EcoFlow DELTA Pro Ultra X | Fast-Install Whole-Home Backup | DELTA Pro Ultra X (1 x Inverter + 2 x Batteries) + Smart Home Panel 3 + Free PowerInsight 2
Starting at 0% APR with Pay
EcoFlow DELTA Pro Ultra X Whole-Home Backup Power EcoFlow DELTA Pro Ultra X Whole-Home Backup Power EcoFlow DELTA Pro Ultra X Whole-Home Backup Power EcoFlow DELTA Pro Ultra X Whole-Home Backup Power EcoFlow DELTA Pro Ultra X Whole-Home Backup Power EcoFlow DELTA Pro Ultra X Whole-Home Backup Power EcoFlow DELTA Pro Ultra X Whole-Home Backup Power EcoFlow DELTA Pro Ultra X Whole-Home Backup Power EcoFlow DELTA Pro Ultra X Whole-Home Backup Power EcoFlow DELTA Pro Ultra X Whole-Home Backup Power EcoFlow DELTA Pro Ultra X Whole-Home Backup Power EcoFlow DELTA Pro Ultra X Whole-Home Backup Power EcoFlow DELTA Pro Ultra X Whole-Home Backup Power EcoFlow DELTA Pro Ultra X Whole-Home Backup Power
PRIME DAY FALL DOTD
PRIME DAY FALL DOTD
PRIME DAY FALL DOTD
PRIME DAY FALL DOTD
PRIME DAY FALL DOTD
PRIME DAY FALL DOTD
PRIME DAY FALL DOTD
PRIME DAY FALL DOTD
PRIME DAY FALL DOTD
PRIME DAY FALL DOTD
PRIME DAY FALL DOTD
PRIME DAY FALL DOTD
PRIME DAY FALL DOTD
PRIME DAY FALL DOTD
Ends in
Days
  • 100% Whole-Home Power Station: Delivers 12–36kW output and 12–180kWh capacity.
  • Plug & play design, installed in 7 days. Save up to 80% on time and cost.
  • Smart & reliable when it matters most, 20ms auto switchover.
  • Save up to $6000/year, 3-year ROI.
  • End-to-end system protection, the highest safety standards.
*12kW/12kWh based on standard bundle (1 × EcoFlow DELTA Pro Ultra X Inverter + 2 × Smart Extra Batteries). Max 36 kW / 180 kWh with expansion. Actual performance varies by configuration.
⚠ Notice: 1. Rooftop solar charging for DPUX via SHP3/Gateway requires current transformers. 2. To connect two DELTA Pro Ultra X Inverters, use the EcoFlow Smart Inlet Box Connection Cable (5P8 Port to 5P8 Port) for proper installation.
Learn more
Service & Benefits
Installation Service
Step 1: Order Placement
When placing an installation order, please provide your full delivery address and contact details.
T&C:
One-Day Delivery
1. Free Shipping Policy
2. One-Day Delivery
Order DELTA Pro Ultra X by 7 AM (PDT) for delivery within 1 business day across select regions of Southern California, Northern Georgia, New Jersey, and Southern & Eastern Texas.
3. One-Day Delivery Regions
Members' Benefits
1. Earn More, Save More: Get 1 EcoCredit per $1 spent – redeem 20 Credits for $1 off anytime, or exchange for exclusive gifts and discounts.
2. Join EcoCredits Monthly Madness: Unlock more EcoCredits fun! Available every 4th Thursday of the month.
3. Bonus Rewards: Earn extra EcoCredits when you refer friends – unlock cash bonuses and special perks.
4. Priority Support: Enjoy 24/7 assistance, extended warranty coverage, and seamless trade-in options.
5. VIP Access: Be the first to shop new products, attend members-only events, and get insider update. Sign up>>
5-Year Warranty
Recommend
EcoFlow Installation Service Installation Service for Smart Home Panel 2 Turnkey Installation Service
Live Installation Support for SHP2/SHP3/Gateway
USD $0
By selecting this service, you agree to EcoFlow Live Installation Support Terms & Conditions (United States)
You acknowledge and consent that the Live Installation Support Service may record the site survey and installation process. Such recordings may capture identifiable images of you or other individuals present at the installation site. These recordings will be used solely for installation documentation and the resolution of any related disputes, and will be retained for no longer than 180 days, after which they will be securely deleted.
