EcoFlow DELTA 2 Max Smart Extra Battery (Refurbished) | DELTA 2 Max Smart Extra Battery
USD $749.00
Regular price USD $749.00
Sale price USD $749.00 Regular price $1,399.00
-$650
· Expandable capacity - Increase the capacity of DELTA 2, DELTA Max and DELTA 2 Max with an extra 2048Wh.
· Triple power at up to 30% lower cost - 2-6kWh expandable capacity to fit your energy storage needs. Add up to two DELTA 2 Max Smart Extra Batteries to gain a capacity of 6144Wh. And it's up to 30% more affordable than a power station of the same capacity.
· 10-year lifespan with an LFP battery - Get 10 years of daily use until it hits 80% of its original capacity. Embrace the 3000+ charging cycles enabled by the LFP battery chemistry.
· Easy to use - Plug-and-play without setup. And use the EcoFlow app to monitor and control the DELTA 2 Max Smart Extra Battery.
· 5-Year Full Warranty - With one of the most comprehensive warranties in the industry, we go the extra mile to give you peace of mind.
USD $749 $1,399 -$650
Expandable capacity
Increase the capacity of DELTA 2 Max with an extra 2048Wh.
Triple the power
2-6kWh expandable capacity to fit your energy storage needs. Add up to two DELTA 2 Max Smart Extra Batteries to gain a capacity of 6144Wh, ideal for home backup, RVing, outdoor adventures, and everyday use. Much more affordable, it costs up to 30% less than a power station of the same capacity.
Durable, Safe, Lightweight
With its upgraded LFP battery chemistry, the DELTA 2 Max Smart Extra Battery has a lifespan of 3000 complete cycles until it reduces to 80% capacity. You'll get pretty much 10 years of power, even if you use it every day. That's 6× longer than other power stations with a similar capacity and output.
Easy to use
There's no setup. Just plug it into your power station for more energy storage. Using the EcoFlow app, you can charge and monitor the DELTA 2 Max Smart Extra Battery with ease.
Stackable, space-saving design
Featuring an ergonomic, compact design, the DELTA 2 Max Smart Extra Batteries can be securely stacked on top of power stations and each other to save space and minimize clutter.
DELTA 2 Max Smart Extra Battery Specs
2048Wh
Input Port
51.2V, 2000W Max
Output Port
51.2V, 3200W Max
Battery
LFP chemistry, 3000 cycles to >80% capacity
Dimension
464 × 235 × 283 mm (18 × 9 × 11 in)
Weight
19kg (42lbs)
What’s in the box
Extra Battery Cable User Manual Warranty Card
Compatible with
DELTA 2 / DELTA Max 2000/ DELTA 2 Max
Which portable power station is compatible with the DELTA 2 Max Smart Extra Battery?
DELTA 2, DELTA Max, and DELTA 2 Max are compatible with the DELTA 2 Max Smart Extra Battery.
How many extra batteries can I use with a portable power station?
Can I charge the extra battery without connecting to a power station?
What makes the Smart Extra Battery "Smart"?
