10 of your home circuits for uninterrupted power during blackouts, smart energy management, and more. All while saving money in the process.
Prepare your home for power outages.
When a blackout hits, the Smart Home Panel immediately switches to your 10 integrated circuits and draws power from your DELTA Pro(s). You’ll barely notice a loss of power as your chosen circuits stay powered with a mere 20ms switchover time.
Expand capacity and output.
The Smart Home Panel supports and fast charges up to two DELTA Pro(s) at a time, alongside their extra batteries + smart generator(s). That gives you a potential 240V, 7200W output and 25kWh of capacity at your control, enough to power pretty much anything in your home, delivering days of power during blackouts.
Control each of your integrated home circuits via the EcoFlow app and get a birds-eye view of your energy consumption habits. Dive into the settings to customize your power use. You can optimize for home backup, saving money, or custom options to schedule your energy use based on your needs. Once you’re set, you can even control which power source your house uses, all from your phone.
Draw power from your DELTA Pro(s) to power your home during peak energy use hours, this lowers your bills and reduces pressure on the grid during peak hours. During off-peak hours, use low-cost/renewable energy to charge your DELTA Pro(s) back to full.
How it all comes together.
The DELTA Pro Ecosystem all links together with the Smart Home Panel at its heart.
Reduce your reliance on the grid and prepare for blackouts. Opt for EcoFlow’s range of portable solar panels to store energy at any time. No sun? We’re working on a wind turbine. No sun or wind? Charge via the grid. No sun, no wind, and a blackout hits? You’re still good. Lean on the EcoFlow Smart Generator as a last resort to charge your batteries.
What‘s in the box
1. Smart Home Panel, 2. Infinity Cable, 3. Wall Mounts, 4. Wire Connectors, 5. User Manual
Tutorial Video
This video explains the installation process for the Smart Home Panel.
Tutorial Video
This video introduces EcoFlow DELTA Pro Ecosystem
*This product does not provide an AFCI (Arc Fault Circuit Interrupter) function. All upstream breakers should be non-GFCI/AFCI. GFCI and AFCI protection should be downstream of the SHP using GFCI/AFCI breakers or outlets.
**How to choose Relay Modules:
1. Load planning: With a Smart Home Panel, selective loads are installed where they will be the most effective during power outages or energy savings management. Consider areas that would significantly affect comfort, such as refrigerator and lights, and choose the maximum of 10 selective loads from your breaker panel based on their efficiency in load.
2. Collect the load info: Determine the number and current rating of the load circuits that you plan to connect. Consult your electrician if you need support with this.
3. Determine the relay modules needed: Choose the relay module that matches the current rating for the circuit breaker upstream of that load circuit. Recommended relay modules for regions: 15A, 20A, 30A for US and Japan.
How much money can I save on my bills with the Smart Home Panel + DELTA Pro?
It varies based on your chosen set up and how you use the ecosystem. However, if used optimally to reduce spending during peak hours, you could save over $1000 a year with 2 DELTA Pro’s, a smart home panel and 2400W worth of EcoFlow solar panels. That assumes average US energy rates. You can save up to double that if you use DELTA Pro’s extra batteries in addition, and if your home has a higher solar supply.
Can the Smart Home Panel charge my DELTA Pro?
Yes. You can plug in up to two DELTA Pros and benefit 3400W fast charging for your units. You can choose which speed is best for you in the EcoFlow app.
Can I use the app while away from home? Or only in the range of my house?
You can monitor and optimize your energy usage from anywhere with a Wi-Fi connection via the EcoFlow app, as long as your units are online.
Output Voltage
120V / 240V
System Frequency
60Hz
# of Controlled Circuits
10
Rate Current
30A, 20A, 15A
Max Backup Power
3600W / 7200W
Max Connected Battery Energy
21.6kWh
Charging Input (DELTA Pro)
3400W Max
IP Code
IP20
Installation
Wall mount, to be installed by a licensed electrician
3 Years
18.1 x 11.8 x 4.7 in / 460 x 330 x 120 mm
Weight
20 lb / 9 kg
Disclaimer
Effective date: Jan 1, 2023