Official Installation Service
USD $0
USD $0
USD $0
Expand Your Capacity
Power With Solar
Optimize Your Energy
Selection Summary
EcoFlow DPUX-BUNDLE 2 x DELTA Pro Ultra X (2 x Inverter + 4 x Batteries) + Smart Home Panel 3 EcoFlow DELTA Pro Ultra X Whole-Home Backup Power
USD $18,399
USD $18,399
USD $18,399.00
Comparison
DELTA Pro Ultra X
DELTA Pro Ultra
DELTA Pro 3
12kW, 120/240V, 60HzUp to 36kW in 3 parallel units
Discharging: Pure sine, 7,200W total, 120V/240V~ 60HzBypass: 100-120V~30A total, 50Hz/60Hz
12kWh
102.4V⎓60A, 6,144Wh
4kWh
12kWh
102.4V⎓60A, 6,144Wh
4kWh
240v/50A
240v/30A
120v/20A
240v/50A
240v/30A
120v/20A
AC Charging Input:100-120V 50/60Hz 1800W 15A120/240V 50/60Hz 7200W 30A120/240V 50/60Hz 12000W 50ABypass Mode: 100-120V 50/60Hz 1800W 15A120/240V 50/60Hz 7200W 30A120/240V 50/60Hz 12000W 50ASolar Charging Input:80-500V, 15A RMS*2
AC Input"Charging: 100-120V~15A; 200-240V~12.5A, 50/60HzBypass: 100-120V~15A, 50/60Hz (duration < 3hrs when the current exceeds 12A)"Solar Charging Input"Total 5600W, 2 portsHigh-PV Input: 80-450V/15A, 4000W MaxLow-PV Input: 30-150V/15A, 1600W Max"
NEMA 5-20 (x2) 120V 20A NEMA L14-30 (x1) 120/240V 30A NEMA 14-50 (x1) 120/240V 50A
120V AC Output Socket (Backup UPS): 2 x 20A Max per port120V AC Output Socket (Online UPS): 2 x 20A Max per port120V AC Output Socket (Online UPS): 1 x 30A Max120V/240V AC Output Socket (Backup UPS): 1 x 30A Max
Total: 74 x NEMA 5-20R, 120V/20A1 x TT-30, 120V/30A1 x L14-30, 120V/240V/16.7A1 x NEMA 6-20R, 240V/16.7A
<10ms standalone, <20ms with Smart Home Panel 3
10ms
10ms
Up to 180kWh, 36kW
Up to 90kWh, 21.6kW
Up to 36kWh, 12kW
Up to 180kWh, 36kW
Up to 90kWh, 21.6kW
Up to 36kWh, 12kW
YES Auto switchover <20ms when paired with EcoFlow Smart Home Panel 3
YES Auto switchover <20ms when paired with EcoFlow Smart Home Panel 2
Customized WidgetDashboardThird-party Devices IntegrationFuture Electricity Price AnalysisSelf-PoweredTOU ModeScheduled TasksAPIAI Assistant
Customized WidgetDashboardThird-party Devices IntegrationFuture Electricity Price AnalysisGenerator Auto Start/StopSelf-PoweredTOU ModeScheduled TasksAPI
DashboardThird-party Devices IntegrationGenerator Auto Start/StopScheduled TasksAPI
Inverter: 34.5±0.2kg(70.06±0.44 lb)Battery: 50.5±0.2kg(111.3±0.44 lb)
Inverter: 31.7 kg (70 lb) Battery: 50.7 kg (111.8 lb)
Approx. 51.5 kg
Approx. 51.5 kg
Whole-Home Power. Unbound.
12–36kW Output
High Power. High IQ.
DELTA Pro Ultra X scales from 12 to 36kW. With a new Adaptive Start algorithm, it intelligently identifies connected appliances and tailors startup for each, seamlessly handling surges up to 45kW and high-demand appliances like a 5-ton AC.
Get Through Any Outage
12–180kWh Capacity—Power That Lasts
Plug your generator into DELTA Pro Ultra X for seamless backup²
10kW Solar Surge³
10kW Solar Surge³
10kW Solar Surge³
Start with 12kWh. Scale instantly to 180kWh
with up to 30 plug-in expansion batteries—no tools, no hassle. Power grows with your needs.
