EcoFlow 500W Alternator Charger | DELTA 3 Plus + 500W Alternator Charger
EcoFlow 500W Alternator Charger EcoFlow 500W Alternator Charger EcoFlow 500W Alternator Charger EcoFlow 500W Alternator Charger EcoFlow 500W Alternator Charger EcoFlow 500W Alternator Charger EcoFlow 500W Alternator Charger EcoFlow 500W Alternator Charger EcoFlow 500W Alternator Charger EcoFlow 500W Alternator Charger
USD $729.00
Regular price USD $729.00
Sale price USD $729.00 Regular price $1,188.00
-$459
- 500W Alternator Charger, 5× faster than traditional in-vehicle auxiliary power outlets. Top up 1kWh in only 2.1 hours
- A 3-in-1 fast charger, maintainer, and jump starter keeps your battery in mint condition
- Compatible with third-party portable power stations
- 3-step easy installation
- Suitable for a variety of vehicles, including SUVs, pickups, and RVs
- Expands existing RV house battery capacity
* The 500W Alternator Charger comes with an XT60 cable, but does not support reverse charging & battery maintenance functions with the XT60 cable. To enable reverse charging & battery maintenance functions, purchase the XT150 cable and use with an EcoFlow DELTA Series product.
* When used with third-party portable power stations, the 500W Alternator Charger does not support reverse charging & battery maintenance functions.
* A DELTA Pro to Smart Generator Adapter is required to connect the Alternator Charger to DELTA Pro.
USD $479 USD $1,049
1kWh Capacity
1800W Output
USD $399 USD $649
25% Conversion Rate | IP68
USD $399 USD $649
USD $729 $1,188 -$459
Charge 5× faster while you drive with our EcoFlow 500W Alternator Charger and recharge your power station in only 2.1 hours.
With the EcoFlow 500W Alternator Charger, charge 5 times faster than with traditional vehicle auxiliary power outlets simply by using excess energy generated by your vehicle. The charger uses its onboard DC-DC converter to restore your EcoFlow power station's energy while you drive.
Note: Alternator capacity varies by vehicle - Please verify with your manual (or the alternator's manual) that the alternator's output supports the alternator charger's maximum power draw for safe operation.
The 3-in-1 charger, maintainer, and jump starter saves time, money, and precious in-vehicle space.With its smart and efficient fast charging capabilities, you'll stay powered no matter how long you're on the road.
Charging Mode
Reverse Charging Mode
Battery Maintenance Mode
Compatible with all EcoFlow and most third-party power stations
Compatible with an XT60 connection, designed to charge EcoFlow RIVER, DELTA Series, and most
third-party power stations. The charger's 500W fast-charging is compatible with most SUV, Pickup, and RV alternators, meeting diverse short-trip car camping power needs.
*When using an XT60 cable, the Alternator Charger switch on the device must be manually turned on and the charging function enabled in the app before charging can begin. Therefore, if planning to use the XT60 cable for output, avoid concealed installation of the Alternator Charger in advance.
With a high thermal resistance, Gallium Nitride (GaN) technology ensures safe charging every single time. The 500W Alternator Charger offers multiple safety features, including undervoltage protection that prevents excessive energy use and damage to the starting battery. A 2-year warranty ensures your experience and peace of mind.
Smart Charge, Smarter Control - Industry-first vehicle infotainment integration
Monitor your power station and remaining charging time at a glance. Stay connected with real-time control through Apple iOS CarPlay & Android Auto support. Access the EcoFlow App directly via your vehicle's infotainment system, turning your drive into a hub of intelligent energy management. Everything at your fingertips without constantly checking your phone, ensuring safer driving.
Connect your 500W Alternator Charger to your vehicle's starter battery or RV's house battery to enjoy
a worry-free power experience during your journey.
Connect your 500W Alternator Charger to your vehicle's starter battery or RV's house battery to enjoy a worry-free power experience during your journey.
Step 1: Connect the Fuse Cable
Step 2: Connect the Input Cable
Step 3: Start Charging
1. Connect the fuse cable to the input cable on one end.
2. Connect the fuse cable to the vehicle battery on the other end.
1. Connect the black cable to the chassis terminal.
2. Thread the other end of the input cable through the car body towards the charger. If the input cable is bulky or difficult to pull through, disconnect the cable ends before threading.
3. Plug the other side of the input cable into the EcoFlow 500W Alternator Charger.
Plug in the output cable from the EcoFlow 500W Alternator Charger to the portable power station.
How to Choose your EcoFlow Alternator Charger
Model
EF-MS-H02-1
Approximately 3.53 lbs (1.6 kg)
Dimensions (W × D × H)
9.5×7.6×1.4 inch
(242 x 194 x 35 mm)
Wi-Fi
Frequency: 2412MHz-2472MHz
Maximum output power: 18.22dBm
Bluetooth
Frequency: 2402MHz-2480MHz
Maximum output power: 7.89dBm
Charging Mode
Input: 12V/24V⎓(11V-31V⎓), 45A Max.
Output: 40V-60V⎓, 500W Max.;24V⎓, 360W Max.
Input: 40V-60V⎓, 3A Max.
Output: 13.8V/27.6V⎓, 100W Max.
Input: 40V-60V⎓, 13.2A Max.
Output: 13.8V/27.6V⎓, 500W Max.
Fuse's Rated Current
125A
Protection Type
Reverse polarity protection
Overcurrent protection
Short circuit protection
Overvoltage and undervoltage protection(Provided with integral protection against overloads)
Operating Temperature
–4℉ to 140℉ (–20℃ to 60℃)
Storage Temperature
–22℉ to 158℉ (–30℃ to 70℃)
Operating Humidity
≤95%
Storage Humidity
≤95%
Is the EcoFlow Alternator Charger compatible with third-party power stations, and how are they charged?
The Alternator Charger can charge third-party portable power stations if the following conditions are met:
1. Connected via an XT60 cable.
2. The battery type is configured in the settings.
3. The vehicle battery voltage (12V/24V) is selected based on the actual voltage level of the vehicle battery connected to the EcoFlow Alternator Charger.
4. The portable power station type is selected as a third-party 24V battery.
Why can't the maximum power be reached when using the XT60 cable?
Why do I need to set the cable length?
Why can't I select the portable power station type as 24V (24V unit: RIVER 2/3/mini/Max/Pro, WAVE, & third-party 24V batteries) when the vehicle battery is set to 24V?
Will the Alternator Charger consume more fuel (i.e. affect gas mileage) when being used?
Is the Alternator Charger suitable for DIY installation?
What advantages does the 500W Alternator Charger offer compared to charging via the cigarette lighter?
What types of vehicles are suitable for installation? Can all of them reach maximum power?
How does the Alternator Charger start and stop?
If the vehicle battery is low on power, can the vehicle battery be charged by the alternator charger?
How long does it take to fully charge a RIVER Series / DELTA Series product using the 500W Alternator Charger?
How to determine whether my car is compatible with the Alternator Charger?
How many working modes does the Alternator Charger have?
Terms and Conditions:
¹The 500W refers to the speed under full power charging. The charging power is related to the car generator's current and operating condition.
Thanks for sharing!