Plug your generator into DELTA Pro Ultra X for seamless backup.
With the EcoFlow FlowMaster Generator Rectifier, you can charge while delivering up to 12kW output—no downtime, no compromise. Compatible with all major portable generators.
Take in 10kW solar input—enough to recharge 12kWh to 80% in just around 1 hour.
Even during storm season, enjoy a full daily recharge and steady, unshakeable energy.
Installed in 7 Days
The wide-body inverter and battery are a stand-alone, off-grid unit—no wall mounting required. Its flexible design allows for faster, simpler approval than grid-tied systems. The exclusive quick-connect makes plug-and-play with the Smart Home Panel 3 or Smart Gateway effortless.
The Fastest Installation:
7 Days, 3 Steps
DAY 1-2: Installer Match
DAY 3-6: Site Visit
DAY 7: One-Day Installation
DAY 3-6: Site Visit
DAY 3-6: Site Visit
After your installation order is placed, we’ll match you with an EcoFlow Authorized Installer.
*7‑Day Installation counts from permit issuance (after purchase & delivery) until on‑site installation is complete.
An Authorized Installer will schedule a visit to your home to assess your setup and plan installation.
Your Smart Home Panel 3 is wired, your EcoFlow app is synced, and your system is fully live. We provide end-to-end support—so your home is powered, connected, and protected from day one.
Energy That Can Move With You
DIY Solar + Plug-and-Play Batteries
Smart & Reliable When It Matters Most
Auto-Recharging · 20ms Auto Switchover · 32 Circuits · Intelligent Control
Before the Storm: Get Alerts
When the Storm Hits: Lights Stay On
During the Storm: Extended Backup Time
Storm Guard Mode sends real-time alerts through the app and can automatically charge your DELTA Pro Ultra X to 100% using solar or grid power.
EcoFlow DELTA Pro Ultra X, paired with the Smart Home Panel 3 or Smart Gateway, switches your whole home from grid to battery power in under 20ms—faster than a blink. The lights stay on, Wi-Fi stays up, and even the game console keeps running. Zero delays. Zero disruptions.
With Smart Home Panel 3, tag appliances by priority in the app. Essentials stay powered while non-essentials are throttled—extending backup time by up to 42%. EcoFlow AI Assistant fine-tunes power use in real time, adapting to weather, usage, and solar input.
Your 24/7 Money Saver
Here's a Typical Day of Savings
Day and night, the system intelligently shifts between solar, storage, and off-peak rates—maximizing every watt to get you the best deal. Here's what that might look like on a typical day of use.
Compatible with Existing Rooftop Solar
No Wasted Watts
With the EcoFlow Current Sense Transformer, every extra watt is redirected to your DELTA Pro Ultra X Smart Extra battery—never wasted or sold back to the grid for pennies.
The Highest Safety
Standards
EV-grade full-tab cells
Durable battery pack
Dual BMS Protection
3-Level System Safety Architecture
Smart Extreme-Weather Protection
The first EV-grade full-tab cells deliver higher capacity with lower resistance, less heat, and longer-lasting performance. 25% More Efficient power flow (thanks to lower resistance: 1.5 mΩ vs. 2 mΩ) 25% Less Self-Heating
Perfectly matched cells ensure identical capacity, voltage, and resistance, minimizing wear and maximizing battery life. 24/7 Self-Maintenance: Automatic SOC balancing maximizes efficiency across the battery’s entire lifespan.
Local BMS – X-Guard® System: 44+ safeguards and comprehensive monitoring ensures all-around safety. Safeguards: overcharge/discharge, extreme temperatures, short circuits, component failures, and more Cloud BMS – Big Data Protection: 100+ anomaly detectors run 24/7, with instant alerts, local service response, and remote emergency support.
Power Protection: 1.2M circuit samples/sec, millisecond-level anomaly detection for inverter and battery. Connection Monitoring: Intelligent cable and interface safeguards track heat, recognize faults, and allow instant shutdown for total electrical security. Load Isolation: Continuous voltage/current monitoring with triple-layer isolation. Faulty devices are cut off automatically while critical loads stay powered.
Heats batteries in extreme cold for safe charging and longer runtime, while high-temp protection allows charging even at up to 45°C (113°F).
Dual BMS Protection
Dual BMS Protection
What's in the box?
Standard Capacity
12.288kWh, 6144Wh x 2
Maximum Capacity with 1 inverter
61.440kWh, 6144Wh x 10
Maximum Capacity with 3 inverters
184.32kWh, 6144Wh x 30
Net Weight (lb)
Dimension (mm)
Inverter: 675 × 475 × 230 mm (26.6 × 18.7 × 9.06 in.)
Battery:660 × 455 × 204 mm (26 × 18 × 8 in.)
5 years
Screen
Extra Battery
AC Outlets
UPS
Rated AC Input Power
12kW,100/200-120/240V, 50A
PV Input
Total 10kW, 2 ports
80-500V/15A, 5000W Max Each
Noise Level
Noise level <30 dB at 0.5 m (ambient temperature 25 °C, 4 kW output)
IP Rating
IP54
Battery Temperature
Operating&Storage temp: −4°F to 113°F (−20°C to 45°C)
Inverter Temperature
Operating&Storage temp: −4°F to 122°F (−20°C to 50°C)
What are the specifications of the AC output ports of the DELTA Pro Ultra X?
The AC output ports and specifications of the DELTA Pro Ultra X are as follows:Front: NEMA 5 - 20 interface (120V 20A), L14 - 30 interface (120V/240V 30A), 14 - 50 interface (120V/240V 50A).Right side: 5 + 8 input/output interface (120V/240V 50A)
What are the specifications of the DC input ports of the DELTA Pro Ultra X? Are there any DC output ports?
The DC input ports and specifications of the DELTA Pro Ultra X are as follows: High-PV input port: 80–500 V, 15 A per input, with a maximum total input of 10000W. There is no DC output port.
How many battery packs can the DELTA Pro Ultra X connect to at most?
The DELTA Pro Ultra X supports the parallel connection of up to 10 battery packs (with a single battery pack capacity of 6144Wh), which can significantly increase the backup power capacity.
What is the UPS switching time of the DELTA Pro Ultra X?
The UPS switching time of the DELTA Pro Ultra X is divided into two scenarios: When the DELTA Pro Ultra X operates independently: Power outage time < 10ms; When the DELTA Pro Ultra X operates in combination with the EcoFlow Smart Home Panel 3 (32 Circuits) or the Smart Gateway, the power outage switching time < 20ms.
What should be noted when connecting old batteries (DELTA Pro Ultra series) to the DELTA Pro Ultra X?
When connecting old batteries (with SN starting with Y712) to the DELTA Pro Ultra X, the following points must be followed: Only connect the old batteries to the rightmost Battery Port (the one farthest from the Power In/Out Port) for upgrading. Do not connect any batteries to the middle Battery Port to avoid abnormalities. Do not unplug the parallel connection cable during the upgrade process until the upgrade indicator on the screen disappears and the device restarts.
Which ecosystem products are compatible with DELTA Pro Ultra X?
DELTA Pro Ultra X is compatible with the following products (some require additional accessories): Third-party devices: 3 - 7.2kW/12kW generators, charging piles, EV charging guns; EcoFlow products: EcoFlow Smart Home Panel 3 (32 Circuits) or Smart Gateway intelligent distribution box.
What are the core upgrades of the DELTA Pro Ultra X compared to the previous generation of DELTA Pro Ultra?
The total output power is increased from 7200W to 12000W; The maximum number of connectable battery packs is increased from 5 to 10; The maximum total PV input power is increased from 5600W to 10000W.
How about the solar charging capacity of the DELTA Pro Ultra X?
Supports two-way high-voltage PV inputs, with a voltage range of 80 - 500V for each way, a maximum working current of 15A per way, and a total power of up to 10,000W; The photovoltaic interface needs to be connected to the EcoFlow PV Switch Box (standard configuration).
Does the DELTA Pro Ultra X require a specific way to connect the battery packs to achieve an output power of 12 kW?
Batteries need to be connected to both power-on pack ports on the Inverter. Additionally, it is recommended that the number of battery packs connected to the two ports be the same; if the number of battery packs connected to the two ports is inconsistent, the output power may not reach 12KW.
Can the DELTA Pro Ultra X output power in bypass mode when powered through the standard AC charging cable?
Yes, it's possible. The specification of the standard charging cable (EcoFlow AC Charging Cable (NEMA 5 - 15P to 5P8 Port)) is 15A, 120V. When charging with this cable, you can simultaneously output and carry a load from the front panel.
Can the DELTA Pro Ultra X change the power frequency to switch between 50Hz and 60Hz?
The frequency cannot be adjusted, and the default frequency is 60HZ. In bypass mode, the output frequency of the device is determined by the frequency of the input mains power (for example, if the mains power input is 60Hz, the output will be 60Hz; if the input is 50Hz, the output will be 50Hz).
Does the DELTA Pro Ultra X support charging by third-party generators?
Supported. There are two connection methods. You can directly connect to the Power in/out port via the accessory EcoFlow Generator Charging Adapter, or connect to the PV port through the EcoFlow FlowMaster Generator Rectifier [optional].
How to reset the Bluetooth connection of the DELTA Pro Ultra X?
When the device is turned off, press and hold the power button until the screen lights up, and then continue to hold it for about 5 seconds. When you hear the device beep twice in succession or see the device screen go off and then light up again, it indicates that the reset is successful.
Does the DELTA Pro Ultra X support grid connection?
It is not supported. The DELTA Pro Ultra X only draws power from the grid and will not actively transmit power back to the grid.
Terms & Conditions
Promotion Period
The EcoFlow Prime Day Sale promotion (hereinafter referred to as the 'Promotion Period') begins at 12:00 AM PDT on June 8, 2026, and ends at 11:59 PM PDT on July 3, 2026.
Installation Discount
A. Valid from 12:00 AM PDT on June 8, 2026, to 11:59 PM PDT on July 3, 2026.
B. Customers purchasing Smart Home Panel 3 are eligible for an automatic $900 discount on installation services related to Smart Home Panel 3 on https://us.ecoflow.com/. The discount will be applied automatically at checkout.
C. This Installation Discount is non-stackable with other discounts.
D. Installation Service Scope
VIP Customer Service: VIP support for installation and usage inquiries.
Professional Installation Service: 4-step professional installation process
Installation Service Fee Coverage: The standard Installation Service Fee ONLY covers the installation labor costs. For more installation information, refer to our Installation T&C
Free Sub Panel Removal: We'll remove your existing sub panel at no extra charge.
E. Installation fees are calculated based on the installation ZIP code. Pricing may vary by region and will be reflected at checkout.
Extended warranty service
A. During the Promotion Period, when you purchase and successfully pay for an order of DELTA Pro Ultra X and related bundles, you will get a 6-year free warranty: 5 years standard warranty plus an additional 1-year extended warranty.
B. The extended warranty applies only to the DELTA Pro Ultra X inverter and battery units included in the purchased system or bundle. It does not apply to accessories, installation services, third-party products, or any other components unless otherwise specified.
C. To qualify for the extended warranty, the purchased DELTA Pro Ultra X system or bundle must include both an inverter and at least one battery.
D. The extended warranty is subject to EcoFlow’s Warranty Policy. For complete warranty terms, coverage details, exclusions, and claim procedures, please refer to the Warranty Policy.
Disclaimer
1. The 32 Smart Circuits feature is only available when DELTA Pro Ultra X is paired with the EcoFlow Smart Home Panel 3. This feature is not supported by DELTA Pro Ultra X alone. The EcoFlow Smart Home Panel 3 is sold separately and is not included with this product.
2. The conclusion is based on internal testing. Actual performance may vary during real-world use.
3. Charging performance of reaching 80% in approximately 1 hour was measured under controlled conditions (ambient and cell temperature of 25 °C, with stable PV or AC charging power). Actual charging time may vary due to temperature, charging power fluctuations, or other environmental factors.
4. Installation time and cost savings are based on internal testing compared with conventional home standby generators and traditional residential energy storage systems. Actual results may vary depending on installer, site conditions, and especially local permit approval times. ⚠ Notice: Rooftop solar charging for DPUX via SHP3/Gateway requires current transformers.
